SOLVED Swap Cache SSD, then move boot to Old SSD
mpyusko
OK, so no ZIL/SLOG utilization during iSCSI benchmarking. So is seems this is a good thing since it out performs NFS?
iSCSI tests (Right side)
NFS (Left side)
HoneyBadger
actually does care
Administrator
Please read the resource linked below, titled "Sync writes, or: Why is my ESXi NFS so slow, and why is iSCSI faster?"
I'm aware you're using XCP and not VMware, but the same principles apply.
mpyusko
Ok, so iSCSI is running a hybrid kind of sync mode and NFS isn't. So I should switch iSCSI to sync=always if I want to maintain data integrity and utilize the ZIL/SLOG device? But that will hurt performance overall performance right? The majority of traffic is generally read, not write. After the SAN/NAS has been up and running for a while, very few read requests actually hit the array. In fact, booting or cycling a VM can actually happen straight out of the ARC within seconds. So given the hardware I have... knowing I'm about to nearly double the RAM, double the L2ARC, and drop in a couple x5660 CPUs... What can I do to enhanced write performance while still maintaining data integrity?
HoneyBadger
actually does care
Administrator
iSCSI still puts your VMs at risk with sync=standard but it doesn't put the pool itself at risk. If you want full VM safety sync=always is needed for the data integrity; "using an SLOG device" is a way to regain some of the lost performance. If you're willing to risk a bit of data loss to your VMs, and are willing to roll the machines/datastore back to ZFS snapshots or external backups, you can run standard but be sure that you understand the risk you're taking. Having a UPS does mitigate this a fair bit as you're now only subject to internal failures (PSU, HBA, backplane/cabling/etc) versus losing your external power.
A faster SLOG device, faster vdevs on the back-end, faster network in-between. Upgrade them based on what's currently bottlenecking you. ;)
mpyusko
Installed the pair of X5660 CPUs, RAM and larger L2ARC last night. Have to wait on a USB to SATA cable before I can switch from the Flashdrive to the SSD.
Being an R710, I'm limited in my options. The LSI 9210-8i plugs directly into the backplane so I lose two ports. I have L2ARC running in an optical Bay adapter with a SATA-3 add-in card (integrated is SATA-2). I have a USB card so I can hookup the PSu for monitoring, and then I have a PCIe to NVMe adapter which contains the ZIL/SLOG. That ties up all 4 internal slots. Since the PSUs are directly connected to the Mobo, there isn't any way to easily get power for another SSD/Drive. PCIe is limited to 25W so, that leaves USB. So when the adapter cable arrives I'll dd the Flashdrive to the SSD and connect the SSD to the internal USB 2.0 port. For kicks, I tried upgrading to 11.3 last night, but it's still giving me invalid checksum errors.
HoneyBadger
actually does care
Administrator
Just make sure you back up your config. dd'ing and swapping is one method; is there a reason you couldn't have both connected (even if the SSD is external temporarily) and make the boot pool mirrored? Then you can break the mirror later.
The Optane M.2 cards - even the cheap M10 sticks - actually have a higher TBW rating than your 660p. So one of those might be a performance improvement over the current 660p, which could then be repurposed elsewhere. I threw the same CrystalDiskMark test (admittedly not the best) at a test-box here that has a 32GB M.2 Optane SLOG - see the results below:
mpyusko
After all the upgrades (except the boot device (You're right, I'll just mirror then break the mirror. ;) )
iSCSI...
NFS...
I saw a ton of activity on the ZIL/SLOG after setting sync=always.
I also tried to Limit the ARC after upgrading the RAM. (160 GB - 16GB for VMs = 144 GB) Is this correct? or do I need to aslo reserve space for the OS/Kernel?
acrstat.py output....
root@cygnus[~]# arc_summary.py
System Memory:
        1.03%   1.61    GiB Active,     1.15%   1.79    GiB Inact
        68.17%  106.30  GiB Wired,      0.00%   0       Bytes Cache
        29.65%  46.23   GiB Free,       -0.00%  -188416 Bytes Gap
        Real Installed:                         160.00  GiB
        Real Available:                 99.97%  159.95  GiB
        Real Managed:                   97.48%  155.92  GiB
        Logical Total:                          160.00  GiB
        Logical Used:                   69.99%  111.98  GiB
        Logical Free:                   30.01%  48.02   GiB
Kernel Memory:                                  1.70    GiB
        Data:                           97.55%  1.66    GiB
        Text:                           2.45%   42.62   MiB
Kernel Memory Map:                              155.92  GiB
        Size:                           7.41%   11.56   GiB
        Free:                           92.59%  144.36  GiB
        Page:  1
ARC Summary: (HEALTHY)
        Storage pool Version:                   5000
        Filesystem Version:                     5
        Memory Throttle Count:                  0
ARC Misc:
        Deleted:                                3.98m
        Mutex Misses:                           3.07k
        Evict Skips:                            3.07k
ARC Size:                               64.75%  93.24   GiB
        Target Size: (Adaptive)         100.00% 144.00  GiB
        Min Size (Hard Limit):          13.45%  19.37   GiB
        Max Size (High Water):          7:1     144.00  GiB
ARC Size Breakdown:
        Recently Used Cache Size:       49.99%  71.98   GiB
        Frequently Used Cache Size:     50.01%  72.02   GiB
ARC Hash Breakdown:
        Elements Max:                           3.84m
        Elements Current:               99.90%  3.83m
        Collisions:                             1.64m
        Chain Max:                              5
        Chains:                                 202.91k
        Page:  2
ARC Total accesses:                                     411.62m
        Cache Hit Ratio:                97.55%  401.55m
        Cache Miss Ratio:               2.45%   10.07m
        Actual Hit Ratio:               93.11%  383.27m
        Data Demand Efficiency:         93.36%  35.57m
        Data Prefetch Efficiency:       67.08%  10.51m
        CACHE HITS BY CACHE LIST:
          Anonymously Used:             4.50%   18.07m
          Most Recently Used:           5.04%   20.23m
          Most Frequently Used:         90.41%  363.04m
          Most Recently Used Ghost:     0.04%   151.43k
          Most Frequently Used Ghost:   0.01%   55.33k
        CACHE HITS BY DATA TYPE:
          Demand Data:                  8.27%   33.21m
          Prefetch Data:                1.76%   7.05m
          Demand Metadata:              86.41%  346.98m
          Prefetch Metadata:            3.56%   14.30m
        CACHE MISSES BY DATA TYPE:
          Demand Data:                  23.44%  2.36m
          Prefetch Data:                34.35%  3.46m
          Demand Metadata:              41.80%  4.21m
          Prefetch Metadata:            0.42%   42.05k
        Page:  3
L2 ARC Summary: (HEALTHY)
        Passed Headroom:                        269.57k
        Tried Lock Failures:                    57.03k
        IO In Progress:                         1
        Low Memory Aborts:                      0
        Free on Write:                          951
        Writes While Full:                      902
        R/W Clashes:                            0
        Bad Checksums:                          0
        IO Errors:                              0
        SPA Mismatch:                           110.20m
L2 ARC Size: (Adaptive)                         434.40  GiB
        Compressed:                     65.46%  284.37  GiB
        Header Size:                    0.03%   151.84  MiB
L2 ARC Breakdown:                               9.70m
        Hit Ratio:                      20.75%  2.01m
        Miss Ratio:                     79.25%  7.69m
        Feeds:                                  136.63k
L2 ARC Buffer:
        Bytes Scanned:                          53.94   TiB
        Buffer Iterations:                      136.63k
        List Iterations:                        546.48k
        NULL List Iterations:                   0
L2 ARC Writes:
        Writes Sent:                    100.00% 62.86k
        Page:  4
DMU Prefetch Efficiency:                        58.33m
        Hit Ratio:                      4.76%   2.78m
        Miss Ratio:                     95.24%  55.55m
        Page:  5
        Page:  6
ZFS Tunable (sysctl):
        kern.maxusers                           10572
        vm.kmem_size                            167419584512
        vm.kmem_size_scale                      1
        vm.kmem_size_min                        0
        vm.kmem_size_max                        1319413950874
        vfs.zfs.vol.immediate_write_sz          32768
        vfs.zfs.vol.unmap_sync_enabled          0
        vfs.zfs.vol.unmap_enabled               1
        vfs.zfs.vol.recursive                   0
        vfs.zfs.vol.mode                        2
        vfs.zfs.sync_pass_rewrite               2
        vfs.zfs.sync_pass_dont_compress         5
        vfs.zfs.sync_pass_deferred_free         2
        vfs.zfs.zio.dva_throttle_enabled        1
        vfs.zfs.zio.exclude_metadata            0
        vfs.zfs.zio.use_uma                     1
        vfs.zfs.zil_slog_bulk                   786432
        vfs.zfs.cache_flush_disable             0
        vfs.zfs.zil_replay_disable              0
        vfs.zfs.version.zpl                     5
        vfs.zfs.version.spa                     5000
        vfs.zfs.version.acl                     1
        vfs.zfs.version.ioctl                   7
        vfs.zfs.debug                           0
        vfs.zfs.super_owner                     0
        vfs.zfs.immediate_write_sz              32768
        vfs.zfs.standard_sm_blksz               131072
        vfs.zfs.dtl_sm_blksz                    4096
        vfs.zfs.min_auto_ashift                 12
        vfs.zfs.max_auto_ashift                 13
        vfs.zfs.vdev.queue_depth_pct            1000
        vfs.zfs.vdev.write_gap_limit            4096
        vfs.zfs.vdev.read_gap_limit             32768
        vfs.zfs.vdev.aggregation_limit_non_rotating131072
        vfs.zfs.vdev.aggregation_limit          1048576
        vfs.zfs.vdev.trim_max_active            64
        vfs.zfs.vdev.trim_min_active            1
        vfs.zfs.vdev.scrub_max_active           2
        vfs.zfs.vdev.scrub_min_active           1
        vfs.zfs.vdev.async_write_max_active     10
        vfs.zfs.vdev.async_write_min_active     1
        vfs.zfs.vdev.async_read_max_active      3
        vfs.zfs.vdev.async_read_min_active      1
        vfs.zfs.vdev.sync_write_max_active      10
        vfs.zfs.vdev.sync_write_min_active      10
        vfs.zfs.vdev.sync_read_max_active       10
        vfs.zfs.vdev.sync_read_min_active       10
        vfs.zfs.vdev.max_active                 1000
        vfs.zfs.vdev.async_write_active_max_dirty_percent60
        vfs.zfs.vdev.async_write_active_min_dirty_percent30
        vfs.zfs.vdev.mirror.non_rotating_seek_inc1
        vfs.zfs.vdev.mirror.non_rotating_inc    0
        vfs.zfs.vdev.mirror.rotating_seek_offset1048576
        vfs.zfs.vdev.mirror.rotating_seek_inc   5
        vfs.zfs.vdev.mirror.rotating_inc        0
        vfs.zfs.vdev.trim_on_init               1
        vfs.zfs.vdev.bio_delete_disable         0
        vfs.zfs.vdev.bio_flush_disable          0
        vfs.zfs.vdev.cache.bshift               16
        vfs.zfs.vdev.cache.size                 0
        vfs.zfs.vdev.cache.max                  16384
        vfs.zfs.vdev.default_ms_shift           29
        vfs.zfs.vdev.min_ms_count               16
        vfs.zfs.vdev.max_ms_count               200
        vfs.zfs.vdev.trim_max_pending           10000
        vfs.zfs.txg.timeout                     5
        vfs.zfs.trim.enabled                    1
        vfs.zfs.trim.max_interval               1
        vfs.zfs.trim.timeout                    30
        vfs.zfs.trim.txg_delay                  32
        vfs.zfs.spa_min_slop                    134217728
        vfs.zfs.spa_slop_shift                  5
        vfs.zfs.spa_asize_inflation             24
        vfs.zfs.deadman_enabled                 1
        vfs.zfs.deadman_checktime_ms            5000
        vfs.zfs.deadman_synctime_ms             1000000
        vfs.zfs.debug_flags                     0
        vfs.zfs.debugflags                      0
        vfs.zfs.recover                         0
        vfs.zfs.spa_load_verify_data            1
        vfs.zfs.spa_load_verify_metadata        1
        vfs.zfs.spa_load_verify_maxinflight     10000
        vfs.zfs.max_missing_tvds_scan           0
        vfs.zfs.max_missing_tvds_cachefile      2
        vfs.zfs.max_missing_tvds                0
        vfs.zfs.spa_load_print_vdev_tree        0
        vfs.zfs.ccw_retry_interval              300
        vfs.zfs.check_hostid                    1
        vfs.zfs.mg_fragmentation_threshold      85
        vfs.zfs.mg_noalloc_threshold            0
        vfs.zfs.condense_pct                    200
        vfs.zfs.metaslab_sm_blksz               4096
        vfs.zfs.metaslab.bias_enabled           1
        vfs.zfs.metaslab.lba_weighting_enabled  1
        vfs.zfs.metaslab.fragmentation_factor_enabled1
        vfs.zfs.metaslab.preload_enabled        1
        vfs.zfs.metaslab.preload_limit          3
        vfs.zfs.metaslab.unload_delay           8
        vfs.zfs.metaslab.load_pct               50
        vfs.zfs.metaslab.min_alloc_size         33554432
        vfs.zfs.metaslab.df_free_pct            4
        vfs.zfs.metaslab.df_alloc_threshold     131072
        vfs.zfs.metaslab.debug_unload           0
        vfs.zfs.metaslab.debug_load             0
        vfs.zfs.metaslab.fragmentation_threshold70
        vfs.zfs.metaslab.force_ganging          16777217
        vfs.zfs.free_bpobj_enabled              1
        vfs.zfs.free_max_blocks                 18446744073709551615
        vfs.zfs.zfs_scan_checkpoint_interval    7200
        vfs.zfs.zfs_scan_legacy                 0
        vfs.zfs.no_scrub_prefetch               0
        vfs.zfs.no_scrub_io                     0
        vfs.zfs.resilver_min_time_ms            3000
        vfs.zfs.free_min_time_ms                1000
        vfs.zfs.scan_min_time_ms                1000
        vfs.zfs.scan_idle                       50
        vfs.zfs.scrub_delay                     4
        vfs.zfs.resilver_delay                  2
        vfs.zfs.top_maxinflight                 32
        vfs.zfs.delay_scale                     500000
        vfs.zfs.delay_min_dirty_percent         60
        vfs.zfs.dirty_data_sync                 67108864
        vfs.zfs.dirty_data_max_percent          10
        vfs.zfs.dirty_data_max_max              4294967296
        vfs.zfs.dirty_data_max                  4294967296
        vfs.zfs.max_recordsize                  1048576
        vfs.zfs.default_ibs                     15
        vfs.zfs.default_bs                      9
        vfs.zfs.zfetch.array_rd_sz              1048576
        vfs.zfs.zfetch.max_idistance            67108864
        vfs.zfs.zfetch.max_distance             33554432
        vfs.zfs.zfetch.min_sec_reap             2
        vfs.zfs.zfetch.max_streams              8
        vfs.zfs.prefetch_disable                0
        vfs.zfs.send_holes_without_birth_time   1
        vfs.zfs.mdcomp_disable                  0
        vfs.zfs.per_txg_dirty_frees_percent     30
        vfs.zfs.nopwrite_enabled                1
        vfs.zfs.dedup.prefetch                  1
        vfs.zfs.dbuf_cache_lowater_pct          10
        vfs.zfs.dbuf_cache_hiwater_pct          10
        vfs.zfs.dbuf_cache_shift                5
        vfs.zfs.dbuf_cache_max_bytes            5198307584
        vfs.zfs.arc_min_prescient_prefetch_ms   6
        vfs.zfs.arc_min_prefetch_ms             1
        vfs.zfs.l2c_only_size                   0
        vfs.zfs.mfu_ghost_data_esize            70523813888
        vfs.zfs.mfu_ghost_metadata_esize        0
        vfs.zfs.mfu_ghost_size                  70523813888
        vfs.zfs.mfu_data_esize                  40647808512
        vfs.zfs.mfu_metadata_esize              216837632
        vfs.zfs.mfu_size                        41271884800
        vfs.zfs.mru_ghost_data_esize            12774014976
        vfs.zfs.mru_ghost_metadata_esize        0
        vfs.zfs.mru_ghost_size                  12774014976
        vfs.zfs.mru_data_esize                  49226321408
        vfs.zfs.mru_metadata_esize              94657024
        vfs.zfs.mru_size                        58062458880
        vfs.zfs.anon_data_esize                 0
        vfs.zfs.anon_metadata_esize             0
        vfs.zfs.anon_size                       3687936
        vfs.zfs.l2arc_norw                      0
        vfs.zfs.l2arc_feed_again                1
        vfs.zfs.l2arc_noprefetch                0
        vfs.zfs.l2arc_feed_min_ms               200
        vfs.zfs.l2arc_feed_secs                 1
        vfs.zfs.l2arc_headroom                  2
        vfs.zfs.l2arc_write_boost               40000000
        vfs.zfs.l2arc_write_max                 10000000
        vfs.zfs.arc_meta_limit                  38654705664
        vfs.zfs.arc_free_target                 870759
        vfs.zfs.arc_kmem_cache_reap_retry_ms    1000
        vfs.zfs.compressed_arc_enabled          1
        vfs.zfs.arc_grow_retry                  60
        vfs.zfs.arc_shrink_shift                7
        vfs.zfs.arc_average_blocksize           8192
        vfs.zfs.arc_no_grow_shift               5
        vfs.zfs.arc_min                         20793230336
        vfs.zfs.arc_max                         154618822656
        vfs.zfs.abd_chunk_size                  4096
        Page:  7
root@cygnus[~]#
mpyusko
Interestingly enough, the M10 seems significantly slower in Write IOPS than the 660p/665p (There are very minor differences between the two with the major on being the 665p increases TBW from 200 to 300) so wouldn't the 660p/665p be the better choice?
Cutrently...
ada0 TBW: 1.41773 TB (L2ARC)
da4 TBW: 13.4886 TB (WD Red NAS)
da5 TBW: 13.4997 TB (WD Red NAS)
nvme0 TBW: [28.3TB] (ZIL/SLOG)
mpyusko
(See Post)
mpyusko
So I swapped out my 500 GB Samsung 860 EVO and replaced it with the 1 TB Intel 660p NVMe that I was using for my ZIL/SLOG.
Then I added a NEW 250GB Samsung 970 EVO Plus for my ZIL/SLOG.
This is taken straight from a Win10 VM running under BHYVE....
This is from a Win10 VM running under XCP-ng.... (iSCSI)
Same VM only with an NFS Volume....
With no other changes made to the environment, it seems like my RND4KQ1T1 and RND4KQ32T16 Write has gone down significantly.... around half.
What the H???? With the upgrade in hardware, I would expect to see gains, not losses.
root@cygnus[~]# smartctl -i /dev/nvme1
smartctl 7.0 2018-12-30 r4883 [FreeBSD 11.3-RELEASE-p9 amd64] (local build)
Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org
Model Number:                       INTEL SSDPEKNW010T8
Serial Number:                      PHNH904100TT1P0B
Firmware Version:                   002C
PCI Vendor/Subsystem ID:            0x8086
IEEE OUI Identifier:                0x5cd2e4
Controller ID:                      1
Number of Namespaces:               1
Namespace 1 Size/Capacity:          1,024,209,543,168 [1.02 TB]
Namespace 1 Formatted LBA Size:     512
Local Time is:                      Fri Jul 17 13:12:34 2020 EDT
root@cygnus[~]# smartctl -i /dev/nvme0
Model Number:                       Samsung SSD 970 EVO Plus 250GB
Serial Number:                      S59BNZFN503665L
Firmware Version:                   2B2QEXM7
PCI Vendor/Subsystem ID:            0x144d
IEEE OUI Identifier:                0x002538
Total NVM Capacity:                 250,059,350,016 [250 GB]
Unallocated NVM Capacity:           0
Controller ID:                      4
Namespace 1 Size/Capacity:          250,059,350,016 [250 GB]
Namespace 1 Utilization:            223,158,272 [223 MB]
Namespace 1 IEEE EUI-64:            002538 55019d4a72
Local Time is:                      Fri Jul 17 13:12:52 2020 EDT
da4 TBW: 15.8475 TB (WD Red NAS)
da5 TBW: 15.8538 TB (WD Red NAS)
nvme0 TBW: [227GB] (ZIL/SLOG)
nvme1 TBW: [33.0TB] (L2ARC)
arc_summary.py...
System Memory:
        1.20%   1.87    GiB Active,     0.91%   1.41    GiB Inact
        89.28%  139.20  GiB Wired,      0.00%   0       Bytes Cache
        3.61%   5.63    GiB Free,       5.00%   7.80    GiB Gap
        Real Available:                 99.97%  159.94  GiB
        Logical Used:                   95.60%  152.95  GiB
        Logical Free:                   4.40%   7.05    GiB
Kernel Memory:                                  1.82    GiB
        Data:                           97.54%  1.78    GiB
        Text:                           2.46%   45.94   MiB
        Size:                           5.51%   8.60    GiB
        Free:                           94.49%  147.32  GiB
        Page:  1
ARC Misc:
        Deleted:                                1.57m
        Mutex Misses:                           1.18k
        Evict Skips:                            1.18k
ARC Size:                               99.99%  127.94  GiB
        Target Size: (Adaptive)         100.00% 127.95  GiB
        Min Size (Hard Limit):          15.13%  19.36   GiB
        Max Size (High Water):          6:1     127.95  GiB
ARC Size Breakdown:
        Recently Used Cache Size:       63.81%  81.64   GiB
        Frequently Used Cache Size:     36.19%  46.31   GiB
ARC Hash Breakdown:
        Elements Max:                           4.45m
        Elements Current:               99.95%  4.45m
        Collisions:                             978.82k
        Chain Max:                              5
        Chains:                                 270.34k
        Page:  2
ARC Total accesses:                                     97.58m
        Cache Hit Ratio:                95.54%  93.23m
        Cache Miss Ratio:               4.46%   4.35m
        Actual Hit Ratio:               92.03%  89.80m
        Data Demand Efficiency:         95.44%  32.68m
        Data Prefetch Efficiency:       58.34%  6.38m
          Anonymously Used:             3.49%   3.26m
          Most Recently Used:           11.94%  11.13m
          Most Frequently Used:         84.38%  78.67m
          Most Recently Used Ghost:     0.10%   91.08k
          Most Frequently Used Ghost:   0.09%   82.49k
          Demand Data:                  33.46%  31.19m
          Prefetch Data:                3.99%   3.72m
          Demand Metadata:              62.50%  58.27m
          Prefetch Metadata:            0.05%   50.34k
          Demand Data:                  34.25%  1.49m
          Prefetch Data:                61.07%  2.66m
          Demand Metadata:              4.33%   188.31k
          Prefetch Metadata:            0.35%   15.42k
        Page:  3
        Passed Headroom:                        101.64k
        IO In Progress:                         0
        Free on Write:                          79
        Writes While Full:                      4.67k
        R/W Clashes:                            0
        Bad Checksums:                          0
        IO Errors:                              0
        SPA Mismatch:                           5.65m
L2 ARC Size: (Adaptive)                         263.31  GiB
        Compressed:                     74.06%  195.01  GiB
        Header Size:                    0.05%   124.43  MiB
L2 ARC Breakdown:                               4.30m
        Hit Ratio:                      5.52%   237.43k
        Miss Ratio:                     94.48%  4.06m
        Feeds:                                  55.96k
L2 ARC Buffer:
        Bytes Scanned:                          9.89    TiB
        Buffer Iterations:                      55.96k
        List Iterations:                        220.88k
        NULL List Iterations:                   685
L2 ARC Writes:
        Writes Sent:                    100.00% 31.57k
        Page:  4
DMU Prefetch Efficiency:                        18.73m
        Hit Ratio:                      9.66%   1.81m
        Miss Ratio:                     90.34%  16.92m
        Page:  5
        Page:  6
        kern.maxusers                           10572
        vm.kmem_size                            167415398400
        vm.kmem_size_min                        0
        vfs.zfs.vol.mode                        2
        vfs.zfs.zio.taskq_batch_pct             75
        vfs.zfs.zil_maxblocksize                131072
        vfs.zfs.zil_nocacheflush                0
        vfs.zfs.debug                           0
        vfs.zfs.vdev.def_queue_depth            32
        vfs.zfs.vdev.initializing_max_active    1
        vfs.zfs.vdev.initializing_min_active    1
        vfs.zfs.vdev.removal_max_active         2
        vfs.zfs.vdev.removal_min_active         1
        vfs.zfs.vdev.validate_skip              0
        vfs.zfs.vdev.max_ms_shift               38
        vfs.zfs.vdev.max_ms_count_limit         131072
        vfs.zfs.space_map_ibs                   14
        vfs.zfs.spa_allocators                  4
        vfs.zfs.deadman_checktime_ms            60000
        vfs.zfs.deadman_synctime_ms             600000
        vfs.zfs.recover                         0
        vfs.zfs.dirty_data_sync_pct             20
        vfs.zfs.dbuf_metadata_cache_overflow    0
        vfs.zfs.dbuf_metadata_cache_shift       6
        vfs.zfs.dbuf_metadata_cache_max_bytes   2599088384
        vfs.zfs.dbuf_cache_max_bytes            5198176768
        vfs.zfs.mfu_ghost_data_esize            85239063552
        vfs.zfs.mfu_ghost_size                  85239063552
        vfs.zfs.mfu_data_esize                  48222936576
        vfs.zfs.mfu_metadata_esize              187322880
        vfs.zfs.mfu_size                        49436049920
        vfs.zfs.mru_ghost_data_esize            51167708160
        vfs.zfs.mru_ghost_size                  51167708160
        vfs.zfs.mru_data_esize                  79471159808
        vfs.zfs.mru_metadata_esize              66280960
        vfs.zfs.mru_size                        87094208000
        vfs.zfs.anon_size                       1977856
        vfs.zfs.arc_meta_limit                  34346532704
        vfs.zfs.arc_free_target                 870737
        vfs.zfs.arc_min                         20792707072
        vfs.zfs.arc_max                         137386130816
        vfs.zfs.abd_scatter_enabled             1
        Page:  7
root@cygnus[~]#
root@cygnus[~]# arcstat.py -f arcsz,c,l2asize,l2size arcsz c l2asize l2size 127G 127G 195G 263G
HoneyBadger
actually does care
Administrator
As mentioned before, what makes an SSD a good SLOG device isn't necessarily what you expect. Neither the 660p or the 970 EVO were designed to deliver low latency writes with a cache flush.
mpyusko
RND4KQ1T1
I guess what confuses me is the 970 EVO Plus is a much faster drive. so to have the performance halved, and not even marginally increased, seems a bit odd.
Also, I ran these two benchmarks simultaneously, from two different hypervisors to the same iSCSI SR as above. (Yes, it's a 2x GigE Lagg) They were both competing for the same resources. at the same time....
If you notice, the Read side had no measurable impact. However the write side was definitely impacted being split between the two hypervisors. The exception is the RND4KQ1T1 which appears to only taken a ~10% hit.
HoneyBadger
actually does care
Administrator
But the EVO is not a "faster drive" if the performance metric in question is "fast sync writes" - which is what an SLOG workload will cause.
Quite simply, for SLOG purposes, it wasn't an upgrade.
HoneyBadger
actually does care
Administrator
It may not have been an upgrade, but here are the stats with no ZIL/SLOG...
Definitely an upgrade over "not having one at all" but the 660p was doing a better job of it.
I really need to remake the "SLOG thread" with some more recent information, but I would suggest trying to pick up a 16G or 32G Optane card and installing that for an inexpensive M.2 based solution. If you have a full PCIe slot available (or can make one free) then consider a P3700 or Optane 900p. If money is no object, P4800X. If you've got the thermal space, consider a used Radian RMS-200 as well.
mpyusko
In the interest of filling out the performance Stats:
I upgraded the ZIL/SLOG to a 64 GB M.10 Optane. I initially had a 32GB in there, but I could only saturate 2 NICs with Sync writes. Once I got all 4 NICs configured with iSCSI Multipath, the bottleneck became grossly apparent.
(4) Multipath iSCSI without ZIL/SLOG
(4) Multpath iSCSI with 32 GB m.10 Optane as ZIL/SLOG:
(4) Multipath iSCSI with 64 GB m.10 Optane as ZIL/SLOG:
Based on the stats from Intel, the 64 GB Optane should be able to handle 5 links saturated (writes).
My R710 is pretty well maxed out as far as what I can do to it.
If I increase the RAM, it will drop from 1333 to 1066.​
I could upgrade the CPUs, but would going from dual X5660 to Dual X5690 really be worth it?​
I can increase the mechanical drives to whatever SATA/SAS which may have performance benefits.​
I could upgrade the 660p L2ARC, but the gains would be marginal.​
The quad NICs are fully utilized (can't add more)*​
The internal PCIe slots are fully utilized (LSI SAS-9211-8i, PCIe/NVME L2ARC, PCIe/NVME SLOG, PCIe/SATA3 Boot/OS)​
So at this point I'm just going to let it sit and do it's thing. I have about 2 more years before I'll preemtively upgrade the mechanical disks. That should be interesting. This SAN serves iSCSI to VMs along with SMB and NFS shares. The dependents are 3 hypervisors and 6 workstations.
HoneyBadger
actually does care
Administrator
Generally speaking, extra RAM (quantity) far outweighs the drop in speed. Consider that 1066MHz or "PC3-8500" RAM is still capable of 8500MB/s of bandwidth. I don't think that will be a bottleneck for you. ;)
Given that you only have 3 hypervisors, have you tuned the round-robin policies to switch paths at a lower number of I/Os? You can probably get the low-queue-depth numbers up a little higher.
mpyusko
Honestly, no (How?). It was driving me nuts getting iSCSI to work properly in the first place. I had multipathing enabled, but couldn't get both paths active. I had a friend login and I'm not 100% sure what the fix was, but I think he said it had something to do with being a FeeNAS box that upgraded to TrueNAS and XCP-ng was looking for FreeNAS but the SAN was serving TrueNAS. He had to update the .conf on the hypervisors to say TrueNAS and restart the links to get multipathing to work. I have not done any tuning. Once I had 2 paths active, I was able to get all 4 working. 2 are dedicated to iSCSI only, 1 NIC is iSCSI/NFS/Internet, and the other NIC is iSCSI/SMB/Management. My thought is iSCSI will always have at least 250 MB/s but can reach 500 MB/s when traffic on the other NICs is light.
I wish I could get the multipathing performance of of NFS and SMB that I can out of iSCSI.
HoneyBadger
actually does care
Administrator
My mistake - I forgot that you were using XCP-ng instead of VMware for the hypervisor. I'm not sure how (or if it's possible) to adjust the pathing from anything other than the default "round robin" with whatever internal metric the underlying OS is using for cycling on that.
Re: the enabling it, yes, the switch from FreeNAS to TrueNAS changed the string in the SCSI device ID, so if there were claim rules for "allow MPIO on vendor FreeNAS" then they wouldn't have applied on TrueNAS. Just be careful on the sharing traffic because while it might make for good benchmarks, it could result in weird/unpredictable behavior in real-world. If 3/4 links are basically unused but the fourth is saturated by SMB/NFS then the round-robin could go Fast-Fast-Fast-Timeout/Very Slow and I'm honestly not sure how the multipath driver would react to that.
