Starting a new build, advice with setup needed
rdcustom
Hello All,
I'm starting a new NAS for my home network and I need some good advice.
This will be the hardware:
-Asus Prime B550M/CSM
-Ryzen 3 4100
-32gb DDR4 Corsair
-2x 128gb SSD m.2 sata
-8x WD Red 4TB
My NAS will be used as follow:
-Plex Server (HW encoding/decoding needed)
-Rsync and FTP backups
-Remote sync with my office server trough internet
I would like to use both 128gb SSDs as Raid1 Boot drive (they are cheap ones from Amazon, so I'd like to go with a Raid1 for reliability) and Hard Drives in Raid 6 or Raid 60.
I also have a spare SSD (1tb), would you suggest to use it as Read/Write cache (especially for Plex) or the RAM would be enough?
Thanks in advance and Happy NAS to all
somethingweird
- Asus Prime B550M/CSM - realtek LAN? Not a good choice.
- WD Red 4TB - are they SMR or CMR? SMR those aren't drives you want. ZFS and SMR drives don't mix.
truenas doesn't have RAID 6 / RAID 60.
rdcustom
Thanks for the reply
I'm not sure about raid and disk configuration, I will choose when finished the build.
Realtek Lan will be fine for now, when switching to 10gbe net year I will probably upgrade that
About disks, I already have them in my Netgear and Qnap NAS and they are WD40EFRX so they are CMR and compatible with ZFS according to WD
But what about the SSD cache?
somethingweird
SSD cache - for me personally - I would max out RAM first before deciding. If had a spare SSD - use the spinners for mass storage and VM/jail on SSD.
LarsR
How do you intend to connect all those disks? There's a high chance that some of the regular sata connectors get disabled when using the m.2 slots.
ChrisRJ
somethingweird
rdcustom
I read the Asus manual and seems that m.2 don't affect data connectors; there's 4 of them onboard and I bought a pcie to 4 sata card
LarsR
Don't use pcie to sata cards, they are known to cause issues. If you want more ports LSI HBA's are the way to go.
rdcustom
Dammit! I already have it... which kind of issue can they cause?
What if I setup the system and change the card after?
Davvo
If you tell us what you plan to use we can see if it's suitable.
You need at least 64GB of RAM in order to consider using L2ARC.
joeschmuck
Old Man
It will really depend on the specific card you have. Try it, some work fine, some do not. I use them myself but the chipset is supported (see my signature). I have been using mine for many years. I would lots data on the NAS for the drives connected to the PCIe to SATA card BUT have those files backed up somewhere. A nice shiny HBA it the preferred path as they have a very good track record.
