TrueNAS Core-VM on Proxmox - The following system core files were found: python3.9.core
BensonHo
Version:
TrueNAS-13.0-U4
I got Warning :
The following system core files were found: python3.9.core. Please create a ticket at https://ixsystems.atlassian.net/ and attach the relevant core files along with a system debug. Once the core files have been archived and attached to the ticket, they may be removed by running the following command in shell: 'rm /var/db/system/cores/*'.​
I dont know what is this and hwo to settle this isuus , i found that my truenas core couldn't login by Web UI after runing a period of time , i need to reboot this truenas core VM and get the UI login again 。
BensonHo
Yes . SSH and Got the below error message :
Welcome to TrueNAS
File "/usr/local/sbin/hactl", line 171, in <module>
main(args.command, args.q)
File "/usr/local/sbin/hactl", line 17, in main
client = Client()
File "/usr/local/lib/python3.9/site-packages/middlewared/client/client.py", line 286, in __init__
self._ws.connect()
File "/usr/local/lib/python3.9/site-packages/middlewared/client/client.py", line 124, in connect
rv = super(WSClient, self).connect()
File "/usr/local/lib/python3.9/site-packages/ws4py/client/__init__.py", line 216, in connect
self.sock.connect(self.bind_addr)
ConnectionRefusedError: [Errno 61] Connection refused
Warning: the supported mechanisms for making configuration changes
are the TrueNAS WebUI and API exclusively. ALL OTHERS ARE
NOT SUPPORTED AND WILL RESULT IN UNDEFINED BEHAVIOR AND MAY
RESULT IN SYSTEM FAILURE.
uname -a
FreeBSD truenas.local 13.1-RELEASE-p7 FreeBSD 13.1-RELEASE-p7 n245418-79e75956dbb TRUENAS amd64
ps axuww
Looks like a python process crashed.
I could login on the web UI again when i run service middlewared restart in CLI and the GUI came back, but after a period of time, the fault will reappear
I don't know how to settle this problem
  • truenas-log.txt
chruk
Connection refused, not sure why that triggered a core dump but looks like there is connectivity issues, perhaps related to a firewall.
