DevilNAS
- Feb 5, 2022
Hello everyone,
Have been two days searching for a solution to this issue but I am not able to activate the hardware transcode on TrueNAS 12.0-U8.
I have made several tries but always without success.
The problem is that after I try to watch a movie that need transcode stay buffering for ever and sometimes reply with error s1003 (Network). The PLex Logs have nothing useful for this problem.
Direct Play works well and sound transcode too. The Video transcode is the problem because needs the hardware. If I deactivate the hardware transcode, everything works great until CPU reach 100% usage.
CPU: Intel i3-9100 with iGPU
First try:
Followed the @dak180 post https://www.truenas.com/community/threads/activating-plex-hardware-acceleration.75391/post-525442
Second try:
Used the https://github.com/danb35/freenas-iocage-plex (which didn't configured hardware transcode because is only compatible with TrueNAS 11 and 12 )
Third try:
And also https://github.com/kern2011/Freenas-Quicksync
Fourth try:
Installed the plugin or Plex Media Server from shell.
After that followed:
The problem is always the same with every try.
Anyone had the same problem that I am having now? How did you solved this issue?
First try:
Second try:
Third try:
Fourth try:
@@@ INTEL GPU OFFLOAD NOTES @@@ If you have a supported Intel GPU, you can leverage hardware accelerated encoding/decoding in Plex Media Server on FreeBSD 12.0+. The requirements are as follows: * Install multimedia/drm-kmod: e.g., pkg install drm-fbsd12.0-kmod * Enable loading of kernel module on boot: sysrc kld_list+="i915kms" ** If Plex will run in a jail, you must load the module outside the jail! * Load the kernel module now (although reboot is advised): kldload i915kms * Add plex user to the video group: pw groupmod -n video -m plex * For jails, make a devfs ruleset to expose /dev/dri/* devices. e.g., /dev/devfs.rules on the host: [plex_drm=10] add include $devfsrules_hide_all add include $devfsrules_unhide_basic add include $devfsrules_unhide_login add include $devfsrules_jail add path 'dri*' unhide add path 'dri/*' unhide add path 'drm*' unhide add path 'drm/*' unhide * Enable the devfs ruleset for your jail. e.g., devfs_ruleset=10 in your /etc/jail.conf or for iocage, iocage set devfs_ruleset="10" Please refer to documentation for all other FreeBSD jail management utilities. * Make sure hardware transcoding is enabled in the server settings @@@ INTEL GPU OFFLOAD NOTES @@@
