Mr. Gosh
 - Nov 24, 2013
Hey Guys,
after many years of FreeNAS Storage Server Administration I have a bigger Problem with a new Box for the first time.
As I read in the Forums there should't be a big Problem with UEFI Boards, so I bought a Asus H87M-Plus for my Customer.
The Plan was to use a small SSD for the Main System.
But after Installing on there it won't boot.
After the Screen:
are just coming more and more "#" in there - ca. 1 per second.
So second try - Install to USB Stick.
There It Boots but hangs on the following error:
so this happens either on usb3 port and on usb2 port
so ot looks like on the usb stikc the loader works - and on the ssd it doesn't but on the usb stick the root filesystem couldn't be mounted.
So i tried what happens if both are connected and I select "F5 Drive 1" to boot the ssd from usb stick... that works - but as it is not really a solution I stopped testing where the changes than get stored - if they really land on the ssd as i suspect, or wherever.....
I tired all this with FreeNAS 9.1.1 and with the newest nightly build (which was called beta 3 i think).
Do you have any suggestions?
I tried any combination out of compatibility modes in the uefi firmware settings...
Thanks for the hints...
Mr.Gosh
After the Screen:
F1 FreeBSD F2 FreeBSD F6 PXE Boot: ########
ugen0.2: <Unknown> at usbus0 (disconnected) Trying to mount root from ufs:/dev/ufs/FreeNASs1a [ro]... mountroot: waiting for device /dev/ufs/FreeNASs1a Mounting from ufs:/dev/ufs/FreeNASs1a failed with error 19. Loader variables: vfs.root.mountfrom=ufs:/dev/ufs/FreeNASs1a vfs.root.mountfrom.options=ro Manual root......blablabla.... mountroot>
Mr.Gosh
