The issue of testing the actual read/write speed of a hard drive!
dengruxi
How can I test the real read-write speed of the disk without using memory acceleration? I used the dd command to test the data and the read was 8000MB/s and the write was 4000MB/s. This is clearly the role of memory as cache, not the true read-write speed of the hard disk!
joeschmuck
Old Man
How much RAM do you have? Exactly what dd command are you using?
Some setup things to note: Use a dataset that does not have compression (should not matter much when using if=/dev/random), use 'dd' with the random option (so the ARC will have no affect), and make.
dengruxi
The command I use is:
Write test:
dd if=/dev/zero of=/mnt/raid5/tmp. dat bs=2048k count=50k
Read test:
dd if=/mnt/raid5/tmp. dat of=/dev/null bs=2048k count=50k
How can I modify my command to get the real read and write speed of the hard disk without using memory? thank you
HoneyBadger
actually does care
Administrator
You could create a separate dataset, with compression disabled (to disable the compression when writing zeroes), and use the shell to disable data read caching with zfs set primarycache=metadata Poolname/Datasetname
Re-run your DD commands and the results should be closer to a "pure HDD test" - which is likely to demonstrate a worst-case scenario, as a real-world workload could benefit from both the read caching and compression on writes.
of=/mnt/raid5/tmp
I assume "RAID5" here is a pseudo-technical term, and you've configured a RAIDZ1 from within the TrueNAS UI?
dengruxi
"Raid5" is just my System Dataset Pool name, which is RAIDZ1,
What is the command to reopen after the shell disables the data read cache? thank you
HoneyBadger
actually does care
Administrator
zfs set primarycache=all Poolname/Datasetname - you'll also want to reenable compression, which should be doable through the TrueNAS web UI by changing the dataset's advanced properties.
