greatwitenorth
- Feb 15, 2013
I recently reinstalled freenas after a power outage caused some boot up issues. I got the system back up and running using 9.2.1.9 and doing a auto import of my 2 mirrored hard drives. Once it was back up I had to delete a large time machine backup from my zfs pool. It took a while, then my macbook said it was disconnected from the volume. I tried to find it on the network but my freenas system seems to have hung completely.
I rebuilt the boot drive using 9.2.1.9 again and now I'm able to boot back up. But when I do an auto import, it stays on step 2 for a while then eventually the system reboots and I have to log back in. When I go to the storage tab it just says "No entry can be found"
I tried importing from the command line as well:
When I do a zpool import Media, a bunch of text whizzes by pretty fast then my system reboots. When it comes back up theres still no entry. Are my drives completely lost? Is there any way to get them online or to recover the data on them?
[root@freenas] ~# zpool import
pool: Media
state: ONLINE
status: The pool is formatted using a legacy on-disk version.
action: The pool can be imported using its name or numeric identifier, though
some features will not be available without an explicit 'zpool upgrade'.
Media ONLINE
mirror-0 ONLINE
gptid/4209d5b8-a0f4-11e4-9405-001aa09fbb6f ONLINE
gptid/09cc4745-7538-11e2-9a1e-001aa09fbb6f ONLINE
[root@freenas] ~# zpool status
no pools available
[root@freenas] ~#
