onthax
- Jan 31, 2012
Having an issue reinstalling radarr in 13U3
it gets to 75% then just hangs there.
jail is built, but no radarr
/var/log/message within the jail shows
within the iocage console log for the jail
Wed Jan 25 08:52:28 AEST 2023
have tried several different network configs, static etc.
Can't see anything in the logs of it actually trying to install radarr
can resolve and ping from the jail outbound which works fine.
pkg update works fine.
Any ideas?
Jan 25 08:52:28 radarr newsyslog[25704]: logfile first created Jan 25 08:52:28 radarr syslogd: kernel boot file is /boot/kernel/kernel Jan 25 08:52:28 radarr dhclient[25529]: receive_packet failed on epair0b: Device not configured Jan 25 08:52:28 radarr dhclient[25529]: ioctl(SIOCGIFFLAGS) on epair0b: Operation not permitted Jan 25 08:52:28 radarr dhclient[25529]: Interface epair0b no longer appears valid. Jan 25 08:52:28 radarr dhclient[25529]: No live interfaces to poll on - exiting. Jan 25 08:52:28 radarr dhclient[25529]: exiting. Jan 25 08:52:28 radarr dhclient[25529]: connection closed Jan 25 08:52:28 radarr dhclient[25529]: exiting. Jan 25 08:52:28 radarr syslogd: exiting on signal 15 Jan 25 08:52:32 radarr syslogd: kernel boot file is /boot/kernel/kernel Jan 25 08:52:42 radarr pkg-static[26426]: pkg-1.19.0 installed Jan 25 08:52:47 radarr pkg-static[26445]: pkg reinstalled: 1.19.0 -> 1.19.0
ELF ldconfig path: /lib /usr/lib /usr/lib/compat
32-bit compatibility ldconfig path: /usr/lib32
Starting dhclient.
Starting dhclient.
Starting dhclient.
Starting dhclient.
Starting dhclient.
Starting dhclient.
Starting Network: lo0 epair0b.
options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
groups: lo
epair0b: flags=8863<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 3e:ec:ef:c1:df:cb
hwaddr 02:9f:25:bf:a9:0b
inet 192.168.52.1 netmask 0xffffff00 broadcast 192.168.52.255
groups: epair
status: active
nd6 options=1<PERFORMNUD>
add host 127.0.0.1: gateway lo0 fib 0: route already in table
add host ::1: gateway lo0 fib 0: route already in table
add net fe80::: gateway ::1
add net ff02::: gateway ::1
add net ::ffff:0.0.0.0: gateway ::1
add net ::0.0.0.0: gateway ::1
Clearing /tmp (X related).
Creating and/or trimming log files.
Updating motd:.
Updating /var/run/os-release done.
Starting syslogd.
Starting cron.
Any ideas?
