Transmission service is stopping randomly
nMad
I installed Transmission manually in an iocage jail using this guide. However, the Transmission service stops once every few days. The jail is still up and running and I am able to start the Transmission service again without any problems. I tried rebooting the jail and the server itself without any luck.
I can't find any errors in /var/log/messages other than normal Tranmission logging about torrents.
Can someone please help me out?
D
dlavigne
Guest
Were you able to resolve this?
If not, which version of FreeNAS?
nMad
Hi dlavigne, thanks for your reply. I was not able to resolve this.
Running latest FreeNAS stable release (11.2-U3) with latest and up to date jail version (11.2-RELEASE-p6). Jail is really clean, only Transmission installed with minimum of configuration, no special settings.
I can provide any logging you ask for to help investigate. Your help would be much appreciated!
nMad
Because it can also be related to Transmission itself I created an issue at Github: https://github.com/transmission/transmission/issues/867
Someone replied with the following comment:
When I encountered this problem, it was due to my system not having enough ram available. ZFS was eating it all up but creating a swap partition seemed to fix it for me.
Can this indeed be the problem? I have 16 GB of RAM and didn't change any swap or RAM related settings.
