Hi all,
I'm replacing my legacy Minio apps with newer ones, and one of things i'm having issues with is enabling TLS. the old ones have the truenas cert on it and it works, I don't remember what I did. All apps are just using the TN loadbalancer, accessed using the TN FQDN for external apps (external to the TN appliance, but all traffic is inside the network.
The old ones are running version 2022-10-24_1.6.58 which can't be upgraded without a bit of messing about.... so that is why i decided to do some new stuff (like erasure coding for immutability etc etc.
The new app (until i get this working, will just be a single) is running 2023-03-13_1.7.15
Anyone help? Documentation I find is for direct linux boxes or truenas core.
