VulcanRidr
- Jan 5, 2015
I'm posting this in the Core forum because that is what I'm running, however it likely applies to Scale as well. I have multiple TrueNAS' at work, and sometime since the release of 13.0u5.3, I am no longer able to get to update-master.ixsystems.com, either in the gui or in the command line. According to the command line, it is because of our cisco umbrella setup. When I try to wget the trains.txt file from update-master, I get
I uploaded a copy of the umbrella certificate to system -> CAs, but I am still unable to reach the site from the GUI or wget. Is there some other place that this cert needs to be uploaded? I wanted to ask, since I remember the adage about not "doing things on the command line behind the gui's back"...
ERROR: cannot verify update-master.ixsystems.com's certificate, issued by ‘CN=Cisco Umbrella Secondary SubCA nyc-SG,O=Cisco’: Unable to locally verify the issuer's authority. To connect to update-master.ixsystems.com insecurely, use `--no-check-certificate'.
