TrueNAS does not see disks
ale9
[via Google Translate]
Hi all I have a problem with my Truenas correctly installed on an old pc with 2 hard disks but if I try to import the disks from the appropriate online interface it can't find them for me consequently I can't create any pool.
Can anyone help me?
[original post]
Salve a tutti ho un problema con il mio Truenas installato correttamente su un vecchio pc con 2 hardisck ma se cerco di importare i dichi dall'apposita interfaccia online non me li trova di conseguenza non riesco a creare nessun pool .
Qualcuno riesce ad aiutarmi?
Davvo
You don't have to import them but create a pool from 0.
In the forum you should use English, except in the Italian section.
[original post]
Non devi importarli ma creare una pool da 0.
Nel forum dovresti usare l'inglese, tranne nella sezione italiana.
ale9
I tried to create a pool but where I have to select the disks it doesn't give me any
[original post]
Non devi importarli ma creare una piscina da 0.
Ho provato a creare una pool ma la dove devo selezionare i dischi non me ne da
jgreco
Resident Grinch
Greetings -
Welcome to these forums.
Please note that the main forums are English language, and you are expected to post in English here. We have a section for International discussion that includes an Italian section, and you may post in Italian there. Supporting multiple languages in the main forums is untenable. If you do not speak English natively, please know that we're fine with machine-translated messages from services such as Google Translate. These don't always work well, but we will still definitely try to help you!
If you already have data on your disks that is not in ZFS format, you need some additional disks to create a pool and you may then import your data from your old disks onto your new pool. TrueNAS will not mount or use your old disks for serving files unless already in ZFS format. If you have EXT3 or NTFS filesystems, for example, you need to copy the data from these off the old disks into a new pool. This is what the import function does. Without a new pool, the import function has nowhere to put your old data in a ZFS format.
Saluti -
Benvenuti in questi forum.
Tieni presente che i forum principali sono in lingua inglese e che qui devi postare in inglese. Abbiamo una sezione per le discussioni internazionali che include una sezione italiana, e lì puoi postare in italiano. Il supporto di più lingue nei forum principali è insostenibile. Se non parli inglese in modo nativo, sappi che non ci sono problemi con i messaggi tradotti automaticamente da servizi come Google Translate. Questi non sempre funzionano bene, ma cercheremo comunque di aiutarti!
Se hai già dati sui tuoi dischi che non sono in formato ZFS, hai bisogno di alcuni dischi aggiuntivi per creare un pool e puoi quindi importare i tuoi dati dai tuoi vecchi dischi nel tuo nuovo pool. TrueNAS non monterà né utilizzerà i tuoi vecchi dischi per servire i file a meno che non siano già in formato ZFS. Se si dispone di file system EXT3 o NTFS, ad esempio, è necessario copiare i dati da questi dai vecchi dischi in un nuovo pool. Questo è ciò che fa la funzione di importazione. Senza un nuovo pool, la funzione di importazione non ha nessun posto dove inserire i tuoi vecchi dati in un formato ZFS.
ale9
Greetings -
[tramite Google Traduttore]
Saluti -
Cosa succede se formatto le mie unità? funzionerebbe?
jgreco
Resident Grinch
