Rob Granger
 - May 12, 2015
Is there any way to query the Truenas TM shares and see if they are showing up as TM shares.
They always show up as SMB shares and I can connect to them, but my TM sometimes just doesn't see the share. Sometimes restarting SMB helps, sometimes just editing a TM share and saving it causes the disks to appear in the +add disk under TM, sometimes not :( Which is the fustrating part.
I know there were a few others that had this issue years ago, my wee troubles just started again recently. I upgraded to 13.U5 from 13.U3 to try and see if that improved things. Nope.
SCALE any more reliable with TM?
Thanks,
Sorry for the ramble, I am stuck.
Thanks,
TrueNas 13.U5
Dell T710
Version:
TrueNAS-13.0-U5.3
12 GB ECC memory
 dns-sd -B _smb._tcp
Browsing for _smb._tcp
DATE: ---Sun 12 Nov 2023---
17:46:14.994  ...STARTING...
Timestamp     A/R    Flags  if Domain               Service Type         Instance Name
17:46:14.995  Add        3   6 local.               _smb._tcp.           macmac
17:46:14.995  Add        3   8 local.               _smb._tcp.           macmac
17:46:14.995  Add        3   8 local.               _smb._tcp.           kmac.home
17:46:14.995  Add        3   6 local.               _smb._tcp.           kmac.home
17:46:14.995  Add        3   6 local.               _smb._tcp.           freenas
17:46:14.995  Add        3   8 local.               _smb._tcp.           freenas
17:46:14.995  Add        3   6 local.               _smb._tcp.           biggermac
17:46:14.995  Add        3   8 local.               _smb._tcp.           biggermac
17:46:14.995  Add        3   1 local.               _smb._tcp.           rmp1
17:46:14.995  Add        3   8 local.               _smb._tcp.           rmp1
17:46:14.995  Add        3   6 local.               _smb._tcp.           rmp1
17:46:14.995  Add        3   6 local.               _smb._tcp.           macjack
17:46:14.995  Add        3   8 local.               _smb._tcp.           macjack
17:46:14.995  Add        3   8 local.               _smb._tcp.           rmp2
17:46:14.995  Add        2   6 local.               _smb._tcp.           rmp2
dns-sd -B _adisk._tcp
Browsing for _adisk._tcp
17:43:23.603  ...STARTING...
17:45:15.955  Add        2   6 local.               _adisk._tcp.         truenas
17:45:16.431  Add        2   8 local.               _adisk._tcp.         truenas
oot@truenas[/usr/local/etc]# testparm -s
Load smb config files from /usr/local/etc/smb4.conf
lpcfg_do_global_parameter: WARNING: The "client ntlmv2 auth" option is deprecated
Loaded services file OK.
Weak crypto is allowed
Server role: ROLE_STANDALONE
# Global parameters
[global]
    aio max threads = 2
    bind interfaces only = Yes
    client NTLMv2 auth = No
    disable spoolss = Yes
    dns proxy = No
    enable web service discovery = Yes
    guest account = rgranger
    kernel change notify = No
    load printers = No
    logging = syslog@0 file
    map to guest = Bad User
    max log size = 5120
    ntlm auth = ntlmv1-permitted
    registry shares = Yes
    server min protocol = NT1
    server multi channel support = No
    server role = standalone server
    server string = TrueNAS Server
    username map = /usr/local/etc/smbusername.map
    username map cache time = 60
    workgroup = HOME
    fruit:nfs_aces = No
    rpc_server:mdssvc = disabled
    rpc_daemon:mdssd = disabled
    idmap config * : backend = tdb
    directory name cache size = 0
    dos filemode = Yes
[depot-bak]
    ea support = No
    guest ok = Yes
    kernel share modes = No
    path = /mnt/tank/depot
    posix locking = No
    read only = No
    smbd max xattr size = 2097152
    vfs objects = fruit streams_xattr shadow_copy_zfs ixnas zfs_core aio_fbsd
    fruit:resource = stream
    fruit:metadata = stream
    nfs4:chown = true
    ixnas:dosattrib_xattr = false
[backup-truenas]
    ea support = No
    guest ok = Yes
    level2 oplocks = No
    oplocks = No
    path = /mnt/tank/backup
    read only = No
    strict locking = Yes
    nfs4:chown = true
[vmprod]
    ea support = No
    level2 oplocks = No
    oplocks = No
    path = /mnt/tank/vmprod
    read only = No
    vfs objects = fruit streams_xattr shadow_copy_zfs noacl zfs_core aio_fbsd
    nfs4:chown = true
[TM-BIGMAC]
    ea support = No
    guest ok = Yes
    mangled names = no
    path = /mnt/tank/TimeMachine-Dataset/TM-BIGMAC/%U
    read only = No
    vfs objects = tmprotect catia fruit streams_xattr shadow_copy_zfs ixnas zfs_core aio_fbsd
    zfs_core:zfs_auto_create = true
    fruit:locking = none
    fruit:time machine = yes
    fruit:encoding = native
    nfs4:chown = true
[TM-MACMAC]
    ea support = No
    guest ok = Yes
    mangled names = no
    path = /mnt/tank/TimeMachine-Dataset/TM-MACMAC/%U
    read only = No
    nfs4:chown = true
[TM-MACJACK]
    ea support = No
    guest ok = Yes
    path = /mnt/tank/TimeMachine-Dataset/TM-MACJACK/%U
    posix locking = No
    read only = No
    vfs objects = tmprotect fruit streams_xattr shadow_copy_zfs ixnas zfs_core aio_fbsd
    nfs4:chown = true
[TM-RMP1]
    ea support = No
    guest ok = Yes
    mangled names = no
    path = /mnt/tank/TimeMachine-Dataset/TM-RMP1/%U
    read only = No
    nfs4:chown = true
[TM-BIGGERMAC]
    ea support = No
    guest ok = Yes
    mangled names = no
    path = /mnt/tank/TimeMachine-Dataset/TM-BIGGERMAC/%U
    read only = No
    nfs4:chown = true
[TM-RMP2]
    ea support = No
    path = /mnt/tank/TimeMachine-Dataset/TM-RMP2/%U
    posix locking = No
    read only = No
    nfs4:chown = true
Xi Systems Freenas Mini
Platform: FREENAS-MINI-2.0
Version: TrueNAS-13.0-U3.1
Serial Number: A1-39469
HostName: freenas.home
ARC and Zil on SSD
DRIVES:
ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
ada0: <WDC WD20EFRX-68EUZN0 80.00A80> ACS-2 ATA SATA 3.x device
ada0: Serial Number WD-WCC4MHT0U6VU
ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 1907729MB (3907029168 512 byte sectors)
ada0: quirks=0x1<4K>
ada1 at ahcich1 bus 0 scbus1 target 0 lun 0
ada1: <WDC WD20EFRX-68EUZN0 80.00A80> ACS-2 ATA SATA 3.x device
ada1: Serial Number WD-WCC4MHECYZ6S
ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 1907729MB (3907029168 512 byte sectors)
ada1: quirks=0x1<4K>
ada2 at ahcich2 bus 0 scbus2 target 0 lun 0
ada2: <16GB SATA Flash Drive SFDE001A> ACS-2 ATA SATA 3.x device
ada2: Serial Number B051502910100000012C
ada2: 600.000MB/s transfers (SATA 3.x, UDMA5, PIO 512bytes)
ada2: Command Queueing enabled
ada2: 15272MB (31277232 512 byte sectors)
ada3 at ahcich4 bus 0 scbus4 target 0 lun 0
ada3: <SanDisk SDSSDHII120G X31200RL> ACS-2 ATA SATA 3.x device
ada3: Serial Number 150682400561
ada3: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 512bytes)
ada3: Command Queueing enabled
ada3: 114473MB (234441648 512 byte sectors)
ada4 at ahcich5 bus 0 scbus5 target 0 lun 0
ada4: <SanDisk SD6SB1M064G1022I X231600> ATA8-ACS SATA 3.x device
ada4: Serial Number 150940404113
ada4: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 512bytes)
ada4: Command Queueing enabled
ada4: 61057MB (125045424 512 byte sectors)
ada5 at ahcich14 bus 0 scbus14 target 0 lun 0
ada5: <WDC WD20EFRX-68EUZN0 80.00A80> ACS-2 ATA SATA 3.x device
ada5: Serial Number WD-WCC4M6UXJ15A
ada5: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada5: Command Queueing enabled
ada5: 1907729MB (3907029168 512 byte sectors)
ada5: quirks=0x1<4K>
ada6 at ahcich15 bus 0 scbus15 target 0 lun 0
ada6: <WDC WD20EFRX-68EUZN0 80.00A80> ACS-2 ATA SATA 3.x device
ada6: Serial Number WD-WCC4MHECYZ19
ada6: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada6: Command Queueing enabled
ada6: 1907729MB (3907029168 512 byte sectors)
ada6: quirks=0x1<4K>
