To RMA or not to RMA, that is the question.. ( WD RED 3TB, less then 2 years old raw read errors)
Noctris
Hi Guys,
So i've had my system (Nebula in signature) running for a while and i got an error in the smart reporting ( selft-test count failed from 0 To 1) apparently due to read failure.
It has been increasing ever since although sometimes if completes without an error ( strange). I tried reinserting the drive in the bay thinking it was a bad contact, swapped the drive to a different bay ( which is on a different sas cable and controller) but it keeps doing the error wat the same LBA..
So my question is: what do the more experienced guys here think ? RMA or not worry yet ?
If RMA: is this something WD would accept for RMA and are there any Europeans here that have had the RMA Procedure completed ? Up until now i only handled RMA with the local store which is always a Hasstle. Mainly because they want the disk before giving a new one which I , logically, would never do. So i'd preffer to do it with WD Direct.
Thanks in advance for the advice !
[root@nebula] ~# smartctl -a /dev/da4
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:	 Western Digital Red
Device Model:	 WDC WD30EFRX-68EUZN0
Serial Number:	WD-WCC4N5AE55VS
LU WWN Device Id: 5 0014ee 20bc49fa3
Firmware Version: 82.00A82
User Capacity:	3,000,592,982,016 bytes [3.00 TB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Rotation Rate:	5400 rpm
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:	Thu Nov  3 16:42:27 2016 CET
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
										was never started.
Self-test execution status:	  ( 113) The previous self-test completed having
										the read element of the test failed.
data collection:				(39900) seconds.
capabilities:					(0x7b) SMART execute Offline immediate.
										command.
										Self-test supported.
SMART capabilities:			(0x0003) Saves SMART data before entering
										power-saving mode.
Error logging capability:		(0x01) Error logging supported.
Short self-test routine
recommended polling time:		(   2) minutes.
Extended self-test routine
recommended polling time:		( 400) minutes.
Conveyance self-test routine
recommended polling time:		(   5) minutes.
SCT capabilities:			  (0x703d) SCT Status supported.
										SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x002f   200   200   051	Pre-fail  Always	   -	   21
  3 Spin_Up_Time			0x0027   178   177   021	Pre-fail  Always	   -	   6058
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   85
  5 Reallocated_Sector_Ct   0x0033   200   200   140	Pre-fail  Always	   -	   1
  7 Seek_Error_Rate		 0x002e   200   200   000	Old_age   Always	   -	   0
  9 Power_On_Hours		  0x0032   084   084   000	Old_age   Always	   -	   12374
 10 Spin_Retry_Count		0x0032   100   253   000	Old_age   Always	   -	   0
 11 Calibration_Retry_Count 0x0032   100   253   000	Old_age   Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   85
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   83
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   338
194 Temperature_Celsius	 0x0022   121   111   000	Old_age   Always	   -	   29
196 Reallocated_Event_Count 0x0032   199   199   000	Old_age   Always	   -	   1
197 Current_Pending_Sector  0x0032   200   200   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0030   100   253   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x0032   200   200   000	Old_age   Always	   -	   0
200 Multi_Zone_Error_Rate   0x0008   200   200   000	Old_age   Offline	  -	   5
SMART Error Log Version: 1
No Errors Logged
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline	   Completed: read failure	   10%	 12358		 37402232
# 2  Short offline	   Completed: read failure	   10%	 12345		 37402232
# 3  Short offline	   Completed without error	   00%	 12321		 -
# 4  Short offline	   Completed: read failure	   10%	 12297		 37402232
# 5  Short offline	   Completed: read failure	   10%	 12272		 37402232
# 6  Short offline	   Completed: read failure	   10%	 12248		 37402232
# 7  Short offline	   Completed: read failure	   10%	 12224		 37402232
# 8  Short offline	   Completed: read failure	   10%	 12200		 37402232
# 9  Short offline	   Completed: read failure	   10%	 12176		 37402232
#10  Extended captive	Interrupted (host reset)	  90%	 12166		 -
#11  Extended captive	Interrupted (host reset)	  90%	 12166		 -
#12  Short offline	   Completed: read failure	   10%	 12153		 37402232
#13  Short offline	   Completed without error	   00%	 12128		 -
#14  Short offline	   Completed without error	   00%	 12116		 -
#15  Short offline	   Completed without error	   00%	 12104		 -
#16  Short offline	   Completed without error	   00%	 12092		 -
#17  Short offline	   Completed without error	   00%	 12080		 -
#18  Short offline	   Completed without error	   00%	 12068		 -
#19  Short offline	   Completed without error	   00%	 12056		 -
#20  Short offline	   Completed without error	   00%	 12045		 -
#21  Short offline	   Completed without error	   00%	 12031		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
[root@nebula] ~# badblocks -h
badblocks: option requires an argument -- h
Usage: badblocks [-b block_size] [-i input_file] [-o output_file] [-svwnf]
	   [-c blocks_at_once] [-d delay_factor_between_reads] [-e max_bad_blocks]
	   [-p num_passes] [-t test_pattern [-t test_pattern [...]]]
	   device [last_block [first_block]]
JoshDW19
Community Hall of Fame
I'll leave the more technical aspect of your question to our more knowledgable members, but I wanted to mention I've had success in some instances with asking that parts be cross-shipped so that I could make sure everything was migrated properly. Generally they'd charge my credit card for the new part and then refund it when they received the defective part a couple weeks later. I can't recall if WD does this, but it might be something helpful to ask for.
WD in the US will do advance exchanges; not sure about outside the US. But if you deal with your vendor, you'll probably get a new replacement, while if you RMA the disk with WD, you'll end up with a refurbished disk instead.
As to whether to return it, it's pretty consistently failing SMART tests. Those tests are internal to the disk; cables or other external factors shouldn't affect them. I'd be interested in seeing what a long SMART test does; none of them have completed during the time in your disk's SMART log. But if short tests are consistently failing, that should be adequate grounds to RMA the disk.
Stux
RMA.
DrKK
FreeNAS Generalissimo
Yeah, not only that, but he can't even get SHORT tests to complete. If possible, OP, I would like to see the COMPLETE (i.e., do not edit) output of "smartctl -x" instead of "smartctl -a".
Either way I'm going to recommend an RMA, but I would like to see your extended SMART output, maybe to assess if there was any way you could have prevented the problem.
Robert Trevellyan
Pony Wrangler
+1 for RMA. I just recently did an advanced RMA with WD USA and had a replacement within a couple of days. Hopefully you can get a similar outcome in your location.
Noctris
Alrighty, let's RMA then. Now i do have a spare lying around here so I might just already replace this disk. I just wanted to make sure that WD would accept these error's for their RMA.
Thanks already for the input !
Output of smartctl -x /dev/da4 as requested:
[root@nebula] ~# smartctl -x /dev/da4
Local Time is:	Fri Nov  4 10:32:32 2016 CET
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Enabled
Write cache is:   Enabled
ATA Security is:  Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
										was never started.
Self-test execution status:	  (   0) The previous self-test routine completed
										been run.
										command.
										power-saving mode.
ID# ATTRIBUTE_NAME		  FLAGS	VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate	 POSR-K   200   200   051	-	21
  3 Spin_Up_Time			POS--K   178   177   021	-	6058
  4 Start_Stop_Count		-O--CK   100   100   000	-	85
  5 Reallocated_Sector_Ct   PO--CK   200   200   140	-	1
  7 Seek_Error_Rate		 -OSR-K   200   200   000	-	0
  9 Power_On_Hours		  -O--CK   084   084   000	-	12391
10 Spin_Retry_Count		-O--CK   100   253   000	-	0
11 Calibration_Retry_Count -O--CK   100   253   000	-	0
12 Power_Cycle_Count	   -O--CK   100   100   000	-	85
192 Power-Off_Retract_Count -O--CK   200   200   000	-	83
193 Load_Cycle_Count		-O--CK   200   200   000	-	338
194 Temperature_Celsius	 -O---K   121   111   000	-	29
196 Reallocated_Event_Count -O--CK   199   199   000	-	1
197 Current_Pending_Sector  -O--CK   200   200   000	-	0
198 Offline_Uncorrectable   ----CK   100   253   000	-	0
199 UDMA_CRC_Error_Count	-O--CK   200   200   000	-	0
200 Multi_Zone_Error_Rate   ---R--   200   200   000	-	5
							||||||_ K auto-keep
							|||||__ C event count
							||||___ R error rate
							|||____ S speed/performance
							||_____ O updated online
							|______ P prefailure warning
General Purpose Log Directory Version 1
SMART		   Log Directory Version 1 [multi-sector log support]
Address	Access  R/W   Size  Description
0x00	   GPL,SL  R/O	  1  Log Directory
0x01		   SL  R/O	  1  Summary SMART error log
0x02		   SL  R/O	  5  Comprehensive SMART error log
0x03	   GPL	 R/O	  6  Ext. Comprehensive SMART error log
0x06		   SL  R/O	  1  SMART self-test log
0x07	   GPL	 R/O	  1  Extended self-test log
0x09		   SL  R/W	  1  Selective self-test log
0x10	   GPL	 R/O	  1  SATA NCQ Queued Error log
0x11	   GPL	 R/O	  1  SATA Phy Event Counters log
0x21	   GPL	 R/O	  1  Write stream error log
0x22	   GPL	 R/O	  1  Read stream error log
0x80-0x9f  GPL,SL  R/W	 16  Host vendor specific log
0xa0-0xa7  GPL,SL  VS	  16  Device vendor specific log
0xa8-0xb7  GPL,SL  VS	   1  Device vendor specific log
0xbd	   GPL,SL  VS	   1  Device vendor specific log
0xc0	   GPL,SL  VS	   1  Device vendor specific log
0xc1	   GPL	 VS	  93  Device vendor specific log
0xe0	   GPL,SL  R/W	  1  SCT Command/Status
0xe1	   GPL,SL  R/W	  1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
Device Error Count: 6
		CR	 = Command Register
		FEATR  = Features Register
		COUNT  = Count (was: Sector Count) Register
		LBA_48 = Upper bytes of LBA High/Mid/Low Registers ]  ATA-8
		LH	 = LBA High (was: Cylinder High) Register	]   LBA
		LM	 = LBA Mid (was: Cylinder Low) Register	  ] Register
		LL	 = LBA Low (was: Sector Number) Register	 ]
		DV	 = Device (was: Device/Head) Register
		DC	 = Device Control Register
		ER	 = Error register
		ST	 = Status register
Error 6 [5] occurred at disk power-on lifetime: 12190 hours (507 days + 22 hours)
  ER -- ST COUNT  LBA_48  LH LM LL DV DC
  40 -- 51 00 00 00 00 02 3a 9c 18 40 00  Error: UNC at LBA = 0x023a9c18 = 37395480
  CR FEATR COUNT  LBA_48  LH LM LL DV DC  Powered_Up_Time  Command/Feature_Name
  60 01 00 00 00 00 00 02 3a 9d d8 40 00  7d+14:47:08.995  READ FPDMA QUEUED
  60 01 00 00 10 00 00 02 3a 9c d8 40 00  7d+14:47:08.993  READ FPDMA QUEUED
  60 01 00 00 08 00 00 02 3a 9b d8 40 00  7d+14:47:08.992  READ FPDMA QUEUED
  60 01 00 00 00 00 00 02 3a 9a d8 40 00  7d+14:47:08.983  READ FPDMA QUEUED
  60 01 00 00 10 00 00 02 3a 99 d8 40 00  7d+14:47:08.971  READ FPDMA QUEUED
Error 5 [4] occurred at disk power-on lifetime: 5606 hours (233 days + 14 hours)
  40 -- 51 00 00 00 00 02 3a b6 78 40 00  Error: UNC at LBA = 0x023ab678 = 37402232
  60 01 00 00 08 00 00 02 3a b6 c8 40 00	 20:03:33.173  READ FPDMA QUEUED
  60 01 00 00 00 00 00 02 3a b5 c8 40 00	 20:03:33.152  READ FPDMA QUEUED
  60 00 40 00 08 00 00 02 3a b5 48 40 00	 20:03:33.146  READ FPDMA QUEUED
  60 00 40 00 00 00 00 02 3a b5 88 40 00	 20:03:33.146  READ FPDMA QUEUED
  60 00 40 00 00 00 00 02 3a b5 08 40 00	 20:03:33.146  READ FPDMA QUEUED
Error 4 [3] occurred at disk power-on lifetime: 5113 hours (213 days + 1 hours)
  When the command that caused the error occurred, the device was doing SMART Offline or Self-test.
  40 -- 51 00 00 00 00 02 3a c3 98 40 00  Error: UNC at LBA = 0x023ac398 = 37405592
  60 00 10 00 20 00 01 5d 50 a0 90 40 00  4d+13:37:45.627  READ FPDMA QUEUED
  60 00 10 00 18 00 01 5d 50 9e 90 40 00  4d+13:37:45.627  READ FPDMA QUEUED
  60 00 10 00 10 00 00 00 40 02 90 40 00  4d+13:37:45.627  READ FPDMA QUEUED
  60 01 00 00 08 00 00 02 3a c3 c0 40 00  4d+13:37:45.627  READ FPDMA QUEUED
  60 01 00 00 00 00 00 02 3a c2 c0 40 00  4d+13:37:45.621  READ FPDMA QUEUED
Error 3 [2] occurred at disk power-on lifetime: 5113 hours (213 days + 1 hours)
  40 -- 51 00 00 00 00 02 3a c2 68 40 00  Error: UNC at LBA = 0x023ac268 = 37405288
  60 01 00 00 08 00 00 02 3a c1 c0 40 00  4d+13:37:42.146  READ FPDMA QUEUED
  60 01 00 00 00 00 00 02 3a c0 c0 40 00  4d+13:37:42.146  READ FPDMA QUEUED
  60 01 00 00 08 00 00 02 3a bf c0 40 00  4d+13:37:42.145  READ FPDMA QUEUED
  60 01 00 00 00 00 00 02 3a be c0 40 00  4d+13:37:42.145  READ FPDMA QUEUED
  60 00 40 00 08 00 00 02 3a be 40 40 00  4d+13:37:42.097  READ FPDMA QUEUED
Error 2 [1] occurred at disk power-on lifetime: 5113 hours (213 days + 1 hours)
  40 -- 51 00 00 00 00 02 3a b5 48 40 00  Error: WP at LBA = 0x023ab548 = 37401928
  61 00 10 00 10 00 00 00 40 02 90 40 00  4d+13:37:36.863  WRITE FPDMA QUEUED
  60 00 10 00 20 00 01 5d 50 a0 90 40 00  4d+13:37:36.851  READ FPDMA QUEUED
  60 00 10 00 18 00 01 5d 50 9e 90 40 00  4d+13:37:36.851  READ FPDMA QUEUED
  60 00 10 00 10 00 00 00 40 02 90 40 00  4d+13:37:36.851  READ FPDMA QUEUED
  60 01 00 00 08 00 00 02 3a b6 c8 40 00  4d+13:37:36.851  READ FPDMA QUEUED
Error 1 [0] occurred at disk power-on lifetime: 5113 hours (213 days + 1 hours)
  60 01 00 00 08 00 00 02 3a b5 c8 40 00  4d+13:37:33.357  READ FPDMA QUEUED
  60 00 40 00 00 00 00 02 3a b5 48 40 00  4d+13:37:33.352  READ FPDMA QUEUED
  60 00 40 00 08 00 00 02 3a b5 88 40 00  4d+13:37:33.350  READ FPDMA QUEUED
  60 00 40 00 00 00 00 02 3a b5 08 40 00  4d+13:37:33.350  READ FPDMA QUEUED
  60 00 40 00 00 00 00 02 3a b4 c8 40 00  4d+13:37:33.350  READ FPDMA QUEUED
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1  Short offline	   Completed without error	   00%	 12382		 -
# 2  Short offline	   Completed: read failure	   10%	 12358		 37402232
# 3  Short offline	   Completed: read failure	   10%	 12345		 37402232
# 4  Short offline	   Completed without error	   00%	 12321		 -
# 5  Short offline	   Completed: read failure	   10%	 12297		 37402232
# 6  Short offline	   Completed: read failure	   10%	 12272		 37402232
# 7  Short offline	   Completed: read failure	   10%	 12248		 37402232
# 8  Short offline	   Completed: read failure	   10%	 12224		 37402232
# 9  Short offline	   Completed: read failure	   10%	 12200		 37402232
#10  Short offline	   Completed: read failure	   10%	 12176		 37402232
#12  Extended captive	Interrupted (host reset)	  90%	 12166		 -
#13  Short offline	   Completed: read failure	   10%	 12153		 37402232
#14  Short offline	   Completed without error	   00%	 12128		 -
#15  Short offline	   Completed without error	   00%	 12116		 -
#16  Short offline	   Completed without error	   00%	 12104		 -
#17  Short offline	   Completed without error	   00%	 12092		 -
#18  Short offline	   Completed without error	   00%	 12080		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
SCT Status Version:				  3
SCT Version (vendor specific):	   258 (0x0102)
SCT Support Level:				   1
Device State:						Active (0)
Current Temperature:					29 Celsius
Power Cycle Min/Max Temperature:	 29/30 Celsius
Lifetime	Min/Max Temperature:	  2/39 Celsius
Under/Over Temperature Limit Count:   0/0
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version:	 2
Temperature Sampling Period:		 1 minute
Temperature Logging Interval:		1 minute
Min/Max recommended Temperature:	  0/60 Celsius
Min/Max Temperature Limit:		   -41/85 Celsius
Temperature History Size (Index):	478 (221)
Index	Estimated Time   Temperature Celsius
222	2016-11-04 02:35	29  **********
...	..(476 skipped).	..  **********
221	2016-11-04 10:32	29  **********
SCT Error Recovery Control:
		   Read:	 70 (7.0 seconds)
		  Write:	 70 (7.0 seconds)
Device Statistics (GP/SMART Log 0x04) not supported
SATA Phy Event Counters (GP Log 0x11)
ID	  Size	 Value  Description
0x0001  2			0  Command failed due to ICRC error
0x0002  2			0  R_ERR response for data FIS
0x0003  2			0  R_ERR response for device-to-host data FIS
0x0004  2			0  R_ERR response for host-to-device data FIS
0x0005  2			0  R_ERR response for non-data FIS
0x0006  2			0  R_ERR response for device-to-host non-data FIS
0x0007  2			0  R_ERR response for host-to-device non-data FIS
0x0008  2			0  Device-to-host non-data FIS retries
0x0009  2			0  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2			1  Device-to-host register FISes sent due to a COMRESET
0x000b  2			0  CRC errors within host-to-device FIS
0x000f  2			0  R_ERR response for host-to-device data FIS, CRC
0x0012  2			0  R_ERR response for host-to-device non-data FIS, CRC
0x8000  4	   121963  Vendor specific
DrKK
Right, so, this smartctl output looks pretty innocuous. I don't see evidence of running the drive too hot, etc. I think you just got unlucky. These output warnings you have indicate that a very specific part of the platter surface is jacked up.
Carry on, RMA it, and proceed. You just got unlucky bro.
