Stuck in boot 23.10.1
OneLastNAS
After I upgrade to 23.10.1 from 23.10.0.1, the startup stops at ix-zfs.service.
Does anyone know anything about this? Thanks!
OneLastNAS
When I removed all HDD, it still can't boot.
NugentS
the thingie isn't plugged into the doohickey
Given that we have no idea what either the thingie or the doohickey is - you might like to read forum rules and educate us!
OneLastNAS
I exported a debug file, hope this helps in diagnosing the problem.
  • debug-TrueNAS-20231231005617.tgz
OneLastNAS
JumpMaster
Thanks for this! For me it fails unrecoverable after change the MTU on a bridged NIC to 9000. Boot takes 40+ minutes after several failures. Running most network commands fail. I am only able to roll back to 23.10.0.1, wipe the network config and perform a fresh upgrade. It does mean I can't use jumbo frames.
