st2
 - Apr 30, 2018
Hey All,
I have a quick question- I have a KGPE-D16 Mobo with 2 AMD Opteron 6320 Processors and two (2) 16G of ECC Mem and planning on putting it together for my main FreeNAS build. This is mostly for storage which will be accessed by 4 people (for now). We mostly use AutoCAD and Revit.
I recently purchased the Norco 4220 case to be able to add drives as we grow.
Thanks
- Is this configuration a good one or should I get something simpler?
 - What SATA controller should I get to expand since this MOBO has 8 SAS/SATA port which only works with a PIKE controller
 - Should I get a PCI Storage SATA expander? if so which one do you guys recommend?
Thanks
