System dataset full, help
answer35
Hi guys,
My system dataset is full but it seems that it is for no reason for me. I suspect that there is way too much logs but not sure.
My applications are located to ix-application dataset so it seems correct that it uses 7Gb but then there is 31Gb that are used in that dataset somewhere but I don't see anything from console
Is there anyone who can help me to cleanup my dataset ?
homer27081990
Fist you need to identify what scenario we are looking at: many small files, few or one large file or duplicate files. Go to shell and cd to your system dataset (/var/db/system, do not touch anything). Then run ls -al. That should give you details about files and directories, even hidden ones, including size.
---(Also, I have the slight suspicion that you posted this thread twice? If so, please remove the duplicate thread.)---
