SSH public key auth broken after upgrade to TrueNAS 13
Darren David
Hi all-
I recently upgraded to TrueNAS 13.0 and something about the upgrade broke SSH keypair auth. I use SecureCRT on Windows, and both PCs that I was able to SSH in from using my keypair for auth stopped working after the upgrade. Password login works fine.
Has something changed with FreeBSD 13 (or TrueNAS) that I need to adjust for?
Darren
Although this is in the context of replication, I think it's going to be relevant for you as well:
Source:
  • Like
Reactions: Maq
marahin
one of my users have been using SSHFS to connect to my TrueNAS Core instance. After upgrading to TrueNAS 13 the SSHFS connection broke. User in question has CentOS 6.
$ ssh xxxxx@yyyyy
no hostkey alg
and the SSHFS connection:
# sshfs -o allow_other -o nonempty,reconnect,ServerAliveInterval=30,ServerAliveCountMax=2880 -o cache=no xxxx@yyyyyy:/mnt/somethingsomething /mnt/somethingsomething
read: Connection reset by peer
Adding
PubkeyAcceptedAlgorithms +ssh-rsa
did not help on its own, I also had to add
HostKeyAlgorithms +ssh-rsa
as suggested here: https://unix.stackexchange.com/questions/679451/sshd-no-hostkey-alg-fixed-but-still-confused
FrankWard
Source:
Adding this parameter did not work for me. I can connect using the keys provided in .ssh for root using FileZilla, but it doesn't work for SecureCRT.
James S
Source:
I, too, have this issue of broken SSH after upgrading.
However, whilst I can add this parameter am I missing something here? Is this just a work-around? In other words, should I be upgrade something on SSH to make this work?
FrankWard
I was able to get it working by adding the public key directly to the user account. I'm able to remote into SSH using SecureCRT, WinSCP, and FileZilla. Still can't get it to work with VSCode.
