puppabriggy
 - Sep 25, 2022
New to Truenas. I'm runing 13.0 core on a i3 (specs in my signature). Although I'm connected to a gigabit network my smb traffic is limited to ±113Mbs. I've run a few tests based on other threads. this is below. This seems to be limited to my SMB service.  Out of paranoia I switched out my switch but that wasn't the problem. Any point in the right direction will be greatly appreciated.
TrueNAS-13.0-U2 Model: MS-7D16 Memory:16 GiB
Case: KCMconmey 4 + 1 Bay DIY NAS Case, 4 x 2.5/3.5 Tray + 1 x 2.5 Internal Bay. (possible backplane issues)
MB: MSI H510I PRO WiFi ProSeries Motherboard (Mini-ITX, 11th/10th Gen Intel Core
CPU: intel Core i3 (10th Gen) i3-10105 Quad-core (4 Core) 3.70 GHz Processor
RAM: Silicon Power Value Gaming DDR4 RAM 16GB (8GBx2) 3200MHz
SSD: Crucial P3 500GB PCIe 3.0 3D NAND NVMe M.2 SSD, up to 3500MB/s - CT500P3SSD8
RAIDZ: 3X Western Digital 3TB WD Red Plus NAS Internal Hard Drive HDD - 5400 RPM, SATA 6 Gb/s, CMR, 128 MB Cache, 3.5" -WD30EFZX
Iperf Server: Win10, Client: Truenas 13.0
I've made the following modificatios to the SMB service settings based on forum searching.
Using the OpenSpeedTest plugin my upload and download speeds are ±987Mbps
using dd to test the pool shows the follwing if I'm reading this right I'm showing at least 3.8GBs.
Iperf Server: Truenas 13.0 Client: Widnows 10-----------------------------------------------------------
Server listening on 5201
Accepted connection from 192.168.1.12, port 52870
[ 5] local 192.168.1.128 port 5201 connected to 192.168.1.12 port 47322
[ ID] Interval Transfer Bandwidth
[ 5] 0.00-1.00 sec 109 MBytes 916 Mbits/sec
[ 5] 1.00-2.00 sec 113 MBytes 949 Mbits/sec
[ 5] 2.00-3.00 sec 113 MBytes 949 Mbits/sec
[ 5] 3.00-4.00 sec 113 MBytes 949 Mbits/sec
[ 5] 4.00-5.00 sec 113 MBytes 949 Mbits/sec
[ 5] 5.00-6.00 sec 113 MBytes 949 Mbits/sec
[ 5] 6.00-7.00 sec 113 MBytes 949 Mbits/sec
[ 5] 7.00-8.00 sec 113 MBytes 949 Mbits/sec
[ 5] 8.00-9.00 sec 113 MBytes 949 Mbits/sec
[ 5] 9.00-10.00 sec 113 MBytes 949 Mbits/sec
[ 5] 10.00-10.04 sec 4.05 MBytes 935 Mbits/sec
[ 5] 0.00-10.04 sec 0.00 Bytes 0.00 bits/sec sender
[ 5] 0.00-10.04 sec 1.10 GBytes 945 Mbits/sec receiver
iperf3: interrupt - the server has terminated
Server listening on 5201 (test #1)
Accepted connection from 192.168.1.128, port 62676
[ 5] local 192.168.1.12 port 5201 connected to 192.168.1.128 port 62677
[ ID] Interval Transfer Bitrate
[ 5] 0.00-1.00 sec 111 MBytes 928 Mbits/sec
[ 5] 1.00-2.00 sec 111 MBytes 933 Mbits/sec
[ 5] 2.00-3.00 sec 111 MBytes 934 Mbits/sec
[ 5] 3.00-4.00 sec 112 MBytes 936 Mbits/sec
[ 5] 4.00-5.00 sec 111 MBytes 935 Mbits/sec
[ 5] 5.00-6.00 sec 111 MBytes 930 Mbits/sec
[ 5] 6.00-7.00 sec 112 MBytes 938 Mbits/sec
[ 5] 7.00-8.00 sec 112 MBytes 939 Mbits/sec
[ 5] 8.00-9.00 sec 112 MBytes 938 Mbits/sec
[ 5] 9.00-10.00 sec 111 MBytes 930 Mbits/sec
[ 5] 10.00-10.01 sec 913 KBytes 915 Mbits/sec
[ 5] 0.00-10.01 sec 1.09 GBytes 934 Mbits/sec receiver
Server listening on 5201 (test #2)
server multi channel support = yes
interfaces = "192.168.1.12;capability=RSS,speed=1000000000"
root@truenas[~]# dd if=/dev/zero of=/mnt/NAS_pool_1/backup/dd_test_report2022092
5.dat bs=1024k count=20000
20000+0 records in
20000+0 records out
20971520000 bytes transferred in 5.430061 secs (3862114947 bytes/sec)
