TrueNAS build hardware suggestions.
simtcr
Hello All,
My requirement - A NAS with Gigabit speed copying and reading. Will mostly run up to 4 HDDs. (I plan to add disks as and when they get filled up). Main thing goes inside these are 4K, BluRay Movies., Which I will play via Kodi on Android TV.
For above requirement, is Intel Core i3-10100F (4 core) and 8GB DDR4 memory good enough?
I tried to find ITX board and cabinet and they are super expensive. So is it good idea to pair the i3 with ASUS Prime H510M-E Micro ATX mobo?
Is cheap 400 watt SMPS ok to drive everything?
Thanks.
simtcr
Supermicro mainboards and Jonsbo N1 is not available where I live (Need to be imported and its a hassle)
I also found that, the CPU I listed dont have integrated graphics. So now I am thinking of
Intel Pentium Gold G6405 10th Gen (2 cores)
Also how about running on this on Ryzen 3200G?
Note: I read that ECC memory is preferred, but that seems to be either expensive and not available.
That is why I want to check if its doable with desktop grade cpu, hence it can be cheap.
