I am fairly new to using trueNAS OS and recently built my first server. I tried searching and although i did find a couple threads on this issue, it was from years back and not really having any solution listed.
I have created a vdev and created a dataset.. Issue i'm having is with the total disk capacity when the drive is mapped in windows. I am running the latest current trueNAS OS 13.1-U4 and using SMB for sharing. I had about 41.3TB of available space. When i copied data, both the total size of the disk and free space is showing the same size in windows mapped drive. In the screenshot it should be showing 39.1TB of 41.3TB, but instead i see 39.1TB of 39.1TB. If i keep adding data, both remaining size and disk size will keep decreasing. Has anyone come across this before? I'm hoping it could be something very simple I am overlooking.. I appreciate any suggestions.. thank you..
