panzerscope
 - May 30, 2022
Hello all.
I am running Traefik with Nextcloud which is going well. I wanted to take advantage of the fact Traefik allows you to setup Auth so you get the login prompt box before you hit the main Nextcloud login page.
I set it up and when browsing to my Nextcloud domain, the Auth prompt appears as it should, however after logging in, when I get to the Nextcloud page, rather than seeing the login, I get "Error" see below for my example.
Expected result of Auth box:
Unexpected error after logging in through Auth:
Has anyone else come across this ?
I know that Authelia is an option, but I figured I would see if I can get an existing option working first.
Thanks,
P
Thanks,
P
