vnet0:bridge10,vnet1:bridge20,vnet2:bridge30 in the "interfaces" config of your jail.
root@truenas[~]# iocage start cups No default gateway found for ipv6. * Starting cups + Started OK + Using devfs_ruleset: 1000 (iocage generated default) + Configuring VNET FAILED route: writing to routing socket: Network is unreachable add net default: gateway 10.0.0.1 fib 0: Network is unreachable Stopped cups due to VNET failure
iocage get all cups, please.I hope I won't look dumb again by overlooking something. I believe the switch is configured correctly as all other vlan clients are working correctly. Only the TrueNAS bce1 seems to be non-working. Unfortunately, I don't have a laptop to connect to this port with vlan activated on it's NIC and ping pfSense.iocage get all cups, please.
root@truenas[~]# iocage get all cups CONFIG_VERSION:28 allow_chflags:0 allow_mlock:0 allow_mount:0 allow_mount_devfs:0 allow_mount_fusefs:0 allow_mount_nullfs:0 allow_mount_procfs:0 allow_mount_tmpfs:0 allow_mount_zfs:0 allow_quotas:0 allow_raw_sockets:1 allow_set_hostname:1 allow_socket_af:0 allow_sysvipc:0 allow_tun:0 allow_vmm:0 assign_localhost:0 available:readonly basejail:0 boot:0 bpf:1 children_max:0 cloned_release:12.2-RELEASE comment:none compression:lz4 compressratio:readonly coredumpsize:off count:1 cpuset:off cputime:off datasize:off dedup:off defaultrouter:auto # I tried with 10.0.0.1 which is the default router, no more success defaultrouter6:none depends:none devfs_ruleset:4 dhcp:0 enforce_statfs:2 exec_clean:1 exec_created:/usr/bin/true exec_fib:0 exec_jail_user:root exec_poststart:/usr/bin/true exec_poststop:/usr/bin/true exec_prestart:/usr/bin/true exec_prestop:/usr/bin/true exec_start:/bin/sh /etc/rc exec_stop:/bin/sh /etc/rc.shutdown exec_system_jail_user:0 exec_system_user:root exec_timeout:60 host_domainname:none host_hostname:cups host_hostuuid:cups host_time:1 hostid:4c4c4544-004b-5a10-8058-b2c04f4e4e31 hostid_strict_check:0 interfaces:vnet0:bridge20 ip4:new ip4_addr:10.0.20.5/24 ip4_saddrsel:1 ip6:new ip6_addr:none ip6_saddrsel:1 ip_hostname:0 jail_zfs:0 jail_zfs_dataset:iocage/jails/cups/data jail_zfs_mountpoint:none last_started:none localhost_ip:none login_flags:-f root mac_prefix:862b2b maxproc:off memorylocked:off memoryuse:off min_dyn_devfs_ruleset:1000 mount_devfs:1 mount_fdescfs:1 mount_linprocfs:0 mount_procfs:0 mountpoint:readonly msgqqueued:off msgqsize:off nat:0 nat_backend:ipfw nat_forwards:none nat_interface:none nat_prefix:172.16 nmsgq:off notes:none nsem:off nsemop:off nshm:off nthr:off openfiles:off origin:readonly owner:root pcpu:off plugin_name:none plugin_repository:none priority:99 pseudoterminals:off quota:none readbps:off readiops:off release:12.2-RELEASE reservation:none resolver:/etc/resolv.conf rlimits:off rtsold:0 securelevel:2 shmsize:off stacksize:off state:down stop_timeout:30 swapuse:off sync_state:none sync_target:none sync_tgt_zpool:none sysvmsg:new sysvsem:new sysvshm:new template:0 type:jail used:readonly vmemoryuse:off vnet:1 vnet0_mac:862b2bbd67e5 862b2bbd67e6 # There is 2 MACs, strange vnet0_mtu:auto vnet1_mac:none vnet1_mtu:auto vnet2_mac:none vnet2_mtu:auto vnet3_mac:none vnet3_mtu:auto vnet_default_interface:none vnet_default_mtu:1500 vnet_interfaces:none wallclock:off writebps:off writeiops:off
root@truenas[~]# pciconf -lv | grep -A1 -B3 network
bce0@pci0:1:0:0: class=0x020000 card=0x02371028 chip=0x163914e4 rev=0x20 hdr=0x00
vendor = 'Broadcom Inc. and subsidiaries'
device = 'NetXtreme II BCM5709 Gigabit Ethernet'
class = network
subclass = ethernet
bce1@pci0:1:0:1: class=0x020000 card=0x02371028 chip=0x163914e4 rev=0x20 hdr=0x00
class = network
subclass = ethernet
defaultrouter:auto # I tried with 10.0.0.1 which is the default router, no more success [...] ip4_addr:10.0.20.5/24
Is there anything missing in my pfSense rules ?Code:defaultrouter:auto # I tried with 10.0.0.1 which is the default router, no more success [...] ip4_addr:10.0.20.5/24
The defaultrouter must be in the 10.0.20.0/24 network - that's why the jail does not start. I assume the jail is supposed to be accessed from hosts in other networks and be able to reach the internet (to install packages and updates, at least)? Then you need something in that VLAN that is a router. Either your layer3 switch (if it is layer3 capable), a separate firewall, or as a last resort your TrueNAS host.
I can help with setting up the TrueNAS host as a router if necessary but I would not recommend it.
I'll ask a friend, good with networking to check this and go the TrueNAS=host as a last resort.I can help with setting up the TrueNAS host as a router if necessary but I would not recommend it.
That's what was missing. I'd love to buy you a beerAnd in the "resolver" field you put the string "nameserver <same-ip-address-as-defaultrouter>" and I am confident your jail will start.
So I have transfered the Emby server form native lan to vlan10 (sorry, not 30).Sort of. Interfaces and jail - yes. But you use the emby application (whatever that is) at the emby address in vlan 30. So your pfsense needs to route between your desktop and the emby jail. And if you want to do filesharing in addition to whatever emby does, this is done from the host because file sharing is builtin into TrueNAS. So you mount a dataset that is outside of the emby jail (create in Storage > Pools) e.g./mnt/<yourpool>/shares/embyinto the jail at some convenient location e.g./var/emby.
If you want the file sharing address to be in vlan 30, too, then your host does need an IP address there. So give the host an address for the bridge30 interface, not the vlan30 one.
jail=embyIP=10.0.10.20IP=10.0.10.2I am glad you asked because I did not want to hijack this thread.you have a working network. You change things around that break the network. Why?
This is what I am trying to achieve. Emby server (serving movies) is now in vlan10 along with the TVboxes taht are pulling said movies.Well for one I would deem it reasonable to keep this emby thing in the same VLAN as the clients accessing it.
Is it not the goal of an emby jail in vlan10? I am not sure how it is different from your previous sentence ?What I would do in this case is move the web interface of the TrueNAS and possibly the SMB share, too, to a more isolated zone/VLAN.
I could do that since the jail itself is just 2 GiB while the movies account for 500 GiB.And then mount the meticulously ripped media into the emby jail read-only.
I am a member of pfSense forum and ask questions there as well. And I have a friend that can help me with some networking. The thing is, books and FAQs tell you how to make each specific thing work but they rarely tell you which way to not make things you'll regret when needs grow.And you will probably need to educate yourself about pfSense.
The default router is at 10.0.10.1.What's your defaultrouter setting for the emby jail? Is it the IP address of your pfsense?
I thought that since jails have their own network stack, the embyjail would be able to access the movie dataset though this stack and ACL.The rest is up to your pfsense ruleset.
I understood your last problem that you moved emby into VLAN 10 and then video playback stopped working? So there is at least one client not in VLAN 10 that needs to access emby?Is it not the goal of an emby jail in vlan10? I am not sure how it is different from your previous sentence ?
Yes, correct. Your data goes in regular TrueNAS datasets outside of iocage. These can then be mounted into the jails, read-write or read-only as desired.But I was under the impression that it is best practice to keep the jails for the "systems" and the datasets (not in iocage) for data...
The movie dataset resides on the TrueNAS that also hosts the emby jail, right? In that case the mounts do not use the network at all. They are configured at "Jails > jailname > Mount Points" in the UI. These are strict local Unix mounts, no sharing protocol involved.I thought that since jails have their own network stack, the embyjail would be able to access the movie dataset though this stack and ACL.
Physical --> LAGG (if present) --> VLAN --> Bridge
