hi noobsauce80,
I built a USB stick with 8.3 and booted from it.
It hung once on the cron step, and another on the mountd step but after a couple reboots those went away.
I imported the UFS mirror, and removed the USB drive.
All seems to be working .....except.....very.....slowly. I shared a directory out with afp and it takes about 90 seconds to display the contents on a mac.
The webgui is rendering slowly as well, including commands run through the terminal page.
Here is my most recent boot sequence. My first thought was I had plugged the USB stick into a 1.1 port, but I don't think that is the case.
Copyright (c) 1992-2012 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 8.3-RELEASE-p4 #0 r241984M: Wed Oct 24 08:35:12 PDT 2012
root@build.ixsystems.com:/usr/home/jpaetzel/8.3.0-RELEASE/os-base/i386/i386/usr/home/jpaetzel/8.3.0-RELEASE/FreeBSD/src/sys/FREENAS.i386 i386
Timecounter "i8254" frequency 1193182 Hz quality 0
CPU: Intel(R) Atom(TM) CPU 230 @ 1.60GHz (1596.01-MHz 686-class CPU)
Origin = "GenuineIntel" Id = 0x106c2 Family = 6 Model = 1c Stepping = 2
Features=0xbfe9fbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
Features2=0x40e31d<SSE3,DTES64,MON,DS_CPL,TM2,SSSE3,CX16,xTPR,PDCM,MOVBE>
AMD Features=0x20100000<NX,LM>
AMD Features2=0x1<LAHF>
TSC: P-state invariant
real memory = 2147483648 (2048 MB)
avail memory = 2076475392 (1980 MB)
ACPI APIC Table: <111708 APIC1326>
FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
FreeBSD/SMP: 1 package(s) x 1 core(s) x 2 HTT threads
cpu0 (BSP): APIC ID: 0
cpu1 (AP/HT): APIC ID: 1
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ioapic0: Changing APIC ID to 2
ioapic0 <Version 2.0> irqs 0-23 on motherboard
kbd1 at kbdmux0
hpt27xx: RocketRAID 27xx controller driver v1.0 (Oct 24 2012 08:35:04)
cryptosoft0: <software crypto> on motherboard
aesni0: No AESNI support.
acpi0: <111708 XSDT1326> on motherboard
acpi0: [ITHREAD]
acpi0: Power Button (fixed)
acpi0: reservation of 0, a0000 (3) failed
acpi0: reservation of 100000, 7f700000 (3) failed
Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x808-0x80b on acpi0
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
vgapci0: <VGA-compatible display> port 0xdc00-0xdc07 mem 0xfea80000-0xfeafffff,0xe0000000-0xefffffff,0xfea40000-0xfea7ffff irq 16 at device 2.0 on pci0
agp0: <Intel 82945G (945G GMCH) SVGA controller> on vgapci0
agp0: aperture size is 256M, detected 7932k stolen memory
pcib1: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0
pci1: <ACPI PCI bus> on pcib1
re0: <RealTek 8168/8111 B/C/CP/D/DP/E/F PCIe Gigabit Ethernet> port 0xe800-0xe8ff mem 0xfebff000-0xfebfffff,0xfdff0000-0xfdffffff irq 16 at device 0.0 on pci1
re0: Using 1 MSI-X message
re0: Chip rev. 0x3c000000
re0: MAC rev. 0x00400000
miibus0: <MII bus> on re0
rgephy0: <RTL8169S/8110S/8211B media interface> PHY 1 on miibus0
rgephy0: none, 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow
re0: Ethernet address: 00:24:21:52:27:43
re0: [ITHREAD]
pcib2: <ACPI PCI-PCI bridge> irq 17 at device 28.1 on pci0
pci2: <ACPI PCI bus> on pcib2
pcib3: <ACPI PCI-PCI bridge> irq 18 at device 28.2 on pci0
pci3: <ACPI PCI bus> on pcib3
pcib4: <ACPI PCI-PCI bridge> irq 19 at device 28.3 on pci0
pci4: <ACPI PCI bus> on pcib4
uhci0: <Intel 82801G (ICH7) USB controller USB-A> port 0xd880-0xd89f irq 23 at device 29.0 on pci0
uhci0: [ITHREAD]
usbus0: <Intel 82801G (ICH7) USB controller USB-A> on uhci0
uhci1: <Intel 82801G (ICH7) USB controller USB-B> port 0xd800-0xd81f irq 19 at device 29.1 on pci0
uhci1: [ITHREAD]
usbus1: <Intel 82801G (ICH7) USB controller USB-B> on uhci1
uhci2: <Intel 82801G (ICH7) USB controller USB-C> port 0xd480-0xd49f irq 18 at device 29.2 on pci0
uhci2: [ITHREAD]
usbus2: <Intel 82801G (ICH7) USB controller USB-C> on uhci2
uhci3: <Intel 82801G (ICH7) USB controller USB-D> port 0xd400-0xd41f irq 16 at device 29.3 on pci0
uhci3: [ITHREAD]
usbus3: <Intel 82801G (ICH7) USB controller USB-D> on uhci3
ehci0: <Intel 82801GB/R (ICH7) USB 2.0 controller> mem 0xfea3bc00-0xfea3bfff irq 23 at device 29.7 on pci0
ehci0: [ITHREAD]
usbus4: EHCI version 1.0
usbus4: <Intel 82801GB/R (ICH7) USB 2.0 controller> on ehci0
pcib5: <ACPI PCI-PCI bridge> at device 30.0 on pci0
pci5: <ACPI PCI bus> on pcib5
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
atapci0: <Intel ICH7 UDMA100 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0xffa0-0xffaf at device 31.1 on pci0
ata0: <ATA channel> at channel 0 on atapci0
ata0: [ITHREAD]
atapci1: <Intel ICH7 SATA300 controller> port 0xd080-0xd087,0xd000-0xd003,0xcc00-0xcc07,0xc880-0xc883,0xc800-0xc80f irq 19 at device 31.2 on pci0
atapci1: [ITHREAD]
ata2: <ATA channel> at channel 0 on atapci1
ata2: [ITHREAD]
ata3: <ATA channel> at channel 1 on atapci1
ata3: [ITHREAD]
pci0: <serial bus, SMBus> at device 31.3 (no driver attached)
acpi_button0: <Power Button> on acpi0
atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
acpi_hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 900
pmtimer0 on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
atkbd0: [ITHREAD]
ppc0: parallel port not found.
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
p4tcc0: <CPU Frequency Thermal Control> on cpu0
coretemp1: <CPU On-Die Thermal Sensors> on cpu1
p4tcc1: <CPU Frequency Thermal Control> on cpu1
fuse4bsd: version 0.3.9-pre1, FUSE ABI 7.8
Timecounters tick every 1.000 msec
hpt27xx: no controller detected.
usbus0: 12Mbps Full Speed USB v1.0
usbus1: 12Mbps Full Speed USB v1.0
usbus2: 12Mbps Full Speed USB v1.0
usbus3: 12Mbps Full Speed USB v1.0
usbus4: 480Mbps High Speed USB v2.0
ugen0.1: <Intel> at usbus0
uhub0: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
ata0: DMA limited to UDMA33, controller found non-ATA66 cable
ugen1.1: <Intel> at usbus1
uhub1: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus1
ugen2.1: <Intel> at usbus2
uhub2: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2
ugen3.1: <Intel> at usbus3
uhub3: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus3
ugen4.1: <Intel> at usbus4
uhub4: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus4
uhub0: 2 ports with 2 removable, self powered
uhub1: 2 ports with 2 removable, self powered
uhub2: 2 ports with 2 removable, self powered
uhub3: 2 ports with 2 removable, self powered
uhub4: 8 ports with 8 removable, self powered
ugen4.2: <Kingston> at usbus4
umass0: <Kingston DT 101 G2, class 0/0, rev 2.00/1.00, addr 2> on usbus4
da0 at umass-sim0 bus 0 scbus3 target 0 lun 0
da0: <Kingston DT 101 G2 PMAP> Removable Direct Access SCSI-0 device
da0: 40.000MB/s transfers
da0: 14883MB (30481152 512 byte sectors: 255H 63S/T 1897C)
ada0 at ata0 bus 0 scbus0 target 0 lun 0
ada0: <CF CARD 4GB 20090216> ATA-0 device
ada0: 33.300MB/s transfers (UDMA2, PIO 512bytes)
ada0: 3831MB (7847280 512 byte sectors: 16H 63S/T 7785C)
ada1 at ata2 bus 0 scbus1 target 0 lun 0
ada1: <ST31500541AS CC32> ATA-8 SATA 2.x device
ada1: 150.000MB/s transfers (SATA, UDMA5, PIO 8192bytes)
ada1: 1430799MB (2930277168 512 byte sectors: 16H 63S/T 16383C)
ada2 at ata3 bus 0 scbus2 target 0 lun 0
ada2: <ST31500541AS CC34> ATA-8 SATA 2.x device
ada2: 150.000MB/s transfers (SATA, UDMA5, PIO 8192bytes)
ada2: 1430799MB (2930277168 512 byte sectors: 16H 63S/T 16383C)
SMP: AP CPU #1 Launched!
GEOM: da0s1: geometry does not match label (16h,63s != 255h,63s).
GEOM_MIRROR: Device mirror/mirror launched (2/2).
Trying to mount root from ufs:/dev/ufs/FreeNASs1a
Setting hostuuid: 00020003-0004-0005-0006-000700080009.
Setting hostid: 0x81f4ec68.
/dev/ufs/FreeNASs4: FILE SYSTEM CLEAN; SKIPPING CHECKS
/dev/ufs/FreeNASs4: clean, 39637 free (29 frags, 4951 blocks, 0.1% fragmentation)
No suitable dump device was found.
Entropy harvesting:
kickstart
Starting file system checks:
/dev/ufs/FreeNASs1a: FILE SYSTEM CLEAN; SKIPPING CHECKS
/dev/ufs/FreeNASs1a: clean, 1160503 free (1383 frags, 144890 blocks, 0.1% fragmentation)
/dev/ufs/FreeNASs3: FILE SYSTEM CLEAN; SKIPPING CHECKS
/dev/ufs/FreeNASs3: clean, 2829 free (21 frags, 351 blocks, 0.7% fragmentation)
/dev/ufs/mirror: FILE SYSTEM CLEAN; SKIPPING CHECKS
/dev/ufs/mirror: clean, 37551002 free (10098 frags, 4692613 blocks, 0.0% fragmentation)
Mounting local file systems:
Setting hostname: freenas.local
Starting dhclient.
re0: no link ...
got link
DHCPDISCOVER on re0 to 255.255.255.255 port 67 interval 8
DHCPOFFER from 192.168.0.1
DHCPREQUEST on re0 to 255.255.255.255 port 67
DHCPACK from 192.168.0.1
bound to 192.168.0.54 -- renewal in 43200 seconds.
Starting Network: lo0 re0.
options=3<RXCSUM,TXCSUM>
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x7
inet6 ::1 prefixlen 128
nd6 options=3<PERFORMNUD,ACCEPT_RTADV>
re0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC>
ether 00:24:21:52:27:43
inet 192.168.0.54 netmask 0xffffff00 broadcast 192.168.0.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
add net ::ffff:0.0.0.0: gateway ::1
add net ::0.0.0.0: gateway ::1
Starting devd.
Starting dhclient.
usbus0: not found
exiting.
/etc/rc.d/dhclient: WARNING: failed to start dhclient
Starting Network: usbus0.
Starting dhclient.
usbus1: not found
exiting.
Starting Network: usbus1.
Starting dhclient.
usbus2: not found
exiting.
Starting Network: usbus2.
Starting dhclient.
usbus3: not found
exiting.
Starting Network: usbus3.
Starting dhclient.
usbus4: not found
exiting.
Starting Network: usbus4.
dhclient already running? (pid=762).
Generating host.conf.
ELF ldconfig path: /lib /usr/lib /usr/local/lib
a.out ldconfig path: /usr/lib/aout
ldconfig:
/usr/lib/aout
No such file or directory
Creating and/or trimming log files
Starting syslogd.
/etc/rc: WARNING: Dump device does not exist. Savecore not run.
/etc/rc: WARNING: failed precmd routine for vmware_guestd
Updating motd:
Mounting late file systems:
Starting ntpd.
16+0 records in
16+0 records out
16 bytes transferred in 0.000187 secs (85598 bytes/sec)
Generating a 1024 bit RSA private key
writing new private key to '/etc/ssl/freenas/CA/private/cakey.key'
writing RSA key
Starting smartd.
Starting django.
Waiting for http...
Done.
Performing sanity check on nginx configuration:
nginx: the configuration file /usr/local/etc/nginx/nginx.conf syntax is ok
nginx: configuration file /usr/local/etc/nginx/nginx.conf test is successful
Starting nginx.
Starting dbus.
Starting avahi-daemon.
ZFS NOTICE: Prefetch is disabled by default on i386 -- to enable,
add "vfs.zfs.prefetch_disable=0" to /boot/loader.conf.
ZFS WARNING: Recommended minimum kmem_size is 512MB; expect unstable behavior.
Consider tuning vm.kmem_size and vm.kmem_size_max
in /boot/loader.conf.
ZFS filesystem version 5
ZFS storage pool version 28
Starting collectd.
Starting bsdstats.
Posting monthly OS statistics disabled
set monthly_statistics_enable="YES" in /etc/periodic.conf
Configuring syscons:
blanktime
Starting sshd.
Starting cron.
File "/usr/local/www/freenasUI/tools/sync_disks.py", line 60, in <module>
main()
File "/usr/local/www/freenasUI/tools/sync_disks.py", line 57, in main
_notifier.sync_disks()
File "/usr/local/www/freenasUI/tools/../../freenasUI/middleware/notifier.py", line 3515, in sync_disks
disk.save()
File "/usr/local/www/freenasUI/tools/../../freenasUI/storage/models.py", line 440, in save
super(Disk, self).save(args, kwargs)
File "/usr/local/lib/python2.7/site-packages/django/db/models/base.py", line 463, in save
self.save_base(using=using, force_insert=force_insert, force_update=force_update)
File "/usr/local/lib/python2.7/site-packages/django/db/models/base.py", line 529, in save_base
rows = manager.using(using).filter(pk=pk_val)._update(values)
File "/usr/local/lib/python2.7/site-packages/django/db/models/query.py", line 557, in _update
return query.get_compiler(self.db).execute_sql(None)
File "/usr/local/lib/python2.7/site-packages/django/db/models/sql/compiler.py", line 986, in execute_sql
cursor = super(SQLUpdateCompiler, self).execute_sql(result_type)
File "/usr/local/lib/python2.7/site-packages/django/db/models/sql/compiler.py", line 818, in execute_sql
cursor.execute(sql, params)
File "/usr/local/lib/python2.7/site-packages/django/db/backends/sqlite3/base.py", line 337, in execute
return Database.Cursor.execute(self, query, params)
django.db.utils
IntegrityError
storage_disk.disk_identifier may not be NULL
Starting rpcbind.
Starting mountd.
Wed Oct 31 10:16:23 PDT 2012
