brandon.arnold
- Aug 6, 2022
I'm building TrueNAS CORE according to the procedure in truenas/core-build. I have the same results whether I build within a FreeBSD 12.3 VM or the TrueNAS clone jail.
The `make release` step errors out with the output below. Looking at the log at `/usr/build/freenas/_BE/objs/logs/buildworld`, I believe the error is `Malformed conditional (${.SHELL:T} == "ksh")`. It seems to correspond with this line of a Makefile in truenas/os.
What's going on?
Output from `make release`:
What's going on?
root@truenasbuild:/usr/build # make release [0:00:00] ==> NOTICE: Selected profile: freenas [0:00:00] ==> NOTICE: Build timestamp: 202208070644 [0:00:00] ==> Checking build environment... [0:00:00] ==> Build environment is OK [0:00:00] ==> Sandbox is fully checked out Doing executing target release on host: truenasbuild Build directory: /usr/build [0:00:01] ==> Building world from /usr/build/freenas/_BE/os [0:00:01] ==> Log file: /usr/build/freenas/_BE/objs/logs/buildworld [0:00:23] ==> Failed command: env -u DEBUG -u MAKEFLAGS MAKEOBJDIRPREFIX=/usr/build/freenas/_BE/objs make -j 5 -C /usr/build/freenas/_BE/os __MAKE_CONF=/usr/build/freenas/_BE/objs/make-build.conf NOCLEAN=YES buildworld [0:00:23] ==> Returned value: 2 [0:00:23] ==> ERROR: Build failed *** Error code 1 Stop. make[2]: stopped in /usr/build *** Error code 1 Stop. make[1]: stopped in /usr/build *** Error code 1 Stop. make: stopped in /usr/build
