SOLVED System folder appeared in strange location
ravenblight
Hello
I have strange issue that after updating to latest bluefin version, after boot the notification about acl mismatch in one of my pools, after investigation I discovered .system folder in dataset where it shouldn't be any system files. Can I remove this folder ?
ravenblight
Hello, again
does somebody have clue how to handle this issue? My system according to gui should be in the boot-pool, and this ghost .system in one of the shares still gives me
SMB shares have path-related configuration issues that may
impact service stability: Segate4TB: ACL type mismatch with child mountpoint at
even after update to Cobia.
ravenblight
Ok nobody anwsered, so maybe for someone whoo has same problem.
I've checked zfs list for this strange dataset and it apeared as just small (too small for whole system) directory, and mounted to self, so I've executed zfs destroy -r on it and its gone, whole setup reboots normally without alert.
