tmkrvs
 - Jan 3, 2024
Hi there,
we're currently into the process of swapping out our NAS system at the DC for a new system based on HPE DL380 hardware with 16x 2.5" SAS HDDs, each 1.2TB in size. We're going to create a single pool with RAID-Z2 on a HBA (currently deciding between P440ar in HBA mode, H240ar or even a totally different one) which will use a NVMe PCIe SSD as caching device. System runs of an industrial-grade (SLC) microSD card inserted in the onboard microSD slo (I know, this might not be ideal!)
To be said: this server is just used as a data-dumping system with no heavy workload. Protocols which will be used are iSCSI and FTP(S) - no CIFS or anything else - no virtualization, no applications are going to be run on the TN server.
I know about TNs capability of expanding a pool when upgrading the HDDs in size - but is it possible to swap out the HDDs for SSDs (not mixing SAS with SATA, it will stay a pure SAS storage) at some day? The controllers should be capable of this as long as they're not used as a RAID itself.
BR
Tim
BR
Tim
