TrueNAS marks disk as FAULTED
Sonicmixmaster
So my TrueNAS server emails me the following:
New alerts:
* Pool TRUENAS50TB state is DEGRADED: One or more devices are faulted in response to persistent errors. Sufficient replicas exist for the pool to continue functioning in a degraded state.
The following devices are not healthy:
  • Disk ATA WDC WD140EDFZ-11 9LG37YSA is FAULTED
I follow the procedure to take disk offline and replace and now pool is resilvering with a brand new disk. On the other hand, the disk that was marked FAULTED I put back into the external enclosure it came in (WD EASYSTORE) and plug into my windows pc, partition and format it NTFS then do a surface scan and no errors show. Also S.M.A.R.T data shows no errors and the only thing different is that this disk has more usage hours on it than the new replacement.
2 questions:
Is the FAULTED disk that Windows shows with no errors in need of replacement.
Can the small pc board controller that comes with WD EASYSTORE external drives be hiding surface errors?
Below is CrystalDiskInfo 8.12.9 text output for the drive in question.
Thanks for any help on this.
CrystalDiskInfo 8.12.9 (C) 2008-2021 hiyohiyo
Crystal Dew World: https://crystalmark.info/
OS : Windows 10 Professional [10.0 Build 19044] (x64)
Date : 2022/07/22 12:47:31
-- Controller Map ----------------------------------------------------------
+ Standard SATA AHCI Controller [ATA]
- CT120BX500SSD1
- CT500MX500SSD1
- Generic IEEE 1667 Probe Silo
- Microsoft TCG Storage silo
- Generic IEEE 1667 ACT
- Samsung SSD 850 EVO 250GB
- Standard SATA AHCI Controller [ATA]
+ Samsung NVMe Controller [SCSI]
- Samsung SSD 980 PRO 2TB
- Microsoft Storage Spaces Controller [SCSI]
+ H+H Virtual CD 10 SCSI Controller [SCSI]
- RAID Virtual Device
- VXDV BD-HD-DVDROM S10 SCSI CdRom Device
-- Disk List ---------------------------------------------------------------
(01) CT120BX500SSD1 : 120.0 GB [0/1/0, pd1] - m2
(02) CT500MX500SSD1 : 500.1 GB [1/1/0, pd1] - m2
(03) Samsung SSD 850 EVO 250GB : 250.0 GB [2/1/0, pd1] - sg
(04) Samsung SSD 980 PRO 2TB : 2000.3 GB [3/2/0, sq] - nv
(05) WDC WD140EDFZ-11A0VA0 : 14000.5 GB [4/0/0, sa1]
(06) WDC WD40NMZW-11GX6S1 : 4000.7 GB [5/0/0, sa1]
Enclosure : WD easystore 264D USB Device (V=1058, P=264D, sa1)
Model : WDC WD140EDFZ-11A0VA0
Firmware : 81.00A81
Serial Number : 9LG37YSA
Disk Size : 14000.5 GB (8.4/137.4/14000.5/14000.5)
Buffer Size : Unknown
Queue Depth : 32
# of Sectors : 27344764928
Rotation Rate : 5400 RPM
Interface : USB (Serial ATA)
Major Version : ACS-2
Minor Version : ATA8-ACS version 4
Transfer Mode : SATA/600 | SATA/600
Power On Hours : 13783 hours
Power On Count : 104 count
Temperature : 41 C (105 F)
Health Status : Good
Features : S.M.A.R.T., APM, NCQ
APM Level : 00FEh [OFF]
AAM Level : ----
Drive Letter : E:
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
01 100 100 __1 000000000000 Read Error Rate
02 135 135 _54 00000000006C Throughput Performance
03 _81 _81 __1 000701840183 Spin-Up Time
04 100 100 __0 000000000069 Start/Stop Count
05 100 100 __1 000000000000 Reallocated Sectors Count
07 100 100 __1 000000000000 Seek Error Rate
08 133 133 _20 000000000012 Seek Time Performance
09 _99 _99 __0 0000000035D7 Power-On Hours
0A 100 100 __1 000000000000 Spin Retry Count
0C _99 _99 __0 000000000068 Power Cycle Count
16 100 100 _25 000000000064 Current Helium Level
C0 100 100 __0 0000000002A3 Power-off Retract Count
C1 100 100 __0 0000000002A3 Load/Unload Cycle Count
C2 _37 _37 __0 003600130029 Temperature
C4 100 100 __0 000000000000 Reallocation Event Count
C5 100 100 __0 000000000000 Current Pending Sector Count
C6 100 100 __0 000000000000 Uncorrectable Sector Count
C7 100 100 __0 000000000004 UltraDMA CRC Error Count
-- IDENTIFY_DEVICE ---------------------------------------------------------
0 1 2 3 4 5 6 7 8 9
000: 045A 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 394C 4733 3759 5341 2020 2020 2020 2020 2020 2020
020: 0003 0000 0038 3831 2E30 3041 3831 5744 4320 5744
030: 3134 3045 4446 5A2D 3131 4130 5641 3020 2020 2020
040: 2020 2020 2020 2020 2020 2020 2020 8010 4001 2F00
050: 4000 0200 0200 0007 3FFF 0010 003F FC10 00FB 7900
060: FFFF 0FFF 0000 0407 0003 0078 0078 0078 0078 0D18
070: 0000 0000 0000 0000 0000 001F 970E 0176 1CDE 0400
080: 03FC 0029 746B 7D69 4773 7469 BC41 4773 007F 826F
090: 8001 00FE FFFE 0000 0000 0008 00CA 00F9 2710 0000
100: 0000 5DE0 0006 0000 00CA 0000 6003 5A87 5000 CCA2
110: 8FC1 7AFE 0000 0000 0000 0000 0000 0000 0000 40DC
120: 409C 0000 0000 0000 0000 0000 0000 0000 0021 000B
130: 0000 0000 0000 0000 0000 0000 0000 0800 0000 0000
140: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
150: 0000 0009 5757 0000 0000 0000 0000 0000 0000 0000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0002 0000
170: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
190: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 003D 0000 0000 4000
210: 0000 0000 0000 0000 0000 0000 0000 1518 0000 0000
220: 0000 0000 10FF 0021 0000 0000 0000 0000 0000 0000
230: 0000 5DE0 0006 0000 0008 0000 0000 0000 0000 0000
240: 0000 0000 0000 4000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 7AA5
-- SMART_READ_DATA ---------------------------------------------------------
+0 +1 +2 +3 +4 +5 +6 +7 +8 +9 +A +B +C +D +E +F
000: 10 00 01 0B 00 64 64 00 00 00 00 00 00 00 02 04
010: 00 87 87 6C 00 00 00 00 00 00 03 07 00 51 51 83
020: 01 84 01 07 00 00 04 12 00 64 64 69 00 00 00 00
030: 00 00 05 33 00 64 64 00 00 00 00 00 00 00 07 0A
040: 00 64 64 00 00 00 00 00 00 00 08 04 00 85 85 12
050: 00 00 00 00 00 00 09 12 00 63 63 D7 35 00 00 00
060: 00 00 0A 12 00 64 64 00 00 00 00 00 00 00 0C 32
070: 00 63 63 68 00 00 00 00 00 00 16 23 00 64 64 64
080: 00 00 00 00 00 00 C0 32 00 64 64 A3 02 00 00 00
090: 00 00 C1 12 00 64 64 A3 02 00 00 00 00 00 C2 02
0A0: 00 25 25 29 00 13 00 36 00 00 C4 32 00 64 64 00
0B0: 00 00 00 00 00 00 C5 22 00 64 64 00 00 00 00 00
0C0: 00 00 C6 08 00 64 64 00 00 00 00 00 00 00 C7 0A
0D0: 00 64 64 04 00 00 00 00 00 00 00 00 00 00 00 00
0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 80 00 65 00 00 5B
170: 03 00 01 00 02 FF 00 83 05 00 00 00 00 00 00 00
180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 6A
-- SMART_READ_THRESHOLD ----------------------------------------------------
000: 10 00 01 01 00 00 00 00 00 00 00 00 00 00 02 36
010: 00 00 00 00 00 00 00 00 00 00 03 01 00 00 00 00
020: 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00
030: 00 00 05 01 00 00 00 00 00 00 00 00 00 00 07 01
040: 00 00 00 00 00 00 00 00 00 00 08 14 00 00 00 00
050: 00 00 00 00 00 00 09 00 00 00 00 00 00 00 00 00
060: 00 00 0A 01 00 00 00 00 00 00 00 00 00 00 0C 00
070: 00 00 00 00 00 00 00 00 00 00 16 19 00 00 00 00
080: 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00
090: 00 00 C1 00 00 00 00 00 00 00 00 00 00 00 C2 00
0A0: 00 00 00 00 00 00 00 00 00 00 C4 00 00 00 00 00
0B0: 00 00 00 00 00 00 C5 00 00 00 00 00 00 00 00 00
0C0: 00 00 C6 00 00 00 00 00 00 00 00 00 00 00 C7 00
0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 DC
Generally, using shucked consumer drives in a NAS is not recommended.
Can you install the faulted drive back in your TrueNAS and run a smartctl -t long test and post the smartctl -a output when it's complete?
Sonicmixmaster
Can I attach the drive and do the smartctl commands on another linux machine? I rather not disturb the TrueNAS pc anymore.
Sure. Your can install on Windows or Linux.
Use what ever flavor of Linux and install the packages or download the Windows client, although it best to connect to the SATA interface directly and not through a USB to SATA bridge as not all those are transparent or supported.
A lot of us here would disagree with you on that--presuming they're CMR drives.
The OPs drives appeared to be CMR. I understand the economics of the decision. I’ve used shucked Seagate drives in a former life. It all depends on how much risk you are willing to take with your data and whether you have a proven 3-2-1 strategy. The only thing an OEM warranty buys you is replacement cost. You never get any liability coverage for loss of data.
So there’s no real difference between a shucked drive and one sold bare, except warranty coverage. But at the current price delta, you could buy a couple of cold spares and still come out ahead.
Sonicmixmaster
Thanks elvisimprsntr for your info about the utility. I will give it a shot as soon as another scan I am doing is done. The scan I'm doing now is directly connected to sata cable in another computer. The scan should be done tomorrow.
To other people in this thread:
The drives I have are not SMR and they are basically slower 5400 rpm Hitachi Ultrastar datacenter drives like these https://www.westerndigital.com/prod...-center-drives/ultrastar-dc-hc560-hdd#0F38651 To me it doesnt matter as I have 6 drives in the pool and speed is not an issue for my setup.
Reddit has some more info on my drive here: https://www.reddit.com/r/DataHoarder/comments/elels8/wd_my_book_14_tb_shucked_wd140edfz_us7sap140/
Sonicmixmaster
The linux test is complete. If anyone sees this let me know. I think the drive is ok and only has UDMA errors which I have been told previously that they are not serious.
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.0-43-generic] (local build)
Device Model: WDC WD140EDFZ-11A0VA0
Serial Number: 9LG37YSA
LU WWN Device Id: 5 000cca 28fc17afe
Firmware Version: 81.00A81
User Capacity: 14,000,519,643,136 bytes [14.0 TB]
Rotation Rate: 5400 rpm
Form Factor: 3.5 inches
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Jul 25 12:19:04 2022 EDT
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 101) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: (1411) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000b 100 100 001 Pre-fail Always - 0
2 Throughput_Performance 0x0004 135 135 054 Old_age Offline - 108
3 Spin_Up_Time 0x0007 082 082 001 Pre-fail Always - 383 (Average 360)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 112
5 Reallocated_Sector_Ct 0x0033 100 100 001 Pre-fail Always - 0
7 Seek_Error_Rate 0x000a 100 100 001 Old_age Always - 0
8 Seek_Time_Performance 0x0004 133 133 020 Old_age Offline - 18
9 Power_On_Hours 0x0012 099 099 000 Old_age Always - 13838
10 Spin_Retry_Count 0x0012 100 100 001 Old_age Always - 0
12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 111
22 Unknown_Attribute 0x0023 100 100 025 Pre-fail Always - 100
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 684
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 684
194 Temperature_Celsius 0x0002 042 042 000 Old_age Always - 38 (Min/Max 19/54)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 100 100 000 Old_age Always - 4
SMART Error Log Version: 1
ATA Error Count: 4
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 4 occurred at disk power-on lifetime: 13768 hours (573 days + 16 hours)
ER ST SC SN CL CH DH
84 41 00 00 00 00 00 Error: ICRC, ABRT at LBA = 0x00000000 = 0
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
60 28 00 c0 d2 21 40 00 22:01:51.426 READ FPDMA QUEUED
2f 00 01 10 00 00 00 00 22:01:51.418 READ LOG EXT
2f 00 01 10 00 00 00 00 22:01:51.417 READ LOG EXT
60 28 00 c0 d2 21 40 00 22:01:51.410 READ FPDMA QUEUED
2f 00 01 10 00 00 00 00 22:01:51.409 READ LOG EXT
Error 3 occurred at disk power-on lifetime: 13768 hours (573 days + 16 hours)
60 28 00 c0 d2 21 40 00 22:01:51.417 READ FPDMA QUEUED
60 28 00 c0 d2 21 40 00 22:01:51.401 READ FPDMA QUEUED
2f 00 01 10 00 00 00 00 22:01:51.401 READ LOG EXT
Error 2 occurred at disk power-on lifetime: 13768 hours (573 days + 16 hours)
60 28 00 c0 d2 21 40 00 22:01:51.409 READ FPDMA QUEUED
60 28 00 c0 d2 21 40 00 22:01:51.386 READ FPDMA QUEUED
61 18 00 50 da 56 40 00 22:01:51.363 WRITE FPDMA QUEUED
61 08 00 e0 21 fd 40 00 22:01:51.363 WRITE FPDMA QUEUED
Error 1 occurred at disk power-on lifetime: 13768 hours (573 days + 16 hours)
61 20 00 68 a3 0e 40 00 22:01:51.363 WRITE FPDMA QUEUED
61 28 00 d0 84 eb 40 00 22:01:51.363 WRITE FPDMA QUEUED
# 1 Extended offline Completed without error 00% 13837 -
# 2 Extended offline Aborted by host 90% 13814 -
# 3 Extended offline Completed without error 00% 13810 -
# 4 Short offline Completed without error 00% 13788 -
# 5 Short offline Completed without error 00% 13657 -
# 6 Short offline Completed without error 00% 13652 -
# 7 Short offline Completed without error 00% 13489 -
# 8 Short offline Completed without error 00% 13484 -
# 9 Short offline Completed without error 00% 13321 -
#10 Short offline Completed without error 00% 13316 -
#11 Short offline Completed without error 00% 13154 -
#12 Short offline Completed without error 00% 13149 -
#13 Short offline Completed without error 00% 12985 -
#14 Short offline Completed without error 00% 12980 -
#15 Short offline Completed without error 00% 12817 -
#16 Short offline Completed without error 00% 12812 -
#17 Short offline Completed without error 00% 12649 -
#18 Short offline Completed without error 00% 12644 -
#19 Short offline Completed without error 00% 12481 -
#20 Short offline Completed without error 00% 12476 -
#21 Short offline Completed without error 00% 12314 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Those errors are for the first sector, so likely to mean communication loss between the disk and the controller (either the SATA/HBA and the disk or the disk controller and the hardware).
All 4 errors were at more-or-less the same time and were not long ago, so you should probably be looking into what may have caused that (cabling?).
Sonicmixmaster
I am doing another test now in Windows which will complete in 30 hours from now. I will look at the cables when it gets done. Meanwhile the server is back up and using my spare new drive for 2 days with no problems so far.
