Basically you shouldn't be running TC on one of the Scale devices in the cluster. If you get issues with the host then management vanishes with the host. No preferred OS / method. It should just not be on one of the Scale Cluster hosts
However having said that - in a steady state it should work.
[As a caveat for my next bit - I don't do things the way that TrueCharts reccomend, and I am not a docker / container expert. I also don't use any IX containers. I do have Truecommand, but its on a portainer host elsewhere. Also I acknowledge the warning about "choose anything other than PVC could break rollback". I don't use rollback cos I don't understand how the permanent storage works with it. I may have gone down the wrong rabbit hole - which I am now stuck with for the moment]
I have a /mnt/"pool_name"/docker dataset with a truecommand dataset under that. apps owns the whole thing - create this please
Under Storage & Persistence, under App Config Storage set a "host path (simple)" and point it to the truecommand dataset you created earlier. This should put the config files in a permanent location.
Test this - if it works on a reboot / restart of the container it shows you where your problem lies.
You could then try PVC (without the simple) - you will have to set TC up again - that might be permanent I don't know
