TrueNAS 13.0-U2 is now available
mav@
This one is for 13.1 which didn't have an issue with Proxmox... What's the benefit ?
13.1 now uses exactly the same OS branch as 13.0, just not tied to releases, so if there was no issue on 13.1, then you just got a lucky build.
OK, the panic happened in core_pcpu_init() when trying to load the kernel CPU initialization routine. Typically a problem here is due to the hypervisor reporting the wrong number of cores to TrueNAS. How many cores have you allocated to TrueNAS in ProxMox? How many physical cores do you have in your Ryzen CPU?
Hi Samul,
maybe I have the same isse.
I tryed to move my Truenas 12 to 13 and this is the screen of painc error.
The installation is on Proxmox 7.2-4 and VM are configured with CPU 8 core - 1 socket.
Do you think is better to move with another CPU layout?
Thanks for the help.
this is my screedshot:
