truenas not starting due to "uncorrectable I/O failure and has been suspended"
Grinas
So i had this thread open as i had a number of failing drives.
After replacing one drive and 12 hours of re silvering. truenas froze and i was unable to run any command via ssh or WebUI. I tired to restart it but after an hour or so it still had not rebooted and console said waiting on PID.
I did a hard reboot of the VM and now truenas wont start. When starting i get the error followed by errors you see below.
Solaris: WARNING: Pool 'ThreeTBM' has encountered an uncorrectable I/O failure and has been suspended
From looking at other threads with that error truenas seems to boot for them and they can see pool info. I have done a few drive changes such as replace new drive the old drive it replaced but the drives may be in different bays as I took out all the drives and labels them when i was changing the drive.
I left this boot for 12 hours and it was still not responding to ping, webUI access and console access.
I know the pool is probably gone but any one have any suggestions on how to get Truenas to boot so i can at least see the disks and see what has failed?
Arwen
First, the pool may not be "gone". ZFS is telling you their is a problem. This is likely due to your in-complete disk replacement. ZFS will normally resume the disk replacement on reboot. But, it could be you lost blocks or another whole disk in your RAID-Z1. That would either be file loss or pool loss, depending on what we see.
Please supply the output of the following command, in CODE tags;
zpool import
ZFS was specifically designed to survive a graceless, (aka a crash or hard power off), reboot. And do so without data loss, (except any data in flight, like any other file system). That said, hardware problems have had an impact on graceless reboots, causing data or pool loss.
One last note. When replacing a failing but not failed disk, if you have a spare disk slot, do a replace in place. This allows ZFS to keep the existing failing disk as a source of data, in addition to the other disks. With a RAID-Z1 pool this can be a life / pool saver, in case a bad block is found on another disk, but the failing disk has that block stripe still functional.
Grinas
zpool import
Sorry I should of been more clear in my first post truenas is not booting so i cant run those commands.
Will these commands work if i boot into another mode?
Arwen
Hmm, if the server is not booting, then something is wrong with your boot-pool. This is complicated because you are running a virtual machine.
Did you pass the LSI HBA through to your TrueNAS Core VM?
Get 2 new boot devices, one loaded with TrueNAS Core, and another available for installing TrueNAS Core. Install TrueNAS Core to the available one. Then boot off the new installed device. You should then be able to see your various pool's status. Unless you restore a saved configuration, the pools won't auto-import.
Grinas
So created and I installed a truenas 13 on a new vm.
It booted and i imported the affected pool. all the backups of this truenas were either on the pool or on gdrive with i had to get rid of delete a few week ago since they changed their licensing.
After importing the pool i still cant access the pool or disk info either via console or via Webui. It just shows loading. I have left it 30+ mins but still the same.
Should i leave it longer or does anyone else have any other suggestions?
How are the pool disks arriving in the VM? is the HBA in PCIe passthrough?
Grinas
OK; that's relatively good news.
so can you see the disks?
camcontrol devlist
And is the pool really imported yet?
zpool import
Grinas
camcontrol devlist
root@truenas[~]# camcontrol devlist
<NECVMWar VMware SATA CD00 1.00>   at scbus2 target 0 lun 0 (cd0,pass0)
<VMware Virtual disk 2.0>          at scbus32 target 0 lun 0 (pass1,da0)
<ATA WDC WD30EFRX-68E 0A82>        at scbus33 target 1 lun 0 (pass2,da1)
<ATA TOSHIBA DT01ACA3 ABB0>        at scbus33 target 3 lun 0 (pass3,da2)
<ATA WDC WD30EFRX-68E 0A82>        at scbus33 target 5 lun 0 (pass4,da3)
<ATA WDC WD30PURZ-85G 0A80>        at scbus33 target 7 lun 0 (pass5,da4)
<ATA NT-1TB 117D>                  at scbus33 target 8 lun 0 (pass6,da5)
<ATA WDC WD30PURX-64P 2B.3>        at scbus33 target 9 lun 0 (pass7,da6)
<ATA WDC WD42PURZ-85B 0A80>        at scbus33 target 12 lun 0 (pass8,da7)
<ATA WDC WD40EFZX-68A 0B81>        at scbus33 target 13 lun 0 (pass9,da8)
zpool import
I ran this command and got nothing back yet after waiting 5+ minutes.
How long would the pool normally take to import? Is there somewhere i can see the logs to see progress of import?
Minutes at most is "normal"... sometimes there can be issues.
dmesg will give you some clues perhaps
CAM messages are of particular interest if there are any.
Grinas
all i got from dmesg is below. No time stamp either so dont know when that message is from.
hwpc_core: unknown PMC architecture: 1
hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI>
Security policy loaded: MAC/ntpd (mac_ntpd)
Solaris: WARNING: Pool 'ThreeTBM' has encountered an uncorrectable I/O failure and has been suspended.
got a few errors about da2 having readable sectors in ESXI console too.
That's strange... if that's a disk in TrueNAS, and attached to the PCIe HBA which is in passthrough to the VM, ESXi can't see it.
That seems unreasonably short... are we saying the boot drive (virtual disk) is corrupt again? (is that what's on da2?)
That does seem to not be your boot pool though, so it's not great news for the pool import.
Grinas
When i say ESXI console i mean console of VM in ESXI so it is being seen by truenas VM.
No thats just the last 10 lines, the rest seems standard enough,
Here is the full `dmesg` output.
Copyright (c) 1992-2021 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
    The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 13.1-RELEASE-p7 n245428-4dfb91682c1 TRUENAS amd64
FreeBSD clang version 13.0.0 (git@github.com:llvm/llvm-project.git llvmorg-13.0.0-0-gd7b669b3a303)
VT(vga): text 80x25
CPU: Intel(R) Xeon(R) CPU E3-1225 v3 @ 3.20GHz (3192.61-MHz K8-class CPU)
  Origin="GenuineIntel"  Id=0x306c3  Family=0x6  Model=0x3c  Stepping=3
  Features=0xf83fbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,MMX,FXSR,SSE,SSE2,SS>
  Features2=0xfffa3203<SSE3,PCLMULQDQ,SSSE3,FMA,CX16,PCID,SSE4.1,SSE4.2,x2APIC,MOVBE,POPCNT,TSCDLT,AESNI,XSAVE,OSXSAVE,AVX,F16C,RDRAND,HV>
  AMD Features=0x2c100800<SYSCALL,NX,Page1GB,RDTSCP,LM>
  AMD Features2=0x21<LAHF,ABM>
  Structured Extended Features=0x27ab<FSGSBASE,TSCADJ,BMI1,AVX2,SMEP,BMI2,ERMS,INVPCID,NFPUSG>
  Structured Extended Features3=0xbc000400<MD_CLEAR,IBPB,STIBP,L1DFL,ARCH_CAP,SSBD>
  XSAVE Features=0x1<XSAVEOPT>
  IA32_ARCH_CAPS=0xc<RSBA,SKIP_L1DFL_VME>
  TSC: P-state invariant
Hypervisor: Origin = "VMwareVMware"
real memory  = 21474836480 (20480 MB)
avail memory = 20802605056 (19838 MB)
Event timer "LAPIC" quality 600
ACPI APIC Table: <PTLTD       APIC  >
FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
FreeBSD/SMP: 4 package(s) x 1 core(s)
random: registering fast source Intel Secure Key RNG
random: fast provider: "Intel Secure Key RNG"
arc4random: WARNING: initial seeding bypassed the cryptographic random device because it was not yet seeded and the knob 'bypass_before_seeding' was enabled.
MADT: Forcing active-low polarity and level trigger for SCI
ioapic0 <Version 2.0> irqs 0-23
Launching APs: 2 3 1
random: entropy device external interface
kbd1 at kbdmux0
vtvga0: <VT VGA driver>
aesni0: <AES-CBC,AES-CCM,AES-GCM,AES-ICM,AES-XTS>
padlock0: No ACE support.
acpi0: <INTEL 440BX>
acpi0: Power Button (fixed)
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 950
cpu0: <ACPI CPU> numa-domain 0 on acpi0
attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
atrtc0: registered as a time-of-day clock, resolution 1.000000s
Event timer "RTC" frequency 32768 Hz quality 0
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x1008-0x100b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
isab0: <PCI-ISA bridge> at device 7.0 on pci0
isa0: <ISA bus> on isab0
atapci0: <Intel PIIX4 UDMA33 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0x1060-0x106f at device 7.1 on pci0
ata0: <ATA channel> at channel 0 on atapci0
ata1: <ATA channel> at channel 1 on atapci0
pci0: <bridge> at device 7.3 (no driver attached)
vgapci0: <VGA-compatible display> port 0x1070-0x107f mem 0xe8000000-0xefffffff,0xfe000000-0xfe7fffff irq 16 at device 15.0 on pci0
vgapci0: Boot video device
pcib2: <ACPI PCI-PCI bridge> at device 17.0 on pci0
pci2: <ACPI PCI bus> on pcib2
uhci0: <UHCI (generic) USB controller> port 0x2000-0x201f irq 18 at device 0.0 on pci2
usbus0 on uhci0
usbus0: 12Mbps Full Speed USB v1.0
ehci0: <EHCI (generic) USB 2.0 controller> mem 0xfd5ff000-0xfd5fffff irq 19 at device 1.0 on pci2
usbus1: EHCI version 1.0
usbus1 on ehci0
usbus1: 480Mbps High Speed USB v2.0
ahci0: <AHCI SATA controller> mem 0xfd5fe000-0xfd5fefff irq 17 at device 3.0 on pci2
ahci0: AHCI v1.30 with 30 6Gbps ports, Port Multiplier not supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
ahcich2: <AHCI channel> at channel 2 on ahci0
ahcich3: <AHCI channel> at channel 3 on ahci0
ahcich4: <AHCI channel> at channel 4 on ahci0
ahcich5: <AHCI channel> at channel 5 on ahci0
ahcich6: <AHCI channel> at channel 6 on ahci0
ahcich7: <AHCI channel> at channel 7 on ahci0
ahcich8: <AHCI channel> at channel 8 on ahci0
ahcich9: <AHCI channel> at channel 9 on ahci0
ahcich10: <AHCI channel> at channel 10 on ahci0
ahcich11: <AHCI channel> at channel 11 on ahci0
ahcich12: <AHCI channel> at channel 12 on ahci0
ahcich13: <AHCI channel> at channel 13 on ahci0
ahcich14: <AHCI channel> at channel 14 on ahci0
ahcich15: <AHCI channel> at channel 15 on ahci0
ahcich16: <AHCI channel> at channel 16 on ahci0
ahcich17: <AHCI channel> at channel 17 on ahci0
ahcich18: <AHCI channel> at channel 18 on ahci0
ahcich19: <AHCI channel> at channel 19 on ahci0
ahcich20: <AHCI channel> at channel 20 on ahci0
ahcich21: <AHCI channel> at channel 21 on ahci0
ahcich22: <AHCI channel> at channel 22 on ahci0
ahcich23: <AHCI channel> at channel 23 on ahci0
ahcich24: <AHCI channel> at channel 24 on ahci0
ahcich25: <AHCI channel> at channel 25 on ahci0
ahcich26: <AHCI channel> at channel 26 on ahci0
ahcich27: <AHCI channel> at channel 27 on ahci0
ahcich28: <AHCI channel> at channel 28 on ahci0
ahcich29: <AHCI channel> at channel 29 on ahci0
pcib3: <ACPI PCI-PCI bridge> at device 21.0 on pci0
pci3: <ACPI PCI bus> on pcib3
mpt0: <LSILogic SAS/SATA Adapter> port 0x4000-0x40ff mem 0xfd4ec000-0xfd4effff,0xfd4f0000-0xfd4fffff irq 18 at device 0.0 on pci3
mpt0: MPI Version=1.5.0.0
pcib4: <ACPI PCI-PCI bridge> at device 21.1 on pci0
pcib5: <ACPI PCI-PCI bridge> at device 21.2 on pci0
pcib6: <ACPI PCI-PCI bridge> at device 21.3 on pci0
pcib7: <ACPI PCI-PCI bridge> at device 21.4 on pci0
pcib8: <ACPI PCI-PCI bridge> at device 21.5 on pci0
pcib9: <ACPI PCI-PCI bridge> at device 21.6 on pci0
pcib10: <ACPI PCI-PCI bridge> at device 21.7 on pci0
pcib11: <ACPI PCI-PCI bridge> at device 22.0 on pci0
pci4: <ACPI PCI bus> on pcib11
mps0: <Avago Technologies (LSI) SAS2308> port 0x5000-0x50ff mem 0xfd3f0000-0xfd3fffff,0xfd380000-0xfd3bffff irq 19 at device 0.0 on pci4
mps0: Firmware: 20.00.07.00, Driver: 21.02.00.00-fbsd
mps0: IOCCapabilities: 5a85c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,MSIXIndex,HostDisc>
pcib12: <ACPI PCI-PCI bridge> at device 22.1 on pci0
pcib13: <ACPI PCI-PCI bridge> at device 22.2 on pci0
pcib14: <ACPI PCI-PCI bridge> at device 22.3 on pci0
pcib15: <ACPI PCI-PCI bridge> at device 22.4 on pci0
pcib16: <ACPI PCI-PCI bridge> at device 22.5 on pci0
pcib17: <ACPI PCI-PCI bridge> at device 22.6 on pci0
pcib18: <ACPI PCI-PCI bridge> at device 22.7 on pci0
pcib19: <ACPI PCI-PCI bridge> at device 23.0 on pci0
pci5: <ACPI PCI bus> on pcib19
vmx0: <VMware VMXNET3 Ethernet Adapter> port 0x6000-0x600f mem 0xfd2fc000-0xfd2fcfff,0xfd2fd000-0xfd2fdfff,0xfd2fe000-0xfd2fffff irq 16 at device 0.0 on pci5
vmx0: Using 512 TX descriptors and 512 RX descriptors
vmx0: Using 4 RX queues 4 TX queues
vmx0: Using MSI-X interrupts with 5 vectors
vmx0: Ethernet address: 00:0c:29:e9:75:05
pcib20: <ACPI PCI-PCI bridge> at device 23.1 on pci0
pcib21: <ACPI PCI-PCI bridge> at device 23.2 on pci0
pcib22: <ACPI PCI-PCI bridge> at device 23.3 on pci0
pcib23: <ACPI PCI-PCI bridge> at device 23.4 on pci0
pcib24: <ACPI PCI-PCI bridge> at device 23.5 on pci0
pcib25: <ACPI PCI-PCI bridge> at device 23.6 on pci0
pcib26: <ACPI PCI-PCI bridge> at device 23.7 on pci0
pcib27: <ACPI PCI-PCI bridge> at device 24.0 on pci0
pcib28: <ACPI PCI-PCI bridge> at device 24.1 on pci0
pcib29: <ACPI PCI-PCI bridge> at device 24.2 on pci0
pcib30: <ACPI PCI-PCI bridge> at device 24.3 on pci0
pcib31: <ACPI PCI-PCI bridge> at device 24.4 on pci0
pcib32: <ACPI PCI-PCI bridge> at device 24.5 on pci0
pcib33: <ACPI PCI-PCI bridge> at device 24.6 on pci0
pcib34: <ACPI PCI-PCI bridge> at device 24.7 on pci0
acpi_acad0: <AC Adapter> on acpi0
atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
psm0: <PS/2 Mouse> irq 12 on atkbdc0
psm0: [GIANT-LOCKED]
WARNING: Device "psm" is Giant locked and may be deleted before FreeBSD 14.0.
psm0: model IntelliMouse, device ID 3
acpi_syscontainer0: <System Container> on acpi0
orm0: <ISA Option ROMs> at iomem 0xc0000-0xc7fff,0xc8000-0xc9fff,0xca000-0xcbfff,0xcc000-0xccfff,0xdc000-0xdffff,0xe0000-0xe7fff pnpid ORM0000 on isa0
Timecounter "TSC-low" frequency 1596303500 Hz quality 1000
Timecounters tick every 10.000 msec
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
ugen1.1: <(0x15ad) EHCI root HUB> at usbus1
ugen0.1: <(0x15ad) UHCI root HUB> at usbus0
uhub0 on usbus1
uhub0: <(0x15ad) EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
uhub1 on usbus0
uhub1: <(0x15ad) UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
random: unblocking device.
Trying to mount root from cd9660:iso9660/TRUENAS []...
uhub1: 2 ports with 2 removable, self powered
Root mount waiting for: CAM usbus0 usbus1
ugen0.2: <VMware VMware Virtual USB Mouse> at usbus0
uhid0 on uhub1
uhid0: <VMware> on usbus0
ums0 on uhub1
ums0: <VMware> on usbus0
ums0: 16 buttons and [XYZT] coordinates ID=0
ugen0.3: <vendor 0x0e0f VMware Virtual USB Hub> at usbus0
uhub2 on uhub1
uhub2: <VMware Virtual USB Hub> on usbus0
uhub0: 6 ports with 6 removable, self powered
da0 at mpt0 bus 0 scbus32 target 0 lun 0
da0: <VMware Virtual disk 2.0> Fixed Direct Access SPC-4 SCSI device
da0: 300.000MB/s transfers
da0: Command Queueing enabled
da0: 8192MB (16777216 512 byte sectors)
da0: quirks=0x140<RETRY_BUSY,STRICT_UNMAP>
cd0 at ahcich0 bus 0 scbus2 target 0 lun 0
cd0: <NECVMWar VMware SATA CD00 1.00> Removable CD-ROM SCSI device
cd0: Serial Number 00000000000000000001
cd0: 600.000MB/s transfers (SATA 3.x, UDMA2, ATAPI 12bytes, PIO 8192bytes)
cd0: 998MB (511399 2048 byte sectors)
da5 at mps0 bus 0 scbus33 target 8 lun 0
da5: <ATA NT-1TB 117D> Fixed Direct Access SPC-4 SCSI device
da5: Serial Number 9100113100090
da5: 600.000MB/s transfers
da5: Command Queueing enabled
da5: 976762MB (2000409264 512 byte sectors)
da8 at mps0 bus 0 scbus33 target 13 lun 0
da8: <ATA WDC WD40EFZX-68A 0B81> Fixed Direct Access SPC-4 SCSI device
da8: Serial Number WD-WX12D514R32V
da8: 600.000MB/s transfers
da8: Command Queueing enabled
da8: 3815447MB (7814037168 512 byte sectors)
da3 at mps0 bus 0 scbus33 target 5 lun 0
da3: <ATA WDC WD30EFRX-68E 0A82> Fixed Direct Access SPC-4 SCSI device
da3: Serial Number WD-WCC4N6SS9F16
da3: 600.000MB/s transfers
da3: Command Queueing enabled
da3: 2861588MB (5860533168 512 byte sectors)
da3: quirks=0x8<4K>
da1 at mps0 bus 0 scbus33 target 1 lun 0
da1: <ATA WDC WD30EFRX-68E 0A82> Fixed Direct Access SPC-4 SCSI device
da1: Serial Number WD-WCC4N0XP648R
da1: 600.000MB/s transfers
da1: Command Queueing enabled
da1: 2861588MB (5860533168 512 byte sectors)
da1: quirks=0x8<4K>
da6 at mps0 bus 0 scbus33 target 9 lun 0
da6: <ATA WDC WD30PURX-64P 2B.3> Fixed Direct Access SPC-4 SCSI device
da6: Serial Number WD-WCC4N6VVXV6T
da6: 300.000MB/s transfers
da6: Command Queueing enabled
da6: 2862443MB (5862285072 512 byte sectors)
da6: quirks=0x8<4K>
da7 at mps0 bus 0 scbus33 target 12 lun 0
da7: <ATA WDC WD42PURZ-85B 0A80> Fixed Direct Access SPC-4 SCSI device
da7: Serial Number WD-WX32D917Z45D
da7: 600.000MB/s transfers
da7: Command Queueing enabled
da7: 3815447MB (7814037168 512 byte sectors)
da4 at mps0 bus 0 scbus33 target 7 lun 0
da4: <ATA WDC WD30PURZ-85G 0A80> Fixed Direct Access SPC-4 SCSI device
da4: Serial Number WD-WCC4N7AY14Z9
da4: 600.000MB/s transfers
da4: Command Queueing enabled
da4: 2861588MB (5860533168 512 byte sectors)
da2 at mps0 bus 0 scbus33 target 3 lun 0
da2: <ATA TOSHIBA DT01ACA3 ABB0> Fixed Direct Access SPC-4 SCSI device
da2: Serial Number X3V9SV5GS
da2: 600.000MB/s transfers
da2: Command Queueing enabled
da2: 2861588MB (5860533168 512 byte sectors)
uhub2: 7 ports with 7 removable, self powered
md0 attached to /data/base.ufs.uzip
Trying to mount root from ufs:/dev/md0.uzip [rw]...
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
Waiting (max 60 seconds) for system process `vnlru' to stop... done
Waiting (max 60 seconds) for system process `syncer' to stop...
Syncing disks, vnodes remaining... 0 0 done
All buffers synced.
Uptime: 23m30s
mps0: Sending StopUnit: path (xpt0:mps0:0:8:ffffffff):  handle 14
uhub0: detached
mps0: Incrementing SSU count
uhid0: detached
ums0: detached
mps0: Decrementing SSU count.
mps0: Completing stop unit for (xpt0:mps0:0:8:ffffffff):
---<<BOOT>>---
VT(vga): text 80x25
avail memory = 20789882880 (19826 MB)
Launching APs: 2 1 3
kbd1 at kbdmux0
usbus0 on uhci0
usbus1 on ehci0
kbd0 at atkbd0
uhub0 on usbus0
uhub0: <(0x15ad) UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
uhub1 on usbus1
uhub1: <(0x15ad) EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
Trying to mount root from zfs:boot-pool/ROOT/default []...
uhub0: 2 ports with 2 removable, self powered
uhid0 on uhub0
ums0 on uhub0
uhub2 on uhub0
uhub1: 6 ports with 6 removable, self powered
da3: quirks=0x8<4K>
da1: quirks=0x8<4K>
da6: quirks=0x8<4K>
intsmb0: <Intel PIIX4 SMBUS Interface> port 0x1040-0x104f at device 7.3 on pci0
intsmb0: intr SMI disabled revision 0
smbus0: <System Management Bus> on intsmb0
lo0: link state changed to UP
vmx_modinit: processor does not support VMX operation
module_register_init: MOD_LOAD (vmm, 0xffffffff83604200, 0) error 6
  Features=0xf8bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,SS>
VMware memory control driver initialized
vmx0: link state changed to UP
I would of thought it would of least been able to tell me the problematic drives so i can try to switch them with the old degraded ones. Now i dont know what drives are good and whats not to create a new pool.
These are the errors i see on truenas vm console
You should still be able to run zpool status and see something in that state (I would expect).
How about smartctl -a /dev/da3 (etc.)?
Grinas
10 minutes since i ran zpool status and zero output. Doesnt appear to have locked up as when i press enter it goes to new line.
smartctl -a /dev/da3 this does seem to work.
da1
smartctl -a /dev/da1
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p7 amd64] (local build)
Model Family:     Western Digital Red
Device Model:     WDC WD30EFRX-68EUZN0
Serial Number:    WD-WCC4N0XP648R
LU WWN Device Id: 5 0014ee 2640bcb11
Firmware Version: 82.00A82
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Rotation Rate:    5400 rpm
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Tue Aug  8 06:18:19 2023 PDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00)    Offline data collection activity
                    was never started.
Self-test execution status:      (   0)    The previous self-test routine completed
                    been run.
data collection:         (40080) seconds.
capabilities:              (0x7b) SMART execute Offline immediate.
                    command.
                    Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
Error logging capability:        (0x01)    Error logging supported.
Short self-test routine
recommended polling time:      (   2) minutes.
Extended self-test routine
recommended polling time:      ( 402) minutes.
Conveyance self-test routine
recommended polling time:      (   5) minutes.
SCT capabilities:            (0x703d)    SCT Status supported.
                    SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       3
  3 Spin_Up_Time            0x0027   182   180   021    Pre-fail  Always       -       5866
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       233
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   100   253   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   039   039   000    Old_age   Always       -       44592
 10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       233
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       232
193 Load_Cycle_Count        0x0032   199   199   000    Old_age   Always       -       5198
194 Temperature_Celsius     0x0022   113   097   000    Old_age   Always       -       37
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       1
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed without error       00%     35590         -
# 2  Extended offline    Completed without error       00%     32877         -
# 3  Extended offline    Completed without error       00%     32853         -
# 4  Extended offline    Completed without error       00%     32783         -
da2
smartctl -a /dev/da2
Model Family:     Toshiba 3.5" DT01ACA... Desktop HDD
Device Model:     TOSHIBA DT01ACA300
Serial Number:    X3V9SV5GS
LU WWN Device Id: 5 000039 ff4d2885a
Firmware Version: MX6OABB0
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
ATA Version is:   ATA8-ACS T13/1699-D revision 4
Local Time is:    Tue Aug  8 06:19:39 2023 PDT
Offline data collection status:  (0x84)    Offline data collection activity
                    was suspended by an interrupting command from host.
                    been run.
data collection:         (22652) seconds.
capabilities:              (0x5b) SMART execute Offline immediate.
                    command.
                    power-saving mode.
recommended polling time:      (   1) minutes.
recommended polling time:      ( 378) minutes.
SCT capabilities:            (0x003d)    SCT Status supported.
  1 Raw_Read_Error_Rate     0x000b   100   100   016    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0005   139   139   054    Pre-fail  Offline      -       70
  3 Spin_Up_Time            0x0007   147   147   024    Pre-fail  Always       -       415 (Average 365)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       591
  5 Reallocated_Sector_Ct   0x0033   094   094   005    Pre-fail  Always       -       276
  7 Seek_Error_Rate         0x000b   100   100   067    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   124   124   020    Pre-fail  Offline      -       33
  9 Power_On_Hours          0x0012   092   092   000    Old_age   Always       -       61005
 10 Spin_Retry_Count        0x0013   100   100   060    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       403
192 Power-Off_Retract_Count 0x0032   099   099   000    Old_age   Always       -       1341
193 Load_Cycle_Count        0x0012   099   099   000    Old_age   Always       -       1341
194 Temperature_Celsius     0x0002   171   171   000    Old_age   Always       -       35 (Min/Max 13/57)
196 Reallocated_Event_Count 0x0032   093   093   000    Old_age   Always       -       307
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       120
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       1102
ATA Error Count: 1153 (device log contains only the most recent five errors)
    CR = Command Register [HEX]
    FR = Features Register [HEX]
    ER = Error register [HEX]
    ST = Status register [HEX]
Error 1153 occurred at disk power-on lifetime: 60867 hours (2536 days + 3 hours)
  ER ST SC SN CL CH DH
  84 51 00 00 4f c2 00  Error: ABRT
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  b0 d5 01 01 4f c2 00 00      05:46:54.563  SMART READ LOG
  b0 d5 01 00 4f c2 00 00      05:46:54.563  SMART READ LOG
  b0 da 00 00 4f c2 00 00      05:46:54.396  SMART RETURN STATUS
  b0 d1 01 01 4f c2 00 00      05:46:54.231  SMART READ ATTRIBUTE THRESHOLDS [OBS-4]
  b0 d0 01 00 4f c2 00 00      05:46:53.963  SMART READ DATA
Error 1152 occurred at disk power-on lifetime: 60867 hours (2536 days + 3 hours)
  84 51 c1 3f 02 00 00  Error: ICRC, ABRT at LBA = 0x0000023f = 575
  60 e0 10 20 a0 50 40 00      05:46:11.191  READ FPDMA QUEUED
  60 e0 08 20 9e 50 40 00      05:46:11.191  READ FPDMA QUEUED
  60 e0 00 20 02 00 40 00      05:46:11.191  READ FPDMA QUEUED
  2f 00 01 10 00 00 00 00      05:46:11.190  READ LOG EXT
  60 e0 18 20 a0 50 40 00      05:46:11.183  READ FPDMA QUEUED
Error 1151 occurred at disk power-on lifetime: 60867 hours (2536 days + 3 hours)
  84 51 c1 3f 00 00 00  Error: ICRC, ABRT at LBA = 0x0000003f = 63
  60 e0 10 20 9e 50 40 00      05:46:11.183  READ FPDMA QUEUED
  60 e0 08 20 02 00 40 00      05:46:11.183  READ FPDMA QUEUED
  60 e0 00 20 00 00 40 00      05:46:11.183  READ FPDMA QUEUED
  2f 00 01 10 00 00 00 00      05:46:11.182  READ LOG EXT
Error 1150 occurred at disk power-on lifetime: 60867 hours (2536 days + 3 hours)
  60 e0 18 20 a0 50 40 00      05:46:11.153  READ FPDMA QUEUED
  60 e0 10 20 9e 50 40 00      05:46:11.153  READ FPDMA QUEUED
  60 e0 08 20 02 00 40 00      05:46:11.153  READ FPDMA QUEUED
  60 e0 00 20 00 00 40 00      05:46:11.153  READ FPDMA QUEUED
  2f 00 01 10 00 00 00 00      05:46:11.152  READ LOG EXT
Error 1149 occurred at disk power-on lifetime: 60867 hours (2536 days + 3 hours)
  84 51 d1 2f 9e 50 0d  Error: ICRC, ABRT at LBA = 0x0d509e2f = 223387183
  60 e0 18 20 00 00 40 00      05:46:11.125  READ FPDMA QUEUED
  60 e0 10 20 02 00 40 00      05:46:11.124  READ FPDMA QUEUED
  60 e0 08 20 a0 50 40 00      05:46:11.124  READ FPDMA QUEUED
  60 e0 00 20 9e 50 40 00      05:46:11.124  READ FPDMA QUEUED
  ef 10 02 00 00 00 00 00      05:46:11.073  SET FEATURES [Enable SATA feature]
# 1  Short offline       Completed without error       00%     60410         -
# 2  Short offline       Completed without error       00%     60398         -
# 3  Short offline       Completed without error       00%     60242         -
# 4  Short offline       Completed without error       00%     60230         -
# 5  Short offline       Completed without error       00%     60026         -
# 6  Short offline       Completed without error       00%     60014         -
# 7  Short offline       Completed without error       00%     59858         -
# 8  Short offline       Completed without error       00%     59846         -
# 9  Short offline       Completed without error       00%     59690         -
#10  Short offline       Completed without error       00%     59678         -
#11  Short offline       Completed without error       00%     59525         -
#12  Short offline       Completed without error       00%     59513         -
#13  Short offline       Completed without error       00%     59285         -
#14  Short offline       Completed without error       00%     59273         -
#15  Short offline       Completed without error       00%     59117         -
#16  Short offline       Completed without error       00%     59105         -
#17  Short offline       Completed without error       00%     58949         -
#18  Short offline       Completed without error       00%     58937         -
#19  Short offline       Completed without error       00%     58781         -
#20  Short offline       Completed without error       00%     58769         -
#21  Short offline       Completed without error       00%     58565         -
da3
Serial Number:    WD-WCC4N6SS9F16
LU WWN Device Id: 5 0014ee 20e541427
Local Time is:    Tue Aug  8 06:20:06 2023 PDT
                    was never started.
                    been run.
data collection:         (40020) seconds.
                    command.
                    power-saving mode.
recommended polling time:      ( 401) minutes.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       1
  3 Spin_Up_Time            0x0027   181   178   021    Pre-fail  Always       -       5925
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       263
  9 Power_On_Hours          0x0032   028   028   000    Old_age   Always       -       53028
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       263
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       248
193 Load_Cycle_Count        0x0032   193   193   000    Old_age   Always       -       22575
194 Temperature_Celsius     0x0022   111   100   000    Old_age   Always       -       39
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
No Errors Logged
# 1  Short offline       Completed without error       00%     52767         -
# 2  Short offline       Completed without error       00%     52755         -
# 3  Short offline       Completed without error       00%     52599         -
# 4  Short offline       Completed without error       00%     52587         -
# 5  Short offline       Completed without error       00%     52431         -
# 6  Short offline       Completed without error       00%     52419         -
# 7  Short offline       Completed without error       00%     52264         -
# 8  Short offline       Completed without error       00%     52252         -
# 9  Short offline       Completed without error       00%     52048         -
#10  Short offline       Completed without error       00%     52036         -
#11  Short offline       Completed without error       00%     51880         -
#12  Short offline       Completed without error       00%     51868         -
#13  Short offline       Completed without error       00%     51712         -
#14  Short offline       Completed without error       00%     51700         -
#15  Short offline       Completed without error       00%     51548         -
#16  Short offline       Completed without error       00%     51536         -
#17  Short offline       Completed without error       00%     51308         -
#18  Short offline       Completed without error       00%     51296         -
#19  Short offline       Completed without error       00%     51140         -
#20  Short offline       Completed without error       00%     51128         -
#21  Short offline       Completed without error       00%     50972         -
da4
smartctl -a /dev/da4
Model Family:     Western Digital Purple
Device Model:     WDC WD30PURZ-85GU6Y0
Serial Number:    WD-WCC4N7AY14Z9
LU WWN Device Id: 5 0014ee 265d1adc5
Firmware Version: 80.00A80
Local Time is:    Tue Aug  8 06:20:23 2023 PDT
                    was never started.
                    been run.
data collection:         (39600) seconds.
                    command.
                    power-saving mode.
recommended polling time:      ( 398) minutes.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   184   182   021    Pre-fail  Always       -       5766
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       126
  9 Power_On_Hours          0x0032   060   060   000    Old_age   Always       -       29213
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       126
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       124
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       648
194 Temperature_Celsius     0x0022   116   092   000    Old_age   Always       -       34
No Errors Logged
# 1  Extended offline    Completed without error       00%     20214         -
# 2  Extended offline    Completed without error       00%     17496         -
# 3  Extended offline    Completed without error       00%     17472         -
# 4  Extended offline    Completed without error       00%     17402         -
# 5  Extended offline    Aborted by host               90%     17364         -
# 6  Short offline       Completed without error       00%     17179         -
# 7  Extended offline    Completed without error       00%     17137         -
# 8  Conveyance offline  Completed without error       00%     17129         -
# 9  Extended offline    Aborted by host               90%     17129         -
#10  Short offline       Completed without error       00%     17129         -
da6
smartctl -a /dev/da6
Device Model:     WDC WD30PURX-64P6ZY0
Serial Number:    WD-WCC4N6VVXV6T
LU WWN Device Id: 0 000000 000000000
Firmware Version: 01.12B.3
User Capacity:    3,001,489,956,864 bytes [3.00 TB]
ATA Version is:   ATA8-ACS (minor revision not indicated)
Local Time is:    Tue Aug  8 06:20:55 2023 PDT
                    was never started.
                    been run.
data collection:         (42300) seconds.
                    command.
                    power-saving mode.
recommended polling time:      ( 424) minutes.
  1 Raw_Read_Error_Rate     0xfc77   200   200   051    Pre-fail  Always       -       60
  3 Spin_Up_Time            0xe455   221   218   021    Pre-fail  Offline      -       3933
  4 Start_Stop_Count        0xe054   100   100   000    Old_age   Offline      -       108
  5 Reallocated_Sector_Ct   0xf455   200   200   140    Pre-fail  Offline      -       0
  7 Seek_Error_Rate         0xe455   200   200   051    Pre-fail  Offline      -       0
  9 Power_On_Hours          0xec74   063   063   000    Old_age   Offline      -       27110
 10 Spin_Retry_Count        0xd675   100   100   051    Pre-fail  Offline      -       0
 11 Calibration_Retry_Count 0xac14   100   100   051    Old_age   Offline      -       0
 12 Power_Cycle_Count       0xfc34   100   100   000    Old_age   Offline      -       108
184 End-to-End_Error        0xf477   100   100   097    Pre-fail  Always       -       0
187 Reported_Uncorrect      0xb414   100   100   000    Old_age   Offline      -       0
188 Command_Timeout         0xb436   100   099   000    Old_age   Always       -       1
190 Airflow_Temperature_Cel 0xac76   065   042   000    Old_age   Always       -       35
192 Power-Off_Retract_Count 0xa474   200   200   000    Old_age   Offline      -       107
193 Load_Cycle_Count        0xa476   200   200   000    Old_age   Always       -       0
194 Temperature_Celsius     0xc45c   115   092   000    Old_age   Offline      -       35
195 Hardware_ECC_Recovered  0xdc7e   200   200   000    Old_age   Always       -       0
196 Reallocated_Event_Count 0xbc74   200   200   000    Old_age   Offline      -       0
197 Current_Pending_Sector  0xe674   200   200   000    Old_age   Offline      -       0
198 Offline_Uncorrectable   0xfc7e   100   253   000    Old_age   Always       -       0
199 UDMA_CRC_Error_Count    0xc456   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0xbc57   200   200   051    Pre-fail  Always       -       28
No Errors Logged
# 1  Short offline       Completed: read failure       30%     26986         4191536
# 2  Extended offline    Completed: read failure       10%     18117         4198216
# 3  Extended offline    Completed: read failure       90%     15402         4198216
# 4  Extended offline    Completed: read failure       90%     15380         4198216
# 5  Extended offline    Completed: read failure       90%     15380         4198216
# 6  Extended offline    Completed: read failure       90%     15378         4198216
# 7  Extended offline    Completed: read failure       90%     15308         4198216
Grinas
needed second post as i hit char limit. I left out Da5 as that is a SSD used for jails
da7
smartctl -a /dev/da7
Device Model:     WDC WD42PURZ-85B4YY0
Serial Number:    WD-WX32D917Z45D
LU WWN Device Id: 5 0014ee 269f574a5
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Rotation Rate:    5040 rpm
TRIM Command:     Available
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Tue Aug  8 06:21:08 2023 PDT
                    was never started.
                    been run.
data collection:         ( 1800) seconds.
                    command.
                    power-saving mode.
recommended polling time:      ( 438) minutes.
SCT capabilities:            (0x3039)    SCT Status supported.
  3 Spin_Up_Time            0x0027   206   206   021    Pre-fail  Always       -       2700
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       20
  9 Power_On_Hours          0x0032   088   088   000    Old_age   Always       -       9029
 10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       19
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       17
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       2
194 Temperature_Celsius     0x0022   115   095   000    Old_age   Always       -       32
No Errors Logged
# 1  Extended offline    Completed without error       00%        46         -
da8
smartctl -a /dev/da8
Device Model:     WDC WD40EFZX-68AWUN0
Serial Number:    WD-WX12D514R32V
LU WWN Device Id: 5 0014ee 214503a33
Firmware Version: 81.00B81
Local Time is:    Tue Aug  8 06:21:41 2023 PDT
                    was never started.
                    been run.
data collection:         (41520) seconds.
capabilities:              (0x11) SMART execute Offline immediate.
                    No Auto Offline data collection support.
                    command.
                    No Offline surface scan supported.
                    No Selective Self-test supported.
                    power-saving mode.
recommended polling time:      ( 442) minutes.
SCT capabilities:            (0x303d)    SCT Status supported.
  3 Spin_Up_Time            0x0027   218   218   021    Pre-fail  Always       -       4058
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       7
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       131
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       6
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       4
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       27
194 Temperature_Celsius     0x0022   118   107   000    Old_age   Always       -       32
200 Multi_Zone_Error_Rate   0x0008   100   253   000    Old_age   Offline      -       0
No Errors Logged
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
Selective Self-tests/Logging not supported
Disk da2 is gone so ill see if i can replace that with another drive and if that solves it. Unfortunelly this ESXI host runs my firewall/router and another few things that i need for day to day usage so not the most convenient thing to reboot.
Only 3 disks with no errors in SMART... that's possibly involved here.
I see Multi-zone and read errors.
da2 is certainly the worst impacted and I suspect may be the one stopping everything with timeouts... can you get it to run without that drive connected?
Grinas
Tried to shutdown Vm but it was stuck after 30+ mins so had to power it off in ESXI and then shut down host and removed that drive and replaced with a spare.
Seems new truenas vm is very slow to boot or wont boot like the other one as been waiting 20+ minutes for ssh and UI to respond.
these are the errors i get in truenas console in ESXI.
Looks like your boot pool is in trouble again...
