Transmission - Change 'Download Location' to a zvol ?
Firenor
Running freenas 8.2 with transmission plugin installed via jail.
I am trying to change Download Location in transmission to a dev/zvol that I created and has shared to my Windows box via iSCSI.
Do I need to mount the zvol in freenas before I can use it in transmission?
I am a newbie to freebsd and I have no idea how to do this, if this is even the solution? If it is, how do I make to automaticly mount everytime I start freenas?
Please help me!
Firenor
Thank you very much for your reply!
Now to my next problem with this.
I now get this:
Error: Permission denied
When I try to write data to the mounted folder
I could not browse to /dev/zvol but I could enter it manually in the wizard, seems to work but I dont now how to test it other than trying to download something but it gave me the above error message.
lrusak
I now get this:
you have a permission error, you will need to give the folder or mount write permisions. You can do this via chmod -R
