floridamike
- Sep 6, 2016
Seem to be having some hardware issues. I'm getting repeating errors stating "Device: /dev/ada5, unable to open device"
When I reboot it comes back online for a little while. Seems like as soon as I push any real data on the associated volume it goes offline.
I have good backups and the device isn't in production yet. Trying to decide if it is the hard drive, cable, power, etc. It's always this ada5 so I'm thinking it is the drive or sata cable or sata port.
I did a fairly extensive burn in from the instructions here. The results for ada5 were slightly concerning (see bottom of post). But it did get a passing score and Multi_Zone_Error_Rate seems to not be a good predictor of drive failure.
Could replace but would like to know thoughts of the experienced community members. Thoughts and thanks in advanced.
[root@freenas] ~# smartctl -a /dev/ada5
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Blue
Device Model: WDC WD30EZRZ-00WN9B0
Serial Number: WD-WCC4E0DDCV9D
LU WWN Device Id: 5 0014ee 20ca31d83
Firmware Version: 80.00A80
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Sep 6 09:39:32 2016 EDT
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x80) Offline data collection activity
was never started.
Self-test execution status: ( 121) The previous self-test completed having
the read element of the test failed.
data collection: (43560) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 437) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x7035) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 100 253 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 100 253 021 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 3
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 199 199 000 Old_age Always - 27
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 106
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 3
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 1
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 31
194 Temperature_Celsius 0x0022 121 115 000 Old_age Always - 31
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 1
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed: read failure 90% 72 760312
# 2 Conveyance offline Completed without error 00% 1 -
# 3 Short offline Completed without error 00% 1 -
# 4 Conveyance offline Completed without error 00% 0 -
# 5 Short offline Completed without error 00% 0 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
[root@freenas] ~#
