After upgrading to 12.0-U3.1. My network access is down, no Web access or shares. My network has not changed so it related to True NAS network stack or something is not loading during the boot process.
I can go to shell and ping the TrueNAS em0 IP address, but not the gateway. I've tried changing the IP address, I've notice that it changes the IP address but it says restarting network failed. I have three network cards (Intel) but none of them can communicate with my network. I believe my storage pools are intact and working.
1) I've tested the NAS switch port and cable by hooking it up to a laptop, it got on the network with DHCP enabled. So it's not the switch or cable.
2) Next I created a USB boot drive with fresh TrueNAS install, the network, tried using static IP and DHCP, also a gateway has been given. It can't ping the gateway just as the existing setup.
What would be the best thing to do in order to fix this? Would resetting the configuration to default fix this issue? I believe I can import or restore my existing pools, so I won't lose my data.
Thanks
Steve
Thanks
Steve
