syslog-ng core dump - Cause for concern?
kss18
Last night's security output email after the latest update -- See the last kernel log message --
> pid 1620 (syslog-ng), uid 0: exited on signal 6 (core dumped)
Is this something I should worry about (and fix)?
nas1.local changes in mounted filesystems:
22c22
< freenas-boot/ROOT/FreeNAS-9.3-STABLE-201502162250 / zfs rw,noatime,nfsv4acls 0 0
> freenas-boot/ROOT/FreeNAS-9.3-STABLE-201502271818 / zfs rw,noatime,nfsv4acls 0 0
nas1.local kernel log messages:
> FreeBSD 9.3-RELEASE-p10 #0 r275790+a21079f: Thu Feb 26 22:13:30 PST 2015
> root@build3.ixsystems.com:/tank/home/jkh/build/FN93/freenas/objs/os-base/amd64/fusion/jkh/FN93/freenas/FreeBSD/src/sys/FREENAS.amd64 amd64
> Timecounter "ACPI-safe" frequency 3579545 Hz quality 850
> ada1: <ST2000NC000-1CX164 CE02> ATA-8 SATA 3.x device
> Timecounter "TSC-low" frequency 1098198301 Hz quality 800
> Trying to mount root from zfs:freenas-boot/ROOT/FreeNAS-9.3-STABLE-201502271818 []...
> vboxdrv: fAsync=0 offMin=0x3a9 offMax=0x3975
> bridge0: link state changed to UP
> epair0a: Ethernet address: 02:7a:33:00:0b:0a
> epair0b: Ethernet address: 02:7a:33:00:0c:0b
-- End of security output --
PenalunWil
I have the same issues I believe...
I've just updated my FreeNAS 9.3 using the automatic up-dater and on re-booting I was looking through the shell and noticed failed socket:33 and also kernel pid... excited on signal 6. Is this anything to be concerned about or is this just FreeNAS booting back into its normal running mode?
Mar 3 14:46:45 willsnas smbd[2695]: [2015/03/03 14:46:45.854602, 0] ../lib/util/become_daemon.c:136(daemon_ready)
Mar 3 14:46:45 willsnas smbd[2695]: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1
Mar 3 14:46:46 willsnas smbd[2695]: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2
Mar 3 14:46:47 willsnas smbd[2695]: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3
Mar 3 14:46:48 willsnas smbd[2695]: dnssd_clientstub ConnectToServer: connect() failed Socket:33 Err:-1 Errno:2 No such file or directory
Mar 3 14:47:08 willsnas nmbd[2692]: STATUS=daemon 'nmbd' finished starting up and ready to serve connections*****
Mar 3 14:47:09 willsnas syslog-ng[3645]: syslog-ng starting up; version='3.5.6'
Mar 3 14:47:09 willsnas kernel: pid 1871 (syslog-ng), uid 0: exited on signal 6 (core dumped)
Mar 3 15:00:02 willsnas autosnap.py: [tools.autosnap:58] Popen()ing: /sbin/zfs snapshot tank@auto-20150303.1500-1
Hope you don't mind me joining in on this one kss18?
I've had one reply which might benefit both of us...
syslogng crashing... I think there's another thread about this that's rather recent and hasn't gotten any replies yet. Might want to file a bug report.
Wil.
PenalunWil
I've had a new security output this morning which shows an "excited on signal 6 (core dump)" at the start and finish of the output...
willsnas.local changes in mounted filesystems: 2c2
< freenas-boot/ROOT/default / zfs rw,noatime,nfsv4acls 0 0 ---
willsnas.local kernel log messages:
pid 4781 (syslog-ng), uid 0: exited on signal 6 (core dumped)
> Waiting (max 60 seconds) for system process `vnlru' to stop...done
> Waiting (max 60 seconds) for system process `bufdaemon' to stop...done
> Waiting (max 60 seconds) for system process `syncer' to stop...
> Syncing disks, vnodes remaining...0 0 0 0 done
> All buffers synced.
> GEOM_ELI: Device da0p1.eli destroyed.
> GEOM_ELI: Detached da0p1.eli on last close.
> GEOM_ELI: Device da1p1.eli destroyed.
> GEOM_ELI: Detached da1p1.eli on last close.
> GEOM_ELI: Device da2p1.eli destroyed.
> GEOM_ELI: Detached da2p1.eli on last close.
> GEOM_ELI: Device da3p1.eli destroyed.
> GEOM_ELI: Detached da3p1.eli on last close.
> GEOM_ELI: Device da4p1.eli destroyed.
> GEOM_ELI: Detached da4p1.eli on last close.
> GEOM_ELI: Device da5p1.eli destroyed.
> GEOM_ELI: Detached da5p1.eli on last close.
> Uptime: 4d5h14m5s
> Copyright (c) 1992-2014 The FreeBSD Project.
> Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
> The Regents of the University of California. All rights reserved.
> FreeBSD is a registered trademark of The FreeBSD Foundation.
> gcc version 4.2.1 20070831 patched [FreeBSD]
> CPU: Intel(R) Pentium(R) CPU G3220 @ 3.00GHz (2993.13-MHz K8-class CPU)
> Origin = "GenuineIntel" Id = 0x306c3 Family = 0x6 Model = 0x3c Stepping = 3
> Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
> Features2=0x4ddaebbf<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,<b11>,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,MOVBE,POPCNT,TSCDLT,XSAVE,OSXSAVE,RDRAND>
> AMD Features=0x2c100800<SYSCALL,NX,Page1GB,RDTSCP,LM>
> AMD Features2=0x21<LAHF,ABM>
> Standard Extended Features=0x2603<GSFSBASE,TSCADJ,ENHMOVSB,INVPCID>
> TSC: P-state invariant, performance statistics
> real memory = 17716740096 (16896 MB)
> avail memory = 16481914880 (15718 MB)
> Event timer "LAPIC" quality 600
> ACPI APIC Table: <SUPERM SMCI--MB>
> FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
> FreeBSD/SMP: 1 package(s) x 2 core(s)
> cpu0 (BSP): APIC ID: 0
> cpu1 (AP): APIC ID: 2
> WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
> ACPI Warning: FADT (revision 5) is longer than ACPI 5.0 version, truncating length 268 to 256 (20111123/tbfadt-325)
> ioapic0 <Version 2.0> irqs 0-23 on motherboard
> ispfw: registered firmware <isp_1040>
> ispfw: registered firmware <isp_1040_it>
> ispfw: registered firmware <isp_1080>
> ispfw: registered firmware <isp_1080_it>
> ispfw: registered firmware <isp_12160>
> ispfw: registered firmware <isp_12160_it>
> ispfw: registered firmware <isp_2100>
> ispfw: registered firmware <isp_2200>
> ispfw: registered firmware <isp_2300>
> ispfw: registered firmware <isp_2322>
> ispfw: registered firmware <isp_2400>
> ispfw: registered firmware <isp_2400_multi>
> ispfw: registered firmware <isp_2500>
> ispfw: registered firmware <isp_2500_multi>
> kbd1 at kbdmux0
> cryptosoft0: <software crypto> on motherboard
> aesni0: No AESNI support.
> padlock0: No ACE support.
> acpi0: <SUPERM SMCI--MB> on motherboard
> acpi0: Power Button (fixed)
> acpi0: reservation of 67, 1 (4) failed> cpu0: <ACPI CPU> on acpi0
> cpu1: <ACPI CPU> on acpi0
> hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
> Timecounter "HPET" frequency 14318180 Hz quality 950
> Event timer "HPET" frequency 14318180 Hz quality 550
> Event timer "HPET1" frequency 14318180 Hz quality 440
> Event timer "HPET2" frequency 14318180 Hz quality 440
> Event timer "HPET3" frequency 14318180 Hz quality 440
> Event timer "HPET4" frequency 14318180 Hz quality 440
> Event timer "HPET5" frequency 14318180 Hz quality 440
> Event timer "HPET6" frequency 14318180 Hz quality 440
> atrtc0: <AT realtime clock> port 0x70-0x77 irq 8 on acpi0
> atrtc0: Warning: Couldn't map I/O.
> Event timer "RTC" frequency 32768 Hz quality 0
> attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0
> Timecounter "i8254" frequency 1193182 Hz quality 0
> Event timer "i8254" frequency 1193182 Hz quality 100
> Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
> acpi_timer0: <24-bit timer at 3.579545MHz> port 0x1808-0x180b on acpi0
> pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
> pci0: <ACPI PCI bus> on pcib0
> pcib1: <ACPI PCI-PCI bridge> irq 16 at device 1.0 on pci0
> pci1: <ACPI PCI bus> on pcib1
> pcib2: <PCI-PCI bridge> irq 16 at device 1.1 on pci0
> pci2: <PCI bus> on pcib2
> mps0: <LSI SAS2308> port 0xe000-0xe0ff mem 0xf7240000-0xf724ffff,0xf7200000-0xf723ffff irq 16 at device 0.0 on pci2
> mps0: Firmware: 16.00.01.00, Driver: 16.00.00.00-fbsd
> mps0: IOCCapabilities: 1285c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,HostDisc>
> ehci0: <EHCI (generic) USB 2.0 controller> mem 0xf7504000-0xf75043ff irq 16 at device 26.0 on pci0
> usbus0: EHCI version 1.0
> usbus0 on ehci0
> pcib3: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0
> pci3: <ACPI PCI bus> on pcib3
> pcib4: <ACPI PCI-PCI bridge> at device 0.0 on pci3
> pci4: <ACPI PCI bus> on pcib4
> vgapci0: <VGA-compatible display> port 0xd000-0xd07f mem 0xf6000000-0xf6ffffff,0xf7000000-0xf701ffff irq 16 at device 0.0 on pci4
> vgapci0: Boot video device
> pcib5: <ACPI PCI-PCI bridge> irq 18 at device 28.2 on pci0
> pci5: <ACPI PCI bus> on pcib5
> igb0: <Intel(R) PRO/1000 Network Connection version - 2.4.0> port 0xc000-0xc01f mem 0xf7400000-0xf747ffff,0xf7480000-0xf7483fff irq 18 at device 0.0 on pci5
> igb0: Using MSIX interrupts with 3 vectors
> igb0: Ethernet address:
> igb0: Bound queue 0 to cpu 0
> igb0: Bound queue 1 to cpu 1
> pcib6: <ACPI PCI-PCI bridge> irq 19 at device 28.3 on pci0
> pci6: <ACPI PCI bus> on pcib6
> igb1: <Intel(R) PRO/1000 Network Connection version - 2.4.0> port 0xb000-0xb01f mem 0xf7300000-0xf737ffff,0xf7380000-0xf7383fff irq 19 at device 0.0 on pci6
> igb1: Using MSIX interrupts with 3 vectors
> igb1: Ethernet address:
> igb1: Bound queue 0 to cpu 0
> igb1: Bound queue 1 to cpu 1
> ehci1: <EHCI (generic) USB 2.0 controller> mem 0xf7503000-0xf75033ff irq 23 at device 29.0 on pci0
> usbus1: EHCI version 1.0
> usbus1 on ehci1
> isab0: <PCI-ISA bridge> at device 31.0 on pci0
> isa0: <ISA bus> on isab0
> ahci0: <Intel Lynx Point AHCI SATA controller> port 0xf050-0xf057,0xf040-0xf043,0xf030-0xf037,0xf020-0xf023,0xf000-0xf01f mem 0xf7502000-0xf75027ff irq 19 at device 31.2 on pci0
> ahci0: AHCI v1.30 with 6 6Gbps ports, Port Multiplier not supported
> ahcich0: <AHCI channel> at channel 0 on ahci0
> ahcich1: <AHCI channel> at channel 1 on ahci0
> ahcich2: <AHCI channel> at channel 2 on ahci0
> ahcich3: <AHCI channel> at channel 3 on ahci0
> ahcich4: <AHCI channel> at channel 4 on ahci0
> ahcich5: <AHCI channel> at channel 5 on ahci0
> acpi_button0: <Power Button> on acpi0
> acpi_tz0: <Thermal Zone> on acpi0
> acpi_tz1: <Thermal Zone> on acpi0
> uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
> uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
> uart2: <16550 or compatible> port 0x3e8-0x3ef irq 7 on acpi0
> orm0: <ISA Option ROMs> at iomem 0xc0000-0xc7fff,0xce000-0xcefff on isa0
> sc0: <System console> at flags 0x100 on isa0
> sc0: CGA <16 virtual consoles, flags=0x300>
> vga0: <Generic ISA VGA> at port 0x3d0-0x3db iomem 0xb8000-0xbffff on isa0
> wbwd0: DevID 0xc3 DevRev 0x33, will not attach, please report this.
> coretemp0: <CPU On-Die Thermal Sensors> on cpu0
> est0: <Enhanced SpeedStep Frequency Control> on cpu0
> p4tcc0: <CPU Frequency Thermal Control> on cpu0
> coretemp1: <CPU On-Die Thermal Sensors> on cpu1
> est1: <Enhanced SpeedStep Frequency Control> on cpu1
> p4tcc1: <CPU Frequency Thermal Control> on cpu1
> ZFS filesystem version: 5
> ZFS storage pool version: features support (5000)
> Timecounters tick every 1.000 msec
> ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
> usbus0: 480Mbps High Speed USB v2.0
> usbus1: 480Mbps High Speed USB v2.0
> ugen0.1: <Intel> at usbus0
> uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0
> ugen1.1: <Intel> at usbus1
> uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
> uhub0: 2 ports with 2 removable, self powered
> uhub1: 2 ports with 2 removable, self powered
> ugen0.2: <vendor 0x8087> at usbus0
> uhub2: <vendor 0x8087 product 0x8008, class 9/0, rev 2.00/0.05, addr 2> on usbus0
> ugen1.2: <vendor 0x8087> at usbus1
> uhub3: <vendor 0x8087 product 0x8000, class 9/0, rev 2.00/0.05, addr 2> on usbus1
> uhub2: 4 ports with 4 removable, self powered
> uhub3: 6 ports with 6 removable, self powered
> ugen0.3: <vendor 0x0000> at usbus0
> uhub4: <vendor 0x0000 product 0x0001, class 9/0, rev 2.00/0.00, addr 3> on usbus0
> uhub4: 4 ports with 3 removable, self powered
> ugen0.4: <vendor 0x0557> at usbus0
> ukbd0: <vendor 0x0557 product 0x2419, class 0/0, rev 1.10/1.00, addr 4> on usbus0
> kbd0 at ukbd0
> ums0: <vendor 0x0557 product 0x2419, class 0/0, rev 1.10/1.00, addr 4> on usbus0
> ums0: 3 buttons and [Z] coordinates ID=0
> ugen1.3: <Kingston> at usbus1
> umass0: <Kingston DataTraveler 2.0, class 0/0, rev 2.00/1.00, addr 3> on usbus1
> umass0: SCSI over Bulk-Only; quirks = 0xc100
> umass0:8:0:-1: Attached to scbus8
> ugen1.4: <BTC> at usbus1
> ukbd1: <BTC USB Keyboard, class 0/0, rev 1.10/1.80, addr 4> on usbus1
> kbd2 at ukbd1
> uhid0: <BTC USB Keyboard, class 0/0, rev 1.10/1.80, addr 4> on usbus1
> da0 at mps0 bus 0 scbus0 target 0 lun 0
> da0: <ATA WDC WD10EFRX-68P 1A01> Fixed Direct Access SCSI-6 device
> da0: Serial Number WD-WCC4J1724714
> SMP: AP CPU #1 Launched!
> da0: 600.000MB/s transfers
> da0: Command Queueing enabled
> da0: 953869MB (1953525168 512 byte sectors: 255H 63S/T 121601C)
> da0: quirks=0x8<4K>
> da6 at umass-sim0 bus 0 scbus8 target 0 lun 0
> da6: <Kingston DataTraveler 2.0 PMAP> Removable Direct Access SCSI-4 device
> da6: Serial Number 1C6F654E5975BDA0A94B02D2
> da6: 40.000MB/s transfers
> da6: 14996MB (30712320 512 byte sectors: 255H 63S/T 1911C)
> da6: quirks=0x3<NO_SYNC_CACHE,NO_6_BYTE>
> da1 at mps0 bus 0 scbus0 target 1 lun 0
> da1: <ATA WDC WD10EFRX-68P 1A01> Fixed Direct Access SCSI-6 device
> da1: Serial Number WD-WCC4J1775678
> da1: 600.000MB/s transfers
> da1: Command Queueing enabled
> da1: 953869MB (1953525168 512 byte sectors: 255H 63S/T 121601C)
> da1: quirks=0x8<4K>
> da2 at mps0 bus 0 scbus0 target 2 lun 0
> da2: <ATA WDC WD10EFRX-68P 1A01> Fixed Direct Access SCSI-6 device
> da2: Serial Number WD-WCC4J1755028
> da2: 600.000MB/s transfers
> da2: Command Queueing enabled
> da2: 953869MB (1953525168 512 byte sectors: 255H 63S/T 121601C)
> da2: quirks=0x8<4K>
> da3 at mps0 bus 0 scbus0 target 3 lun 0
> da3: <ATA WDC WD10EFRX-68P 1A01> Fixed Direct Access SCSI-6 device
> da3: Serial Number WD-WCC4J1755125
> da3: 600.000MB/s transfers
> da3: Command Queueing enabled
> da3: 953869MB (1953525168 512 byte sectors: 255H 63S/T 121601C)
> da3: quirks=0x8<4K>
> da5 at mps0 bus 0 scbus0 target 5 lun 0
> da5: <ATA ST1000DM003-1CH1 CC47> Fixed Direct Access SCSI-6 device
> da5: Serial Number Z1D8NFNC
> da5: 600.000MB/s transfers
> da5: Command Queueing enabled
> da5: 953869MB (1953525168 512 byte sectors: 255H 63S/T 121601C)
> da5: quirks=0x8<4K>
> da4 at mps0 bus 0 scbus0 target 4 lun 0
> da4: <ATA WDC WD10EFRX-68P 1A01> Fixed Direct Access SCSI-6 device
> da4: Serial Number WD-WCC4J1730341
> da4: 600.000MB/s transfers
> da4: Command Queueing enabled
> da4: 953869MB (1953525168 512 byte sectors: 255H 63S/T 121601C)
> da4: quirks=0x8<4K>
> Timecounter "TSC-low" frequency 1496565704 Hz quality 1000
> GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7)
> ipmi0: <IPMI System Interface> port 0xca2,0xca3 on acpi0
> ipmi0: KCS mode found at io 0xca2 on acpi
> ipmi0: IPMI device rev. 1, firmware rev. 1.10, version 2.0
> ipmi0: Number of channels 2
> ipmi0: Attached watchdog
> ipmi1: <IPMI System Interface> on isa0
> device_attach: ipmi1 attach returned 16
> wbwd0: HEFRAS and EFER do not align: EFER 0x4e DevID 0x00 DevRev 0x00 CR26 0x00
> GEOM_ELI: Device da0p1.eli created.
> GEOM_ELI: Encryption: AES-XTS 256
> GEOM_ELI: Crypto: software
> GEOM_ELI: Device da1p1.eli created.
> GEOM_ELI: Device da2p1.eli created.
> GEOM_ELI: Device da3p1.eli created.
> GEOM_ELI: Device da4p1.eli created.
> GEOM_ELI: Device da5p1.eli created.
> vboxdrv: fAsync=0 offMin=0x27c offMax=0xb50
I thought I'd post the whole report in an assumption that it may be useful for those who are trying to fix this bug.
PenalunWil
Sorry Guys. I've just had an interesring look through the bugs list for the first time oops =X
