leprechaun
- Mar 17, 2012
I have a problem after i set up my jail and try to install transmission it says that it installed successfully. But it does not show up in the drop down menu under plugins. If i then go to the control services and go to plugins i can see transmission. But when i try to start it i get the following message: Jun 18 12:36:22 freenas manage.py: [freeadmin.navtree:413] Couldn't retrieve http://192.168.1.74:80/plugins/transmission/_s/treemenu: HTTP Error 502: Bad Gateway
I tried to remove the plug in,jail and even tried to reinstall freenas but still no luck. But i could from the shell access the jail and install flexget. I Am using freenas 8.2 Beta 4
