Syncthing error after added folder.
frodm
Thanks for adding me into this Forum. I´m a newbie on TrueNAS, so please bear with me when I don´t understand.
After I added a folder in Syncthing (official version) I get these error messages:
2023-04-15 12:59:23: Loading ignores: lstat /data/serier/.stignore: permission denied
2023-04-15 12:59:23: Failed to create folder marker: stat /data/serier/.stfolder: permission denied
2023-04-15 12:59:23: Error on folder "SerierTrueNAS" (rdlfk-fo9s2): stat /data/serier/.stfolder: permission denied
To my understanding this is related to ACL and permissions on the shared folder. The shared folder seems ok as I have mapped it another machine. I played around with several users and groups, and disabled ACL. But no go.
Any ideas how to fix this is much appreciated.
Cheers
morganL
Captain Morgan
Administrator
Have you disabled HostPathValidation?
frodm
morganL
Captain Morgan
Administrator
Can you update to 22.12.2 before we start troubleshooting.
frodm
Sure. I did, but ran into a problem. Under Applications->Installed Applications, it says "Applications are not running". Is this how it should be? I can´t find any reference on this in the documentation.
frodm
I tried installing the Syncthing app again. Error:
[EFAULT] Kubernetes service is not running.
Error: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/job.py", line 426, in run await self.future File "/usr/lib/python3/dist-packages/middlewared/job.py", line 461, in __run_body rv = await self.method(*([self] + args)) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1186, in nf res = await f(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1318, in nf return await func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/chart_release.py", line 397, in do_create await self.middleware.call('kubernetes.validate_k8s_setup') File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1386, in call return await self._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1335, in _call return await methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/plugins/kubernetes_linux/update.py", line 513, in validate_k8s_setup raise CallError(error) middlewared.service_exception.CallError: [EFAULT] Kubernetes service is not running.
frodm
I played around with NICs, which resultet in the error over. That´s fix now, apps are back. The Syncthing error is stille there.
// Frode
