As of yesterday my FreeNAS server keeps on crashing. All is running fine then it just powers down and automatically tries to power up. When trying to power up the fans spin up for 1/2 seconds then down again. This can happen 5-10 times and system will then reboot, but sometimes it can take 30-40 minutes before it reboots.
Whilst trying to boot if I go into IPMI and look under Post Snooping I am getting a Code 15, but I can't find any info as to what this code means. Anyone know what it means?
The longest the system has stayed up once it has managed to re-boot in about 20 mins, then it goes through the same sequence of trying to boot again.
It sounds like a hardware fault to me, I am in touch with SuperMicro but so far the only help I've had is
1. Remove ALL power from system
2. Remove Mainboard BIOS battery
3. short the 2 metal connections on the battery socket with a metal tool for ~5 seconds
4. re-insert BIOS Battery and restore power to the system
I have tried the above numerous times but to no avail.
Are there any logs that FreeNAS creates that may give me some more info of what is actually happening, I have 'Enable debug kernel' & 'Enable automatic upload of kernel crash dumps' options selected in the Advanced Settings menu.
Has anyone got any ideas of what the problem may be?
System build info is in my signature below.
Many thanks Grant
Many thanks Grant
