Tried an upgrade with potentially disastrous consequences. – What can I do?
Ceetan
I recently tried to upgrade my Nas to the most recent update. Now, admittedly it wasn't very smart of me to try to do that when I only had remote access so that's on me. With that being said, something went wrong and ever since that and then also hasn't been building properly from what I can tell. I can I access the IPMI, and I wonder if there is anything I can do from there? Currently I'm having error 0X17=Dimm not present, get on with the Supermicro logo on screen. How worried should I be? Is this apocalypse level failure? Should I try to power it down via IPMI until I can tend to it manually, or could that exacerbate the issue ?
This thread seems to concern a similar issue
https://forums.servethehome.com/index.php?threads/x11ssh-f-error-on-reboot.11320/
Thank you in advance
Ceetan
Specs for those on mobile
FreeNAS-11.0 (IIRC)
MOBO: Supermicro X11SSL-CF with
CPU: Intel Core i3-6100
RAM 2*16GB Crucial DDR4 ECC 2133MHz (CT2K16G4WFD8213)
8* WD Red WD40EFRX 64MB 4TB in RAIDZ2
BOOT: 90GB Corsair SSD
CASE: Fractal design node 804
PSU:EVGA SuperNOVA 650 G2
UPS: APC BE700G-GR,
Stux
Have you tried restarting it?
Pretty much if that doesn't work, the. You need physical maintenance.
Start by removing all DIMMs, then put them all back, and restart.
A software update did not cause this.
Ceetan
A hard reboot seems to have solved the issue, at least temporarily. Are there any tests you would recommend in order to select the general health of the server and the data?
maydo
i had same issue on latest upgrade FreeNAS-11.0-U2 on same board X11SSL-CF
fixed with removing all dimms and put them back
f4242
Had the same problem. I have 2 identicals servers, only one failed. I just powered off and on again and it booted.
