baseman
- Sep 13, 2023
Hello all.
Since two weeks ago I've been getting this weird error whenever the TrueNAS app catalog tries to refresh/update itself. I get the same error whenever I run it manually as well. The error message itself is the following:
Has anyone else encountered this and know what to do? I couldn't find anything on this exact error in the forums.
Here is what I found in the log files:
Failed to sync TRUENAS catalog: [ENOENT] Unable to retrieve feature capability mapping for SCALE versions
[2023/09/13 12:43:20] (ERROR) middlewared.job.run():440 - Job <bound method accepts.<locals>.wrap.<locals>.nf of <middlewared.plugins.catalogs_linux.items.CatalogService object at 0x7f20f0fa77c0>> failed
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 428, in run
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 465, in __run_body
rv = await self.middleware.run_in_thread(self.method, *([self] + args))
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1261, in run_in_thread
return await self.run_in_executor(self.thread_pool_executor, method, *args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1258, in run_in_executor
File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1382, in nf
return func(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/catalogs_linux/items.py", line 135, in items_internal
self.middleware.call_sync('catalog.get_feature_map', False)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1425, in call_sync
return methodobj(*prepared_call.args)
File "/usr/lib/python3/dist-packages/middlewared/plugins/catalogs_linux/features.py", line 24, in get_feature_map
raise CallError('Unable to retrieve feature capability mapping for SCALE versions', errno=errno.ENOENT)
middlewared.service_exception.CallError: [ENOENT] Unable to retrieve feature capability mapping for SCALE versions
[2023/09/13 12:43:20] (ERROR) middlewared.job.run():440 - Job <bound method accepts.<locals>.wrap.<locals>.nf of <middlewared.plugins.catalogs_linux.sync_catalogs.CatalogService object at 0x7f20f0fa76a0>> failed
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 463, in __run_body
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1378, in nf
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1246, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/catalogs_linux/sync_catalogs.py", line 44, in sync
await item_job.wait(raise_error=True)
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 376, in wait
raise self.exc_info[1]
await self.future
