Please do not use external links, many of our forum people will not click on the links. Please post directly in our forums. And this site has a lot of popups! How many ways can we infect a computer, let me count the ways. The attached text file is much better for me to view.
Here is the iostat output as well https://pastecode.io/s/wa6y4i6i (view in fullscreen for better readability)
From the data provided, while it may not be a lot of data, it does appear that 'writing data' to be virtually continuous. I have no idea if that is contributing to your problem or not.
Another piece of information you have not provided is the version of SCALE you are running now and what were you running when your TRIM times were good? I'm trying to take notice in your postings, you just joined the forum yesterday (thanks for joining), you have been running TrueNAS for months but what version of TrueNAS were you running? Did you run CORE and upgrade to SCALE, what version of SCALE? We need some more history. Did this problem start after an upgrade? Can you roll back to the previous version that worked to verify it TRIM works and the current version of SCALE is causing your issue?
If you upgraded your pool, you may not be able to roll back, thus I never upgrade my pools as the new features are something that I would not use and they restrict me from rolling back to a previous version. Just something worth noting.
Hey @IvoT
The defaults in ZFS are to limit a maximum of 10 TRIM commands in queue per leaf vdev - so with your 8x SSD's in RAIDZ2, you're averaging just over one TRIM command in queue per physical disk, and it's also aiming to aggregate your TRIMs across transaction groups as well. This is designed to limit the TRIM speed in order not to impact pool I/O.
zpool iostat -vq YourPoolName 5 show? The trimq_write columns should show how deep your current TRIM queues are.Device r/s rMB/s rrqm/s %rrqm r_await rareq-sz w/s wMB/s wrqm/s %wrqm w_await wareq-sz d/s dMB/s drqm/s %drqm d_await dareq-sz f/s f_await aqu-sz %util dm-0 0.00 0.00 0.00 0.00 0.08 21.75 0.00 0.00 0.00 0.00 0.00 2.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 nvme0n1 0.20 0.00 0.00 0.00 0.23 21.23 30.60 0.10 0.00 0.00 0.04 3.45 0.00 0.00 0.00 0.00 0.00 0.00 0.42 1.45 0.00 0.36 sda 0.00 0.00 0.00 0.00 3.28 28.88 0.00 0.00 0.00 0.00 0.98 10.05 0.00 0.00 0.00 0.00 0.00 0.00 0.00 4.75 0.00 0.00 sdb 0.00 0.00 0.00 0.00 3.29 27.59 0.00 0.00 0.00 0.00 0.89 10.05 0.00 0.00 0.00 0.00 0.00 0.00 0.00 4.75 0.00 0.00 sdc 0.01 0.00 0.00 0.00 3.50 25.75 0.00 0.00 0.00 0.00 1.49 10.27 0.00 0.00 0.00 0.00 0.00 0.00 0.00 12.42 0.00 0.00 sdd 0.01 0.00 0.00 0.00 3.84 26.30 0.00 0.00 0.00 0.00 1.51 10.63 0.00 0.00 0.00 0.00 0.00 0.00 0.00 12.58 0.00 0.00 sde 0.06 0.00 0.00 0.00 1.38 20.33 17.97 0.12 0.04 0.25 0.06 6.98 0.27 22.90 0.00 0.20 1.11 85860.53 0.54 0.06 0.00 0.53 sdf 0.06 0.00 0.00 0.00 1.87 19.59 17.91 0.12 0.05 0.27 0.06 6.99 0.27 22.90 0.00 0.19 1.11 86084.19 0.54 0.06 0.00 0.53 sdg 0.06 0.00 0.00 0.00 0.25 19.19 17.97 0.12 0.05 0.25 0.06 6.98 0.27 22.90 0.00 0.19 1.12 86080.18 0.54 0.06 0.00 0.53 sdh 0.06 0.00 0.00 0.02 0.25 19.47 17.92 0.12 0.05 0.25 0.06 6.99 0.27 22.90 0.00 0.18 1.11 85844.60 0.54 0.06 0.00 0.53 sdi 0.00 0.00 0.00 0.00 3.35 26.74 0.00 0.00 0.00 0.00 1.47 10.14 0.00 0.00 0.00 0.00 0.00 0.00 0.00 11.58 0.00 0.00 sdj 0.00 0.00 0.00 0.00 3.81 27.19 0.00 0.00 0.00 0.00 1.45 9.99 0.00 0.00 0.00 0.00 0.00 0.00 0.00 12.50 0.00 0.00 sdk 0.00 0.00 0.00 0.00 3.83 27.53 0.00 0.00 0.00 0.60 1.62 10.40 0.00 0.00 0.00 0.00 0.00 0.00 0.00 5.00 0.00 0.00 sdl 0.01 0.00 0.00 0.00 3.11 26.27 0.00 0.00 0.00 0.59 1.07 10.11 0.00 0.00 0.00 0.00 0.00 0.00 0.00 7.33 0.00 0.00 zd0 0.00 0.00 0.00 0.00 0.00 21.75 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
capacity operations bandwidth syncq_read syncq_write asyncq_read asyncq_write scrubq_read trimq_write rebuildq_write
pool alloc free read write read write pend activ pend activ pend activ pend activ pend activ pend activ pend activ
SAS 12.7T 15.2T 42 699 249K 4.51M 0 0 0 0 0 0 0 0 0 0 63 16 0 0
raidz2-0 12.7T 15.2T 42 699 249K 4.51M 0 0 0 0 0 0 0 0 0 0 63 16 0 0
547ba0f9-ba44-4f01-ad33-4bda61310bdd - - 5 81 30.4K 560K 0 0 0 0 0 0 0 0 0 0 8 2 0 0
ae6f3e47-7d8e-45ff-b56c-0907c47b83bf - - 5 88 29.6K 577K 0 0 0 0 0 0 0 0 0 0 8 2 0 0
555672f7-1f29-451d-8fad-820612d19d05 - - 5 87 30.4K 573K 0 0 0 0 0 0 0 0 0 0 8 2 0 0
fba71670-e645-4906-818b-20238c8f97fd - - 4 89 29.6K 584K 0 0 0 0 0 0 0 0 0 0 8 2 0 0
5e41b921-b752-490d-bf6d-b79ecb9b1c22 - - 5 90 34.4K 584K 0 0 0 0 0 0 0 0 0 0 8 2 0 0
d1b7284c-ab83-498c-bad3-72ea74a7f6c8 - - 5 89 31.2K 579K 0 0 0 0 0 0 0 0 0 0 8 2 0 0
03efaaf3-eb40-492c-8f16-87c2b88f2aed - - 5 86 32.0K 586K 0 0 0 0 0 0 0 0 0 0 8 2 0 0
b26c8881-71ed-40b7-95c4-e45df9b4d9e1 - - 5 87 31.2K 577K 0 0 0 0 0 0 0 0 0 0 7 2 0 0
echo N >> /sys/module/zfs/parameters/zfs_vdev_trim_max_active2 but you can increase N up to the value of zfs_vdev_max_active - you'll with the understanding that increased TRIM/UNMAP activity will negatively impact pool I/O.echo N >> /sys/module/zfs/parameters/zfs_trim_queue_limitiostat and zpool iostat as well as general application latencies.iostat -mx dumps from that one as well, to compare the delete column metrics?hdparm -I /dev/sdX output, specifically with regards to the reported logical/physical sector size (since it's a Samsung, I expect both to report as 512b) and the number of TRIM blocks supported (under the "Data Set Management TRIM supported (limit 8 blocks)"
/dev/sdb:
ATA device, with non-removable media
Standards:
Likely used: 1
Configuration:
Logical max current
cylinders 0 0
heads 0 0
sectors/track 0 0
Logical/Physical Sector size: 512 bytes
device size with M = 1024*1024: 0 MBytes
device size with M = 1000*1000: 0 MBytes
cache/buffer size = unknown
Capabilities:
IORDY not likely
Cannot perform double-word IO
R/W multiple sector transfer: not supported
DMA: not supported
PIO: pio0
sdparm /dev/sdb -p bl | grep unmapMaximum unmap LBA count: -1 [unbounded] Maximum unmap block descriptor count: -1 [unbounded] Optimal unmap granularity: 8 blocks
sdparm /dev/sdb --get WCE to see if write caching is enabled?It may be something specific to your drives (PM1643) as it doesn't seem to have an issue pushing UNMAPs to my SSDs - although not at the same speed as the 400-500MB/s you mentioned, but mine are both in-use and not quite the same speed as your Samsungs. Might be worth submitting a bug/Jira ticket for this, and including a debug to indicate the slow TRIM performance even when manually launched.Currently it is at 71% trimmed. I will retry after a day or two, but I don't think it will be faster. To me it seems like for some reason truenas is not sending enough unmap requests to the pool.
NAGHey @IvoT
SAS drives do better with discards than SATA, so you may be able to use autotrim in your situation, and simply let the VMFS layer pass the UNMAP commands down the chain (VMware can also rate-limit the discard speed)
I need to make a longer effortpost on TRIM in general. Someone nag me if I haven't done it in a reasonable amount of time.![]()
