ericlesvieira
- Nov 8, 2023
Hello everyone, in greeting you I hope you can help me with a request.
I'm trying to use Tailscale on my Truenas to access apps via the internet.
When installing Tailscale via native apps in the Truenas store, I can install and enable the service, however, when adding a route, which in my service would be 192.168.3.27/24, the application goes into infinite deployment.
Having done this, I moved on to installing via truecharts, and the problem occurs in the same way.
In the History tab of the app, we have the following cases:
2023-11-08 11:06:46
Back-off restarting failed container tailscale in pod tailscale-79595f96d6-mbwqm_ix-tailscale(bfdc1a5b-0542-4d52-8342-d6b54fe895b2)
2023-11-08 11:05:50
Started container tailscale
2023-11-08 11:05:49
Created container tailscale
2023-11-08 11:05:40
Container image "tailscale/tailscale:v1.52.0@sha256:b102f468a2f1b0b6e9717cf728c43886c136e808010547eebe9ebd80aedd34c3" already present on machine
2023-11-08 11:05:36
Add eth0 [172.16.1.74/16] from ix-net
2023-11-08 11:05:32
Successfully assigned ix-tailscale/tailscale-79595f96d6-mbwqm to ix-truenas
2023-11-08 11:05:31
Scaled up replica set tailscale-79595f96d6 to 1
2023-11-08 11:05:31
Created pod: tailscale-79595f96d6-mbwqm
2023-11-08 10:21:26
Back-off restarting failed container tailscale in pod tailscale-9d7566857-q6js2_ix-tailscale(9d930cd1-f5e7-4ab0-a6de-1e02baa19dc3)
2023-11-08 10:21:08
Startup probe errored: rpc error: code = NotFound desc = failed to exec in container: failed to load task: no running task found: task 6daa4e5049df58989108bc8afec49f7b1eb8d04c577ce8874b46d73b63443b36 not found: not found
2023-11-08 10:20:56
2023-11-08 10:20:55
2023-11-08 10:20:51
Container image "tailscale/tailscale:v1.52.0" already present on machine
2023-11-08 10:20:46
Scaled up replica set tailscale-9d7566857 to 1
2023-11-08 10:20:46
Created pod: tailscale-9d7566857-q6js2
2023-11-08 10:20:46
Successfully assigned ix-tailscale/tailscale-9d7566857-q6js2 to ix-truenas
2023-11-08 10:20:45
Deleted pod: tailscale-d67786bc7-7tpnb
2023-11-08 10:20:44
Scaled down replica set tailscale-d67786bc7 to 0 from 1
2023-11-08 10:17:43
Back-off restarting failed container tailscale in pod tailscale-d67786bc7-7tpnb_ix-tailscale(aa53b2ce-73fc-4abc-934d-4a015320d5a5)
2023-11-08 10:17:20
2023-11-08 10:17:20
2023-11-08 10:17:15
2023-11-08 10:17:13
Scaled up replica set tailscale-d67786bc7 to 1
2023-11-08 10:17:13
Created pod: tailscale-d67786bc7-7tpnb
2023-11-08 10:17:13
Successfully assigned ix-tailscale/tailscale-d67786bc7-7tpnb to ix-truenas
2023-11-08 10:17:10
Readiness probe errored: rpc error: code = Unknown desc = failed to exec in container: container is in CONTAINER_EXITED state
2023-11-08 10:17:09
Scaled down replica set tailscale-546b8f8f76 to 0 from 1
2023-11-08 10:17:09
Deleted pod: tailscale-546b8f8f76-bxpb6
2023-11-08 10:17:09
Stopping container tailscale
I am using:
Name:
tailscale
App Version:
1.52.0
Chart Version:
1.0.21
Version:
TrueNAS-SCALE-23.10.0.1
assignment
2023-11-08 11:06:46
2023-11-08 11:05:50
2023-11-08 11:05:49
2023-11-08 11:05:40
2023-11-08 11:05:36
2023-11-08 11:05:32
2023-11-08 11:05:31
2023-11-08 11:05:31
2023-11-08 10:21:26
2023-11-08 10:21:08
2023-11-08 10:20:56
2023-11-08 10:20:55
2023-11-08 10:20:51
2023-11-08 10:20:46
2023-11-08 10:20:46
2023-11-08 10:20:46
2023-11-08 10:20:45
2023-11-08 10:20:44
2023-11-08 10:17:43
2023-11-08 10:17:20
2023-11-08 10:17:20
2023-11-08 10:17:15
2023-11-08 10:17:13
2023-11-08 10:17:13
2023-11-08 10:17:13
2023-11-08 10:17:10
2023-11-08 10:17:09
2023-11-08 10:17:09
2023-11-08 10:17:09
I am using:
Name:
tailscale
App Version:
1.52.0
Chart Version:
1.0.21
Version:
assignment
