TN Scale update timeout - train is not visible
flashdrive
WebGui:
/ui/system/update
Error Message
TrueNAS was unable to reach update servers.
I can ping a random website via shell - host location is China.
What URL should I check for the TN Scale Update?
Why is the train not visible?
RyanGrange
I have the same problem. Had to do a manual update from 22.12.3.3 to 22.12.4.2 and train is still blank. Update checks still fail.
RyanGrange
I tried using the TrueNAS cli app and update get_trains returns Namespace update not found
RyanGrange
Disregard that error. Didn't realize update was inside the system namespace.
Though system update get_trains returns Error: TimeoutError()
RyanGrange
Looks like update-master.ixsystems.com resolves to 2a10:c640:dead::5, and the dead part is correct. Can't ping it.
Dominick_Storj
Globally Distributed Genius
StorJ
Please note your location for our investigation into these issues, thank you.
Bejeweld
Zeeland, The Netherlands
When it eventually connects to IPV4 it downloads the train.
# wget https://update.ixsystems.com/scale/trains.json
--2023-10-25 22:39:20--  https://update.ixsystems.com/scale/trains.json
Resolving update.ixsystems.com (update.ixsystems.com)... 2a10:c640:dead::5, 136.0.77.2
Connecting to update.ixsystems.com (update.ixsystems.com)|2a10:c640:dead::5|:443... failed: Connection timed out.
Connecting to update.ixsystems.com (update.ixsystems.com)|136.0.77.2|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1240 (1.2K) [application/json]
Saving to: 'trains.json'
trains.json              100%[==================================>]   1.21K  --.-KB/s    in 0s
2023-10-25 22:41:30 (12.8 MB/s) - 'trains.json' saved [1240/1240]
And when trying through CLI:
[truenas]> system update check_available
Bejeweld
I was trying to download the update file to be able to manually update it, this seems to have the same problem. IPV6 is not working but after 2 minutes when it tries IPV4 it downloads the file.
# wget https://download.sys.truenas.net/TrueNAS-SCALE-Cobia/23.10.0/TrueNAS-SCALE-23.10.0.iso
--2023-10-26 11:46:22--  https://download.sys.truenas.net/TrueNAS-SCALE-Cobia/23.10.0/TrueNAS-SCALE-23.10.0.iso
Resolving download.sys.truenas.net (download.sys.truenas.net)... 2a10:c640:0:1::4, 185.244.226.4
Connecting to download.sys.truenas.net (download.sys.truenas.net)|2a10:c640:0:1::4|:443... failed: Connection timed out.
Connecting to download.sys.truenas.net (download.sys.truenas.net)|185.244.226.4|:443... connected.
Length: 1584807936 (1.5G) [application/x-cd-image]
Saving to: ‘TrueNAS-SCALE-23.10.0.iso’
TrueNAS-SCALE-23.10.0.is  29%[=========>                         ] 445.15M  31.1MB/s    eta 38s
Bejeweld
Update: upgrading/updating this way works.
# cli
[truenas]> system update manual path="/var/tmp/firmware/TrueNAS-SCALE-23.10.0.update"
[0%] ...
[50%] Reading update file...
[50%] Verifying rootfs.squashfs...
[50%] Verifying truenas_install/__main__.py...
[50%] Verifying truenas_install/__init__.py...
[50%] Running pre-checks...
[50%] Starting installer...
[50%] Creating dataset...
[50%] Extracting...
[62%] Extracting...
[75%] Extracting...
[75%] Performing post-install tasks...
[77%] Running autotune...
[85%] Preparing NVDIMM configuration...
[85%] Preparing GRUB configuration...
[90%] Updating initramfs...
[95%] Updating GRUB...
[97%] Configuring FIPS...
[95%] Cleaning up...
[100%] Cleaning up...
[truenas]>
Dominick_Storj
StorJ
An update for the IPv6 update issue has been pushed out at the CDN. Please advise if anyone is still having IPv6 related issues.
Thank you,
Bejeweld
I still have the same issue, even after upgrading to 23.10.
admin@truenas[~]$ cli
Dominick_Storj
StorJ
Could you update us on if you are still having issues? Have you also tried to download from the truenas page?
Thank you!
Bejeweld
I'm still getting: "TrueNAS was unable to reach update servers."
Manually updating via the CLI works and downloading via your link as well, but it's all manual.
RyanGrange
After downloading the 23.10.0.0 update from TrueNAS once 23.x was updated to stable and installing it by using the WebUI's manual update, my automated check and update to 23.10.0.1 worked perfectly. The WebUI lists the train as TrueNAS-SCALE-Cobia - TrueNAS SCALE Cobia [release].
Bejeweld
My NAS now sees, downloads and applies the updates (again). So this can be marked as resolved as far as I know! :)
