MrBucket101
 - Jul 9, 2018
I've got a raspberry pi cluster running k3s, that I run various services on. It's not uncommon to run into images that weren't built for ARM. I'll usually build the image myself or submit a PR to add multi-arch support to their build system.
Usually, its as simple as installing docker-buildx, and adding --platform=linux/arm64, linux/amd64 to the build command
Unfortunately, I couldn't find the Dockerfile for TrueCommand, and furthermore, the setup scripts provided, install docker and pull the ixsystems/truecommand image
With no way of knowing how to manually install TrueCommand, I can't create my own image, and without access to the TrueCommand Dockerfile, I also can't build an ARM64 image either.
Is it possible to request an ARM64 build of Truecommand?
