The system is brand new and I was running badblocks since a couple of days. I noticed in the morning today the system is not running. And I can't turn the host on. Please help.
System spec
RAM 2x CT16G4WFD8266
MB SUPERMICRO MBD-X11SCL-IF-O
Chassis Superchassis CSE-721TQ-250B (250W PSU)
CPU G5600
OS CORSAIR FORCE Series MP300 120GB
BMC event log says
			System spec
CPU G5600
BMC event log says
- Timer interrupt - Interrupt type: None, Timer use at expiration: SMS/OS - Assertion
 - Hard Reset - Interrupt type: None, Timer use at expiration: SMS/OS - Assertion
- BMC light is blinking (status OK)
 - No fans running
 - Case front LAN light turns on
 - Can login to BMC via IPMI IP address
 - BMC reports the Host is currently off (duh)
 - Can't turn on the host using BMC or the physical switch on the chassis
 - No output on the display via VGA
 - No output on the iKVM/HTML
 - Watchdog timer disabled in BIOS
 - Haven't messed around with and watchdog jumpers
 - Tried clearing CMOS. Pulled battery out and shorted JBT1.
 - When I try to turn on the host via BMC I get the following error in the screenshot.
