looks a bit better after i created a user docker, see log.
But it seems to ignore the yaml file and in the end the container is shut down.
I added a new directory in via the gui like the comment in your youtube video mentions - doesnt solve the problem:
Andrew Kelsey
There have been some changes to how this needs to be done. The 3rd entry under volumes needs to point to a path inside the container.
In the configuration for the app under Storage and Persistence, click add, choose Host Path for type, enter the dataset path to where your yaml file is, then in Mouth Path, enter the location inside the container (make it up). This will mount the Host Path location to the Mouth Path location in the container.
That 3rd entry under volumes in the yaml will not be your Host Path.
2023-01-21 23:30:29.075668+00:00docker not running yet. Waiting...
2023-01-21 23:30:30.833747+00:00Certificate request self-signature ok
2023-01-21 23:30:30.833824+00:00subject=CN = docker:dind server
2023-01-21 23:30:30.856997+00:00/certs/server/cert.pem: OK
2023-01-21 23:30:30.914429+00:00Certificate request self-signature ok
2023-01-21 23:30:30.914465+00:00subject=CN = docker:dind client
2023-01-21 23:30:30.930842+00:00/certs/client/cert.pem: OK
2023-01-21 23:30:31.067639+00:00time="2023-01-21T23:30:31.067481837Z" level=info msg="Starting up"
2023-01-21 23:30:31.069300+00:00time="2023-01-21T23:30:31.069238544Z" level=warning msg="could not change group /var/run/docker.sock to docker: group docker not found"
2023-01-21 23:30:31.070945+00:00time="2023-01-21T23:30:31.070881358Z" level=info msg="libcontainerd: started new containerd process" pid=108
2023-01-21 23:30:31.071042+00:00time="2023-01-21T23:30:31.071001010Z" level=info msg="parsed scheme: \"unix\"" module=grpc
2023-01-21 23:30:31.071057+00:00time="2023-01-21T23:30:31.071011886Z" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
2023-01-21 23:30:31.071079+00:00time="2023-01-21T23:30:31.071052485Z" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///var/run/docker/containerd/containerd.sock <nil> 0 <nil>}] <nil> <nil>}" module=grpc
2023-01-21 23:30:31.071095+00:00time="2023-01-21T23:30:31.071075963Z" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
2023-01-21 23:30:31.113084+00:00time="2023-01-21T23:30:31Z" level=warning msg="containerd config version `1` has been deprecated and will be removed in containerd v2.0, please switch to version `2`, see https://github.com/containerd/containerd/blob/main/docs/PLUGINS.md#version-header"
2023-01-21 23:30:31.113580+00:00time="2023-01-21T23:30:31.113525384Z" level=info msg="starting containerd" revision=78f51771157abb6c9ed224c22013cdf09962315d version=v1.6.13
2023-01-21 23:30:31.124338+00:00time="2023-01-21T23:30:31.124282283Z" level=info msg="loading plugin \"io.containerd.content.v1.content\"..." type=io.containerd.content.v1
2023-01-21 23:30:31.124384+00:00time="2023-01-21T23:30:31.124349157Z" level=info msg="loading plugin \"io.containerd.snapshotter.v1.aufs\"..." type=io.containerd.snapshotter.v1
2023-01-21 23:30:31.167133+00:00time="2023-01-21T23:30:31.167055821Z" level=info msg="skip loading plugin \"io.containerd.snapshotter.v1.aufs\"..." error="aufs is not supported (modprobe aufs failed: exit status 1 \"ip: can't find device 'aufs'\\nmodprobe: can't change directory to '/lib/modules': No such file or directory\\n\"): skip plugin" type=io.containerd.snapshotter.v1
2023-01-21 23:30:31.167157+00:00time="2023-01-21T23:30:31.167085465Z" level=info msg="loading plugin \"io.containerd.snapshotter.v1.btrfs\"..." type=io.containerd.snapshotter.v1
2023-01-21 23:30:31.167316+00:00time="2023-01-21T23:30:31.167268406Z" level=info msg="skip loading plugin \"io.containerd.snapshotter.v1.btrfs\"..." error="path /var/lib/docker/containerd/daemon/io.containerd.snapshotter.v1.btrfs (zfs) must be a btrfs filesystem to be used with the btrfs snapshotter: skip plugin" type=io.containerd.snapshotter.v1
2023-01-21 23:30:31.167338+00:00time="2023-01-21T23:30:31.167282102Z" level=info msg="loading plugin \"io.containerd.snapshotter.v1.devmapper\"..." type=io.containerd.snapshotter.v1
2023-01-21 23:30:31.167344+00:00time="2023-01-21T23:30:31.167292458Z" level=warning msg="failed to load plugin io.containerd.snapshotter.v1.devmapper" error="devmapper not configured"
2023-01-21 23:30:31.167355+00:00time="2023-01-21T23:30:31.167300126Z" level=info msg="loading plugin \"io.containerd.snapshotter.v1.native\"..." type=io.containerd.snapshotter.v1
2023-01-21 23:30:31.167367+00:00time="2023-01-21T23:30:31.167333173Z" level=info msg="loading plugin \"io.containerd.snapshotter.v1.overlayfs\"..." type=io.containerd.snapshotter.v1
2023-01-21 23:30:31.167770+00:00time="2023-01-21T23:30:31.167726139Z" level=info msg="loading plugin \"io.containerd.snapshotter.v1.zfs\"..." type=io.containerd.snapshotter.v1
2023-01-21 23:30:31.174993+00:00time="2023-01-21T23:30:31.174934870Z" level=info msg="loading plugin \"io.containerd.metadata.v1.bolt\"..." type=io.containerd.metadata.v1
2023-01-21 23:30:31.175022+00:00time="2023-01-21T23:30:31.174977241Z" level=warning msg="could not use snapshotter devmapper in metadata plugin" error="devmapper not configured"
2023-01-21 23:30:31.175036+00:00time="2023-01-21T23:30:31.174997739Z" level=info msg="metadata content store policy set" policy=shared
2023-01-21 23:30:31.175278+00:00time="2023-01-21T23:30:31.175243782Z" level=info msg="loading plugin \"io.containerd.differ.v1.walking\"..." type=io.containerd.differ.v1
2023-01-21 23:30:31.175307+00:00time="2023-01-21T23:30:31.175275543Z" level=info msg="loading plugin \"io.containerd.event.v1.exchange\"..." type=io.containerd.event.v1
2023-01-21 23:30:31.175331+00:00time="2023-01-21T23:30:31.175288064Z" level=info msg="loading plugin \"io.containerd.gc.v1.scheduler\"..." type=io.containerd.gc.v1
2023-01-21 23:30:31.175393+00:00time="2023-01-21T23:30:31.175372036Z" level=info msg="loading plugin \"io.containerd.service.v1.introspection-service\"..." type=io.containerd.service.v1
2023-01-21 23:30:31.175418+00:00time="2023-01-21T23:30:31.175387165Z" level=info msg="loading plugin \"io.containerd.service.v1.containers-service\"..." type=io.containerd.service.v1
2023-01-21 23:30:31.175429+00:00time="2023-01-21T23:30:31.175400826Z" level=info msg="loading plugin \"io.containerd.service.v1.content-service\"..." type=io.containerd.service.v1
2023-01-21 23:30:31.175629+00:00time="2023-01-21T23:30:31.175600279Z" level=info msg="loading plugin \"io.containerd.service.v1.diff-service\"..." type=io.containerd.service.v1
2023-01-21 23:30:31.175664+00:00time="2023-01-21T23:30:31.175641182Z" level=info msg="loading plugin \"io.containerd.service.v1.images-service\"..." type=io.containerd.service.v1
2023-01-21 23:30:31.175679+00:00time="2023-01-21T23:30:31.175653839Z" level=info msg="loading plugin \"io.containerd.service.v1.leases-service\"..." type=io.containerd.service.v1
2023-01-21 23:30:31.175687+00:00time="2023-01-21T23:30:31.175662699Z" level=info msg="loading plugin \"io.containerd.service.v1.namespaces-service\"..." type=io.containerd.service.v1
2023-01-21 23:30:31.175692+00:00time="2023-01-21T23:30:31.175671349Z" level=info msg="loading plugin \"io.containerd.service.v1.snapshots-service\"..." type=io.containerd.service.v1
2023-01-21 23:30:31.175704+00:00time="2023-01-21T23:30:31.175679746Z" level=info msg="loading plugin \"io.containerd.runtime.v1.linux\"..." type=io.containerd.runtime.v1
2023-01-21 23:30:31.175881+00:00time="2023-01-21T23:30:31.175855674Z" level=info msg="loading plugin \"io.containerd.runtime.v2.task\"..." type=io.containerd.runtime.v2
2023-01-21 23:30:31.176037+00:00time="2023-01-21T23:30:31.175983970Z" level=info msg="loading plugin \"io.containerd.monitor.v1.cgroups\"..." type=io.containerd.monitor.v1
2023-01-21 23:30:31.176341+00:00time="2023-01-21T23:30:31.176315267Z" level=info msg="loading plugin \"io.containerd.service.v1.tasks-service\"..." type=io.containerd.service.v1
2023-01-21 23:30:31.176382+00:00time="2023-01-21T23:30:31.176361712Z" level=info msg="loading plugin \"io.containerd.grpc.v1.introspection\"..." type=io.containerd.grpc.v1
2023-01-21 23:30:31.176392+00:00time="2023-01-21T23:30:31.176375320Z" level=info msg="loading plugin \"io.containerd.internal.v1.restart\"..." type=io.containerd.internal.v1
2023-01-21 23:30:31.176518+00:00time="2023-01-21T23:30:31.176495324Z" level=info msg="loading plugin \"io.containerd.grpc.v1.containers\"..." type=io.containerd.grpc.v1
2023-01-21 23:30:31.176530+00:00time="2023-01-21T23:30:31.176507954Z" level=info msg="loading plugin \"io.containerd.grpc.v1.content\"..." type=io.containerd.grpc.v1
2023-01-21 23:30:31.176536+00:00time="2023-01-21T23:30:31.176519072Z" level=info msg="loading plugin \"io.containerd.grpc.v1.diff\"..." type=io.containerd.grpc.v1
2023-01-21 23:30:31.176545+00:00time="2023-01-21T23:30:31.176530284Z" level=info msg="loading plugin \"io.containerd.grpc.v1.events\"..." type=io.containerd.grpc.v1
2023-01-21 23:30:31.176554+00:00time="2023-01-21T23:30:31.176539602Z" level=info msg="loading plugin \"io.containerd.grpc.v1.healthcheck\"..." type=io.containerd.grpc.v1
2023-01-21 23:30:31.176567+00:00time="2023-01-21T23:30:31.176551467Z" level=info msg="loading plugin \"io.containerd.grpc.v1.images\"..." type=io.containerd.grpc.v1
2023-01-21 23:30:31.176589+00:00time="2023-01-21T23:30:31.176561908Z" level=info msg="loading plugin \"io.containerd.grpc.v1.leases\"..." type=io.containerd.grpc.v1
2023-01-21 23:30:31.176596+00:00time="2023-01-21T23:30:31.176575674Z" level=info msg="loading plugin \"io.containerd.grpc.v1.namespaces\"..." type=io.containerd.grpc.v1
2023-01-21 23:30:31.176609+00:00time="2023-01-21T23:30:31.176585917Z" level=info msg="loading plugin \"io.containerd.internal.v1.opt\"..." type=io.containerd.internal.v1
2023-01-21 23:30:31.176896+00:00time="2023-01-21T23:30:31.176870291Z" level=info msg="loading plugin \"io.containerd.grpc.v1.snapshots\"..." type=io.containerd.grpc.v1
2023-01-21 23:30:31.176921+00:00time="2023-01-21T23:30:31.176899180Z" level=info msg="loading plugin \"io.containerd.grpc.v1.tasks\"..." type=io.containerd.grpc.v1
2023-01-21 23:30:31.176934+00:00time="2023-01-21T23:30:31.176912552Z" level=info msg="loading plugin \"io.containerd.grpc.v1.version\"..." type=io.containerd.grpc.v1
2023-01-21 23:30:31.176945+00:00time="2023-01-21T23:30:31.176927967Z" level=info msg="loading plugin \"io.containerd.tracing.processor.v1.otlp\"..." type=io.containerd.tracing.processor.v1
2023-01-21 23:30:31.176961+00:00time="2023-01-21T23:30:31.176941332Z" level=info msg="skip loading plugin \"io.containerd.tracing.processor.v1.otlp\"..." error="no OpenTelemetry endpoint: skip plugin" type=io.containerd.tracing.processor.v1
2023-01-21 23:30:31.176969+00:00time="2023-01-21T23:30:31.176949796Z" level=info msg="loading plugin \"io.containerd.internal.v1.tracing\"..." type=io.containerd.internal.v1
2023-01-21 23:30:31.177031+00:00time="2023-01-21T23:30:31.177012155Z" level=error msg="failed to initialize a tracing processor \"otlp\"" error="no OpenTelemetry endpoint: skip plugin"
2023-01-21 23:30:31.177484+00:00time="2023-01-21T23:30:31.177454738Z" level=info msg=serving... address=/var/run/docker/containerd/containerd-debug.sock
2023-01-21 23:30:31.177592+00:00time="2023-01-21T23:30:31.177560939Z" level=info msg=serving... address=/var/run/docker/containerd/containerd.sock.ttrpc
2023-01-21 23:30:31.177982+00:00time="2023-01-21T23:30:31.177932515Z" level=info msg=serving... address=/var/run/docker/containerd/containerd.sock
2023-01-21 23:30:31.178057+00:00time="2023-01-21T23:30:31.178012255Z" level=info msg="containerd successfully booted in 0.065517s"
2023-01-21 23:30:31.188679+00:00time="2023-01-21T23:30:31.188610834Z" level=info msg="parsed scheme: \"unix\"" module=grpc
2023-01-21 23:30:31.188704+00:00time="2023-01-21T23:30:31.188649314Z" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
2023-01-21 23:30:31.188712+00:00time="2023-01-21T23:30:31.188669508Z" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///var/run/docker/containerd/containerd.sock <nil> 0 <nil>}] <nil> <nil>}" module=grpc
2023-01-21 23:30:31.188729+00:00time="2023-01-21T23:30:31.188682296Z" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
2023-01-21 23:30:31.190012+00:00time="2023-01-21T23:30:31.189965369Z" level=info msg="parsed scheme: \"unix\"" module=grpc
2023-01-21 23:30:31.190038+00:00time="2023-01-21T23:30:31.189979942Z" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
2023-01-21 23:30:31.190045+00:00time="2023-01-21T23:30:31.189995852Z" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///var/run/docker/containerd/containerd.sock <nil> 0 <nil>}] <nil> <nil>}" module=grpc
2023-01-21 23:30:31.190055+00:00time="2023-01-21T23:30:31.190013594Z" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
2023-01-21 23:30:31.217971+00:00time="2023-01-21T23:30:31.217883757Z" level=info msg="Loading containers: start."
2023-01-21 23:30:31.307037+00:00time="2023-01-21T23:30:31.306963132Z" level=info msg="Default bridge (docker0) is assigned with an IP address 172.18.0.0/16. Daemon option --bip can be used to set a preferred IP address"
2023-01-21 23:30:31.326085+00:00time="2023-01-21T23:30:31.326021686Z" level=info msg="Loading containers: done."
2023-01-21 23:30:31.342486+00:00time="2023-01-21T23:30:31.342381952Z" level=info msg="Docker daemon" commit=42c8b31 graphdriver(s)=zfs version=20.10.22
2023-01-21 23:30:31.342703+00:00time="2023-01-21T23:30:31.342655613Z" level=info msg="Daemon has completed initialization"
2023-01-21 23:30:31.446336+00:00time="2023-01-21T23:30:31.446170902Z" level=info msg="API listen on /var/run/docker.sock"
2023-01-21 23:30:31.451798+00:00time="2023-01-21T23:30:31.451697067Z" level=info msg="API listen on [::]:2376"
2023-01-21 23:30:34.251400+00:00time="2023-01-21T23:30:34.251317245Z" level=info msg="Processing signal 'terminated'"
2023-01-21 23:30:34.252070+00:00time="2023-01-21T23:30:34.252022781Z" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
2023-01-21 23:30:34.252263+00:00time="2023-01-21T23:30:34.252222016Z" level=info msg="Daemon shutdown complete"
2023-01-21 23:30:34.252345+00:00time="2023-01-21T23:30:34.252233007Z" level=info msg="stopping healthcheck following graceful shutdown" module=libcontainerd
2023-01-21 23:30:34.252362+00:00time="2023-01-21T23:30:34.252242432Z" level=info msg="stopping event stream following graceful shutdown" error="context canceled" module=libcontainerd namespace=plugins.moby
