I have a pool that is made of four 1TB HDDs that had a drive go bad. It was an older drive so I didn't think much of it. Replaced with an affordable WD Blue 1TB and after a couple weeks, the pool became degraded. Hmm... ok so I replaced it with a 2TB WD Red NAS drive (CMR if it matters). Did a short and a long SMART test. Passed. Wake up in the morning to this message...
So i ran the smartctl --all /dev/sdb command
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.10.93+truenas] (local build)
Device Model: WDC WD20EFZX-68AWUN0
Serial Number: WD-WX62D313TD45
LU WWN Device Id: 5 0014ee 2bee442e1
Firmware Version: 81.00B81
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Rotation Rate: 5400 rpm
Form Factor: 3.5 inches
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Mar 1 18:14:54 2022 PST
SMART support is: Enabled
General SMART Values:
was never started.
Self-test execution status: ( 40) The self-test routine was interrupted
by the host with a hard or soft reset.
data collection: (21360) seconds.
capabilities: (0x11) SMART execute Offline immediate.
No Auto Offline data collection support.
command.
No Offline surface scan supported.
Self-test supported.
No Selective Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 230) minutes.
SCT capabilities: (0x303d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 100 253 021 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 3
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 69
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 2
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 0
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 2
194 Temperature_Celsius 0x0022 118 112 000 Old_age Always - 29
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Interrupted (host reset) 80% 56 -
# 2 Short offline Completed without error 00% 55 -
# 3 Extended offline Interrupted (host reset) 10% 55 -
# 4 Extended offline Completed without error 00% 16 -
# 5 Short offline Completed without error 00% 3 -
# 6 Short offline Completed without error 00% 0 -
Selective Self-tests/Logging not supported
So what is the Interrupted (host reset) about? A fast search leads me to think maybe I have a bad cable? The drives are connected to an LSI HBA with a SAS to SATA breakout cable. Prime suspect?
EDIT:
Also of note, the error would clear when the server was rebooted.
This morning, I received a notice that the WD Blue drive that has already been removed, was just faulted. So the system thinks the drive is still installed??
Pool tiny_vault state is ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected.
2022-03-01 03:48:03 (America/Los_Angeles)So i ran the smartctl --all /dev/sdb command
was never started.
command.
power-saving mode.
No Errors Logged
EDIT:
