transmission can't connect to trackers
yomismo
i had transmission on the old UI and since was the last plugin left behind i decided to remove that and move it on the new UI and new jail
now transmission dont download anything, i can ping from the jail shell yet i cant get any seed for the debian torrent
Candle
Are you running it through a VPN? If so, try doing "service -R." If it says OpenVPN can't start run this line: ln -sf /lib/libc.so.7 /usr/lib/libdl.so.1
This fixes the
Shared object "libdl.so.1" not found, required by "openvpn"
/usr/sbin/service: WARNING: failed to start openvpn
Issue.
yomismo
Edit: solved i just installed the plugin many times until of one them was OK and deleted the rest
