TrueNAS 12 Certificate Import Problem
frankwayne
I have today's image of TrueNAS 12.0 (MASTER-202006020424) running on hardware and on Hyper-V and I can't import a certificate on either. I tried importing both an external certificate with key and an external CA certificate, but I get a generic "Error" popup with an empty error message. If I open "More info...", I get a Python call stack that ends with "OpenSSL.crypto.Error: []". I've gone back to a couple of earlier releases of 12.0 and see the same error.
If I install FreeNAS 11.3 on the same VM that 12.0 is running on and try the same certificates, they import with no problems.
Is this a known issue? (I couldn't find a reference to it.) Has anyone else been able to import an external certificate in 12.0?
waqarahmed
Thank you @frankwayne for letting us know about it. Can you please create a ticket a ticket at https://jira.ixsystems.com and kindly make sure to attach a debug. Also please share the public key of the certificate as well. Looking forward to hearing from you. Thanks again
