I would like to say in my defense that I noticed that but I intentionally kept them so "strange" because they are the same that on my screen appear in your command in the guide. That beeing said your suggestion fixed the issue. THANK YOU!
After a fast check they are different in your guide from any other quote you've written, change them if you want. Just in case another newbie like me comes again.
Hi again, no problem after that now I have all working fine, but I want to let you know that after your correction of what I said the colored words in your guide disappeared :(:(
this mount points do exactly what you asked for. They link inside jail dir with FreeNAS dir so when you set to download in that particular dir, it will download where you set with mountpoint
Hmm okay, thanks for the confirmation. I must have goofed something up then, because I cannot find any files after they have downloaded lol.
EDIT: HUZZAH!!! I deleted the jail and started all over again, making sure to follow your steps exactly and paying close attention to the directories I was using. Everything is now working as intended. Thank you so much for the wonderful guide. All of the linux distros i will be seeding now thank you as well ;)
Thanks for the excellent guide. I have used it successfully in the past.
However did something happen to the transmission package?
pkg update
Updating FreeBSD repository catalogue...
FreeBSD repository is up to date.
All repositories are up to date.
root@transmission:~ # pkg search transmission
py37-transmission-rpc-2.0.4 Python module for Transmission bittorent client RPC protocol
py37-transmissionrpc-0.11_1 Python module that communicates with Transmission through JSON-RPC
transmission-cli-3.00_3 Meta-port for Transmission BitTorrent client
transmission-daemon-3.00_3 Meta-port for Transmission BitTorrent client
transmission-gtk-3.00_3 Meta-port for Transmission BitTorrent client
transmission-remote-gui-gtk2-5.18.0_4 Remote GUI for transmission daemon
transmission-utils-3.00_2 Meta-port for Transmission BitTorrent client
transmission-web-3.00_1 Meta-port for Transmission BitTorrent client
root@transmission:~ # pkg install transmission
pkg: No packages available to install matching 'transmission' have been found in the repositories
Should I be using something different?
Hi, i don't know.
I just jumped to TrueNAS and i'm sick of fixing/changing/adapting/loosing a lot of things and time so right now i'm moving everything on a Debian VM with Docker. This should be, at least in theory, "bulletproof"
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
